Jesse OBrien Posted September 19, 2013 Share Posted September 19, 2013 I'm certain this has been addressed before, and I did a lot of searching (on several forums) but have come up short. This past weekend, I attended a hillclimb race event and made a few observations that made me rethink wheel choices. I had always assumed the widest wheel possible would offer the most mechanical grip and amount to the best 'momentum' car possible. I saw a few Turner cars ripping up the track with plenty of power and plenty of mechanical grip, along with well-sorted suspension. They were unquestionably fast: However, a cobbled-together awd twin-turbo Audi broke the track record. It was unquestionably fast as well. The thing that got me thinking and questioning what I "knew" is that the Audi is running significantly less tire, weighs roughly the same, and can put down roughly the same amount of power. Both cars had excellent pilots. However, the car with narrower tires was putting down better times, going against everything I had previously believed. I asked the drivers about it afterward, and I got a brief primer on roll centers, kingpin angles, and terrifying steering vs smooth steering characteristics. I had always assumed that the hub should be lined up with the centerline of the wheel, but apparently I had it all wrong and the roll center should be lined up with the centerline of the wheel. I'm working my way through some of the experienced racers' advice on here, and am not quite ready to invest in wheels/tires, but I'd like to get some research done ahead of time for this. I have to assume that there's a wheel/tire combo that's a good 'starting point' for the s30. Right now, I suppose I'm looking for 15x8 wheels since they have a reasonable selection of sticky DOT tires, but I wanted to see if I could get some reading material from you fine folks before I spend money and potentially ruin the car's handling capabilities. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 19, 2013 Share Posted September 19, 2013 I had always assumed that the hub should be lined up with the centerline of the wheel, but apparently I had it all wrong and the roll center should be lined up with the centerline of the wheel. This makes no sense. You're comparing a physical suspension component with a calculated abstraction. The main reson the Audi was faster up the hill was 4WD. Hill climbs are generally low speed events (like an autocross) and thus reward accelerative traction. Anything you can do to increase grip under acceleration will reduce your times. Spreading grip around four contact patches gives you twice as much area for acceleration in a 4WD vehicle (given the same size tires). Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 19, 2013 Share Posted September 19, 2013 If you can fit 15x9s, the 225 extreme summer performance and DOT tires work well on a 9. They're really wide for 225. You said roll center should somehow relate to the tire. I think you meant scrub radius. There are lots of race cars running a positive scrub radius. The most immediate effect in a Z is that a big scrub radius will make it harder to steer.AWD is the traction king. Google "traction circles" and you should find some stuff about how much traction each tire has at any given point. Suffice it to say that in a high hp 2wd car the undriven wheels are usually not pushing to their max, and that's why AWD has an advantage. That thing really does look cobbled together though... LOL Quote Link to comment Share on other sites More sharing options...
Leon Posted September 19, 2013 Share Posted September 19, 2013 The answer to your question is probably more complex than you expect. Correctly sizing wheels/tires factors in a car's entire performance window, and you really need tire data to pick the right one. Good luck getting that from the manufacturers, unless you know somebody! You need to plan out maximum acceleration numbers for take-off, braking, changing direction, etc. and try to match up a tire to that without wasting material (e.g. too wide of a tire for your needs will increase unsprung weight and rotational inertia). Tire size also affects gearing, so I'd start by choosing a diameter to work with that matches the gearing you'd like... Ditto JC on the RC comment. Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted September 19, 2013 Author Share Posted September 19, 2013 This makes no sense. You're comparing a physical suspension component with a calculated abstraction. I agree, none of this makes any sense. I thought I had a moderate understanding of how things worked 'till these guys started explaining things to me. I may just be taking away the buzzwords from the conversation, and didn't absorb all the context. I feel like I'm starting over in suspension 101 again. The main reson the Audi was faster up the hill was 4WD. Hill climbs are generally low speed events (like an autocross) and thus reward accelerative traction. Anything you can do to increase grip under acceleration will reduce your times. Spreading grip around four contact patches gives you twice as much area for acceleration in a 4WD vehicle (given the same size tires). That makes perfect sense, and is what I had always assumed. More mechanical grip means faster times. The Audi driver reported slower times with wider tires, which is what threw a wrench into my brain. It's kind of funny, my whiteboard in the garage has a 'johnc prep list' on it with starting recommendations straight from you. I think that should be standard reading for anyone who buys an