Fiberglass fender identification
I'm pretty sure those are Not subtle z front flares due to a few reasons. Subtle z fronts do not come with side light provisions, and they start to ramp outward directly from the corner in front of the door to the wheel tub to add 1.5" of flare. From your provided pictures it appears that the side of the fender follows the stock flat sided lines until you get to the wheel tub/ mud flap. Here are a few pics of mine and also another members completed car with the subtle z kit.
Holes not pre-existing in panels is not really a gold-standard of identification on a finished vehicle.
Fairlady Z's didn't have rear marker lights and if you federalize properly, afterwards they do!
I'd be more prone to look at contours of the two with similar reference objects in sight (like lug bolt pattern) so you can make a scaling grid and compare.
People always wonder why the iPhone is sitting on this  or that in my Nikon-Taken Photographs. Because it is high-contrast object with a defined edge, and with a given screen illuminated has a nice scaleable grid on it. Makes for reconstructing field piping and the like very easy. Same goes for fenders and their contours.
