C6 Corvette Oil Pan
I'm sure somebody has done this but I tried to search and didn't find anything.
Has anybody ever used an oil pan from an LS2 or LS3 C6 Corvette?
The C6 pan is over an inch shorter at the front of the sump and looks a lot better.  Also it has some decent baffling built right in.
F-Body & C6 Corvette:
  • Replies 49
Thanks for the pictures!
I can see that the bell housing actually hangs a little lower than the back of the pan.  Ever consider trimming the bell housing for maximum ground clearance?  Probably not necessary either way.
Got any other pictures?
I am also running the same oil pan With JCI mounts on a 280. Take note that you cannot remove and install this oil pan unless you lift the motor a bit. Also I made a "plow" on mine protect the pan and anything else. I previously hit some dried concrete in the road that took my pan out... That's not going to happen again I assure you.
B6A8F359-502A-4ECF-81E2-7E1AF593E28A_zps
  • 4 months later...
Has anyone tried the performance GM swap pan kit? Big cost difference with them and just curious if they work.
Muscle car swap pan kit - 179.99
http://dirtydingo.com/store/product_info.php?cPath=1_356&products_id=1461
Fbody Pan swap kit - 329.99
http://dirtydingo.com/store/product_info.php?cPath=1_356&products_id=1450
Top pan is the muscle car swap pan the bottom is the Fbody pan.
Why not just buy a used F-body pan? They are pretty cheap on LS1 Tech all the time
It seems the marine place is out of stock, but the LS2-3 pan is 276 at GMPD
http://www.improvedracing.com/tech/LS-oil-pan-dimensions.php
Part Numbers -
Oil pan:12624617 276.95
Pickup tube:12624497 32.71
Windage tray:12558189 17.21
Dip stick:12570788 12.64
Dip stick tube:12570787 12.59
Pickup tube o-ring:12557752 3.87
Gasket:12612350 25.63
Total comes out to 381.60 for a complete and brand new oil pan... If thats the route you'd like. I'm a junkyard builder so I'll hold out to save a buck, but if you need it... GMPD usually has everything in stock.
Edited by MrPhotographer06