s30 (http://forums.hybridz.org/topic/91330-240z-chassis-prep-reinforcements/?do=findComment&comment=864737). I think we all end up asking that question at some point in our ownership. If you can fit 15x9s, the 225 extreme summer performance and DOT tires work well on a 9. They're really wide for 225. You said roll center should somehow relate to the tire. I think you meant scrub radius. There are lots of race cars running a positive scrub radius. The most immediate effect in a Z is that a big scrub radius will make it harder to steer. AWD is the traction king. Google "traction circles" and you should find some stuff about how much traction each tire has at any given point. Suffice it to say that in a high hp 2wd car the undriven wheels are usually not pushing to their max, and that's why AWD has an advantage. That thing really does look cobbled together though... LOL It's very carefully cobbled together. Scrub radius is what they were explaining to me, but I'm not sure anyone used that term. I want 0 offset on the 15x9's correct? I'm really just looking for a solid starting point, it doesn't need to be the end-all best possible wheel. I've ogled Braap's old yellow z with its massively wide tires many, many times and would love to be able to justify running wide tires like that. I'm trying not to put the cart before the horse though. The answer to your question is probably more complex than you expect. Correctly sizing wheels/tires factors in a car's entire performance window, and you really need tire data to pick the right one. Good luck getting that from the manufacturers, unless you know somebody! You need to plan out maximum acceleration numbers for take-off, braking, changing direction, etc. and try to match up a tire to that without wasting material (e.g. too wide of a tire for your needs will increase unsprung weight and rotational inertia). Tire size also affects gearing, so I'd start by choosing a diameter to work with that matches the gearing you'd like... Ditto JC on the RC comment. I have a lot of math to do, but for right now I'm just looking for a starting point. I'm trying to balance this to be street driveable as well, since I don't have a truck-trailer to haul it on. The main problem is that I don't know what the car's performance window actually is. I don't have dyno results for the engine, haven't changed any suspension components (yet, since I don't know exactly what the car needs yet). The only real determination I could make is gearing, and even with that, I'd like to swap up to an LSD (STI, perhaps) which will change my gearing again. For now, a starting point is all I need. Quote Link to comment Share on other sites More sharing options...
R3VO 3VOM Posted September 19, 2013 Share Posted September 19, 2013 (edited) If you look at the cobbled Audi, he wasn't exactly running 145's. So a wider contact patch helps. But also, that thing doesn't look like it weighs 4000lbs either, so that also helps with acceleration as well. And since it looks to be a tube framed car, I'd imagine he isn't using a stock suspension either; I'd bet its some form of adjustable coilover shock . So as Everyone has said, handling comes down to more than just tires. It is tires yes, but good tires on a 4000lb car with mushy suspension still isn't going to handle all that much better than before. But tires, I feel the widest and stickiest you can run in your application will give you the best handling. Along with other mods of course; suspension etc. Edited September 19, 2013 by R3VO 3VOM Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 19, 2013 Share Posted September 19, 2013 Don't know on the offset, but there are a bunch of threads on that subject. You might try the Z transmission calculator for tire diameter and gear selection. http://webspace.webring.com/people/cz/z_design_studio/ Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted September 19, 2013 Author Share Posted September 19, 2013 If you look at the cobbled Audi, he wasn't exactly running 145's. So a wider contact patch helps. But also, that thing doesn't look like it weighs 4000lbs either, so that also helps with acceleration as well. And since it looks to be a tube framed car, I'd imagine he isn't using a stock suspension either; I'd bet its some form of adjustable coilover shock . So as Everyone has said, handling comes down to more than just tires. It is tires yes, but good tires on a 4000lb car with mushy suspension still isn't going to handle all that much better than before. But tires, I feel the widest and stickiest you can run in your application will give you the best handling. Along with other mods of course; suspension etc. Right, but he was only running 225's, where the Turner was running something like 355's. Both had well-tuned suspensions for the hill and carried incredible speed through every corner. Both are ~1500lb cars plus fuel/driver. I guess I'm just surprised that AWD can bridge that much of a tire size gap. Don't know on the offset, but there are a bunch of threads on that subject. You might try the Z transmission calculator for tire diameter and gear selection. http://webspace.webring.com/people/cz/z_design_studio/ That's my plan as well, I just feel like I should ask for some input from more experienced people before going crazy with the widest tires I can get, and slapping overfenders under them. I want a car that I can drive quickly and effectively, not one that's bored waiting for me to figure out how to wrestle with it. Quote Link to comment Share on other sites More sharing options...
