richie2619 Posted February 17, 2014 Share Posted February 17, 2014 I'm sure there are folks who have info like this already but I wanted to share something I found. lantech.com has sleeves that are 12mm od 10mm id and 10mm long. p/n 000457A I based that on an 11mm thick flange for mounting the ring gear. If the flange is thinner than that, p/n 000456A is the same as above but 8mm long. Quote Link to comment Share on other sites More sharing options...
richie2619 Posted February 17, 2014 Author Share Posted February 17, 2014 On 2/17/2014 at 5:36 AM, richie2619 said: I'm sure there are folks who have info like this already but I wanted to share something I found. lantech.com has sleeves that are 12mm od 10mm id and 10mm long. p/n 000457A I based that on an 11mm thick flange for mounting the ring gear. If the flange is thinner than that, p/n 000456A is the same as above but 8mm long. https://order.lantech.com/parts_list_details.aspx?ident=000457A Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted February 18, 2014 Share Posted February 18, 2014 Wow, nice find. Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted February 18, 2014 Share Posted February 18, 2014 Wish I had seen this when Mcmaster & Carr told me they couldn't sell me a private order to Canada. I ended up making my own spacers by cutting ribbons of 20 ga. sheet metal and heating and rolling them into sleeves. It was hateful. Quote Link to comment Share on other sites More sharing options...
NewZed Posted February 18, 2014 Share Posted February 18, 2014 If you search around you'll find that some of the pros say they're not even necessary. Clamping force is key. The ring gear should never slip at all, so the bushings/shims/space fillers should never feel a thing. Quote Link to comment Share on other sites More sharing options...
richie2619 Posted February 18, 2014 Author Share Posted February 18, 2014 I'd like to think that's true. Something about throwing 400 lb ft of torque at it makes me feel that it's got to shift. Especially with 10in wide tires. At 2 bucks a piece, I'll have more peace of mind. I promise you I've wasted $20 on worse! Quote Link to comment Share on other sites More sharing options...
johnc Posted February 19, 2014 Share Posted February 19, 2014 I don't know why this is so hard for some folks...http://metric-steel.spahrmetric.com/item/tubing/metric-round-tubing/019508-12-01-010-0 http://www.speedymetals.com/pc-3411-8242-12-od-x-0035-wall-dom-steel-tube.aspx http://www.onlinemetals.com/merchant.cfm?pid=466&step=4&showunits=inches&id=19&top_cat=1 Quote Link to comment Share on other sites More sharing options...
richie2619 Posted February 19, 2014 Author Share Posted February 19, 2014 Maybe because I wasn't born with this information in my head. Quote Link to comment Share on other sites More sharing options...
johnc Posted February 19, 2014 Share Posted February 19, 2014 Neither was I. There's this thing called Google that helps you find things. Works very well. Try it some day. Quote Link to comment Share on other sites More sharing options...
richie2619 Posted February 19, 2014 Author Share Posted February 19, 2014 Thank you. Quote Link to comment Share on other sites More sharing options...
