King's Evil Posted March 25, 2014 Share Posted March 25, 2014 Hey guys, been a while that I been off on the forums, but I am back. I been working in on this Z and this girl isn't stock anymore. I got a pair of 2" wheel spacers for the front to widen my track width because I installed a complete 87 C4 Corvette rear ifs into my Z. The front studs are not long enough, the spacer lug bolts are only grabbing a quarter of the threads, that will worries me if I drive it like that. Can anyone point out where I can get a set of correct 2" studs for the stock hub? Sorry if this a basic question, I just want to get the right stuff when it come to wheels. Here's some picture of my Z for your troubles. Thanks! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 25, 2014 Share Posted March 25, 2014 Shouldn't you have a longer than 2" stud if you're using a 2" spacer? Quote Link to comment Share on other sites More sharing options...
King's Evil Posted March 25, 2014 Author Share Posted March 25, 2014 Hoping it can be flush or more inside the adapture,if it sticks out I can always grind some length off. I can go with 1.75 studs. Just hoping someone can point me out where to get correct long studs. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 25, 2014 Share Posted March 25, 2014 ARP 2.5" studs from a Camaro or 2nd gen RX7 fit, but they have 12x1.5mm threads. Quest vans are a little shorter and have 12x1.25mm threads. I'm sure you can find part numbers with a search. Quote Link to comment Share on other sites More sharing options...
mal_tiempo Posted March 25, 2014 Share Posted March 25, 2014 Just went and looked at my set, the ARP studs are "Late Model GM", ARP part number 100-7708. Quote Link to comment Share on other sites More sharing options...
King's Evil Posted March 25, 2014 Author Share Posted March 25, 2014 On 3/25/2014 at 9:24 PM, mal_tiempo said: Just went and looked at my set, the ARP studs are "Late Model GM", ARP part number 100-7708. Thanks guys! Just what I need, I just need to pop those old ones out and put these in, I was hoping to keep it 12x 1.25. Oh well as long they press in nice and tight then I'm happy. Hey mal-tiempo, when they are pressed into the hub how long they come out? Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 26, 2014 Share Posted March 26, 2014 Buy the NISMO long Stud Kit for a 350Z... So you get 20 studs instead of 16... PFFFT! Maybe you need spares if something breaks , right? That's what I used on my S30 Courtesy Nissan likely ships to your door. 1.25 thread pitch... Drops (presses) right in! Quote Link to comment Share on other sites More sharing options...
duragg Posted March 26, 2014 Share Posted March 26, 2014 (edited) /\ Tony has good point. I did the M12 x 1.5 ARP studs and finding suitable lug nuts was a PITA. I needed small O.D. With external splines and open ends and the M12x1.25 would have been easier to source. Edited March 26, 2014 by duragg Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 26, 2014 Share Posted March 26, 2014 (edited) 12x1.5 is a more common size than 12x1.25. Toyota, Mazda, I believe Mitsubishi, the Camaro, etc all use this size. You can buy generic lug nuts for both sizes at the auto parts store. I just bought some for my Miata when I took the wheel locks off. Not a problem. You can get aluminum splined nuts for Miatas all over the place. Edited March 26, 2014 by JMortensen Quote Link to comment Share on other sites More sharing options...
osirus9 Posted March 26, 2014 Share Posted March 26, 2014 You can get any kind of lug nuts you want from here: http://www.gorilla-auto.com/ Also, thanks for the tip on the NISMO 350Z long stud kit Tony. I'll be going with that if I need longer studs in the future since then I won't have to buy new lugs. Quote Link to comment Share on other sites More sharing options...
duragg Posted March 26, 2014 Share Posted March 26, 2014 For whatever reason, finding m12*1.5 in the exact thing I needed was a challenge. Comically so. Maybe its an Arizona thing. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted March 26, 2014 Share Posted March 26, 2014 A note for anybody putting extended studs in an aluminum spacer/adapter. Use the washer and nut method to PULL the studs in. I recently pressed some in and they went in a little crooked. Not a problem going I to steel-just a few taps with a rubber dead blow to align them. But the steel studs smoosh the aluminum and you trash the spacers if they go in the least bit crooked. NEXT time, I'm gonna pull em in. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 27, 2014 Share Posted March 27, 2014 If you pull, use a torque wrench (beam indicating deflection pointer style) to monitor your turning torque. It's easy to overdo it and pass the stretch limit of the stud and that just sets up a lugnut and broken stud flying off someplace! Quote Link to comment Share on other sites More sharing options...
mal_tiempo Posted March 27, 2014 Share Posted March 27, 2014 On 3/25/2014 at 10:22 PM, King's Evil said: Hey mal-tiempo, when they are pressed into the hub how long they come out? No idea, they are still sitting on the floor in my pile o' parts. Sorry Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted March 28, 2014 Share Posted March 28, 2014 (edited) I used S14 studs as they were available at the local parts store, and if memory serves me correct, they were 42mm in length, plenty for the 8mm spacers I was running, not sure if they'd cut it for your bolt in spacers. I was actually in search of a certain year, I believe rear Nissan quest stud which I believe is the longest OEM 12x1.25 thread stud that fits our hubs,and comes in somewhere around 50mm/2". They weren't available local to me, but if you don't live on an desolate island in the North Atlantic you could probably find them at your local parts store/dealer. Edited March 31, 2014 by m1ghtymaxXx Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 31, 2014 Share Posted March 31, 2014 OEM thread size is M12-1.25, that goes for the Quest as well. 1.5 as stated previously is for Toyota's and other ilk. Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted March 31, 2014 Share Posted March 31, 2014 On 3/31/2014 at 7:09 AM, Tony D said: OEM thread size is M12-1.25, that goes for the Quest as well. 1.5 as stated previously is for Toyota's and other ilk. Woops, just a typo! meant 1.25 Quote Link to comment Share on other sites More sharing options...
Chris Duncan Posted May 29, 2014 Share Posted May 29, 2014 I just bought some Quest studs. They are 45mm. Napa part # NOE 641-2785 Is there anything longer out there? I need about 55mm Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 29, 2014 Share Posted May 29, 2014 ARP 2.5" is 63.5mm, but you'll need the 1.5mm lug nuts. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 30, 2014 Share Posted May 30, 2014 On 5/29/2014 at 1:33 AM, Chris Duncan said: I just bought some Quest studs. They are 45mm. Napa part # NOE 641-2785 Is there anything longer out there? I need about 55mm That was covered in Post #7 Quote Link to comment Share on other sites More sharing options...