Phantom Posted September 19, 2013 Share Posted September 19, 2013 One of the things not addressed was where the specific tires on the Audi, combined with his gearing put him in his engine RPM range. If the the narrower tires were the same series as the fatter ones then the narrow tires would have been a little smaller in diameter and raised his engine RPM at any given speed. That, combined with the total greater contact area for power transmission would have helped him in the acceleration/maximum speed department. I ran a hill climb recently in my 280Z and was running 225/50-16 Dunlop Direzza's. I was faster up the hill than the twin turbo Z32's that were running wider tires. The basic reasons were: 1. It was a hill climb and the need for power is amplified. 2. I was probably 5-600 lbs lighter than the Z32's 3. I was running an LS1/T56 combo so I was always in the right gear to maintain maximum torque/HP and my torque range was huge. I was also a little crazy too so maybe that helped. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 19, 2013 Share Posted September 19, 2013 Trying to fit a wheel wider than 7" on an S30 is a pain in the ask. If you are looking to run a 225/50/15, make your life easier and limit your wheel width to 7". Zero offset or, 4.5" back spacing. Bolt it on and go. Johnc gave me this advice years ago and it has proven true. Even going to 8" has been very painful without flares. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 19, 2013 Share Posted September 19, 2013 8" wide should fit no problems with coilovers. I had 8's on mine with no flares and could have gotten more under there. I didn't even have the rear fender lips rolled. Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted September 19, 2013 Author Share Posted September 19, 2013 I have no problems whatsoever with flares, I just want to be sure that wider is actually going to be a handling improvement. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 19, 2013 Share Posted September 19, 2013 tube80z bought that yellow car. He has raced several Zs with 13" wide rears and 10" wide fronts, and was very fast. Talking with him convinced me to go 15x14's front and rear. Quote Link to comment Share on other sites More sharing options...
heavy85 Posted September 19, 2013 Share Posted September 19, 2013 Lots and lots of variables to make a conclusion on tire size especially for hillclimbs. It been my experience that hillclimb times are HIGHLY dependant on how hard the driver is willing to push. For example, my first hillclimb I beat a former Daytone 24 winner with him in his purpose built hillclimb special complete with big wings, low weight, turbo, huge slicks, etc and me in my LS1 Z on 245 STREET tires. Im not that great a driver either. Then you need to pick a tire and venue. Hillclimb need tires that work now so if your tire needs a lot of heat then smaller can be better to get them up to temp faster. If you want to put some ZG flares on, I've had much success with 245 17's. RS3's Quote Link to comment Share on other sites More sharing options...
johnc Posted September 20, 2013 Share Posted September 20, 2013 Tire compound is more important then tire width (a softer compound provides more grip). Tire temp is more important then tire width (a 205 width Hoosier R6 at 190F grips better then a 285 Hoosier R6 at 80F). Tire heat cycles are more important then tire width (a new set of scrubbed 205 Hoosier R6s grip better the a 285 Hoosier R6 with a years worth of races)... See the trend? Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 20, 2013 Share Posted September 20, 2013 (edited) Johnc, if EVERYTHING else is optimized: ( dry, clean pavement, sticker new, perfect temperature of the perfect tire compound, perfect inflation, perfect shocks and spring rate, unlimited funds, infinitely stiff chassis, infinite power and torque, perfect alignment for the venue, perfect driving ), is there a down side to trying to achieve the largest contact patch that you can? I know this is a super complex question, so I'm really asking it for the original poster in order to get him to a simple answer to a complicated question. Edited September 20, 2013 by RebekahsZ Quote Link to comment Share on other sites More sharing options...
johnc Posted September 20, 2013 Share Posted September 20, 2013 All else being equal never is. Another example: B Stock Solo2 RX8. You're limited to stock rim width. Same car, same driver. On a 18 x 8" rim the car was quicker on 245/35-18s then 285, 275, 265, 255, and 225 width tires. All the tires had an OD within 5% of each other. All testing done in the same place on the same day with retest to reduce variability. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 20, 2013 Share Posted September 20, 2013 A different test: STX Solo 2 E36 BMW. Car was tested on 245s on a 8.5" rim, 255s on a 9" rim, and 285s on a 10.5" rim. All 18s. The 285s were significantly faster then the others except for the morning test runs. The 245s were faster when it was cool. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 20, 2013 Share Posted September 20, 2013 A simple answer to a complex question is the wrong answer. Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted September 20, 2013 Author Share Posted September 20, 2013 I'm learning a lot just watching this discussion go back and forth. Johnc, if EVERYTHING else is optimized: ( dry, clean pavement, sticker new, perfect temperature of the perfect tire compound, perfect inflation, perfect shocks and spring rate, unlimited funds, infinitely stiff chassis, infinite power and torque, perfect alignment for the venue, perfect driving ), is there a down side to trying to achieve the largest contact patch that you can? I know this is a super complex question, so I'm really asking it for the original poster in order to get him to a simple answer to a complicated question. I was wary to ask this question, because I know exactly how I'd answer it if I were the one with more experience. All else being equal never is. ... just like that. So there's no simple answer, no formula that fits every car. Because our runs are ~4minutes (absolute max, that's a stock Daewoo ambling up the longest hill in the area), I think I need to focus on cool-weather temps. For now, I think my question has been answered: On a mostly-stock s30, 15x8 0 offset 225-[proper-gearing-height]-15 is acceptable. I'll have to do my own testing and fine-tuning from there. Heavy, I'm curious as to why you'd choose 17" over 15" if the widths are the same, and brakes don't demand it. I'm trying to focus on wheel width more than wheel diameter, but what's one more wrench in the equation? Quote Link to comment Share on other sites More sharing options...
