nzarano Posted November 13, 2014 Share Posted November 13, 2014 has anyone ever used one of those efi conversions for a four barrel carb on an l28? something like this http://www.jeep4x4center.com/tbi-kit-emissions-legal-304-360-401-v8-k247jpv8.html http://hamiltonfuelinjection.com/products/1-throttle-body-injection-kit.aspx Quote Link to comment Share on other sites More sharing options...
nzarano Posted November 13, 2014 Author Share Posted November 13, 2014 the main reason being having an l28 bored in a 240z and avoiding having to deal with wiring up an efi harness Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 13, 2014 Share Posted November 13, 2014 Both of those options still use wires that need to be connected. You only save like four or five injectors worth of wire. Why don't you just go mechanical? http://www.arizonazcar.com/manifold.html Quote Link to comment Share on other sites More sharing options...
nzarano Posted November 13, 2014 Author Share Posted November 13, 2014 for cold starts and if i change anything on the engine it adjusts so theres no need to keep fidling with carbs... Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 13, 2014 Share Posted November 13, 2014 you cant have efi without wiring. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted November 13, 2014 Share Posted November 13, 2014 (edited) Wow that first kit is expensive. If you already have the 4bbl intake you could just get the tb from a salvage yard and a megasquirt kit and use and adapter to fit the tb to the intake. Also need an electric fuel pump that provides 13 psi. Edited November 13, 2014 by skirkland1980 Quote Link to comment Share on other sites More sharing options...
Tony D Posted November 14, 2014 Share Posted November 14, 2014 Yes, since at least 1991... Next question? Quote Link to comment Share on other sites More sharing options...
280zex Posted November 17, 2014 Share Posted November 17, 2014 If you are capable of doing your own wrenching and modification, you could go get a CIS fuel delivery system from a1980's model VW and retro fit an old 4 bbl carb to fit the injectors. Even better if you found the right parts for cheap is find the old dual carb intake for the z, get 2 throttle bodies of the right size and retrofit the VW injection system to that. The stock VW CIS injection system is simple mechanical injection, and uses NO computer. Stock it is capable of supporting 200 engine HP. Even better is that Volvo had the same system but has 6 injectors instead of 4, so did older Ferrari sports cars. The CIS mechanical fuel injection system is the easiest fuel injection system in the world to work with. Quote Link to comment Share on other sites More sharing options...
z-ya Posted November 21, 2014 Share Posted November 21, 2014 The other option is to get a GM TBI setup. You may have to make an adapter plate, but it would make a nice setup. When I built my superchaged setup a while back I used a TB from a Jeep and an adapter plate. I welded injector bosses in the manifold. It worked great until I melted some pistons on the track. Quote Link to comment Share on other sites More sharing options...
280zex Posted November 21, 2014 Share Posted November 21, 2014 (edited) On 11/21/2014 at 2:54 PM, z-ya said: The other option is to get a GM TBI setup. You may have to make an adapter plate, but it would make a nice setup. When I built my superchaged setup a while back I used a TB from a Jeep and an adapter plate. I welded injector bosses in the manifold. It worked great until I melted some pistons on the track. I was wondering what happened to that setup of yours..... Edited November 21, 2014 by 280zex Quote Link to comment Share on other sites More sharing options...
z-ya Posted November 21, 2014 Share Posted November 21, 2014 Yea, no easy way to intercool. IATs we getting close to 300F. The SC was so loud, you couldn't hear the detonation. Melted ring lands. Quote Link to comment Share on other sites More sharing options...
Tony D Posted November 22, 2014 Share Posted November 22, 2014 Pete, you just got greedy! Quote Link to comment Share on other sites More sharing options...
Project1 Posted January 3, 2015 Share Posted January 3, 2015 I use to use the TBI inject, that exact howel kit, on a jeep I had. It worked really well. The carb I had was very hard to keep tuned because of the ethanol in the gas is not always consistant. Quote Link to comment Share on other sites More sharing options...
