trackzpeed Posted August 26, 2015 Author Share Posted August 26, 2015 A little more work last night. Both headers bolted up and done... the drivers side slipped in easy from underneath once the steering rod was removed. Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted August 27, 2015 Author Share Posted August 27, 2015 Pics of the driver header and the current low hanging fruit..... The headers and oil pan hang just a hair below the cross member.... My car is lowered about 1.5-2 inches. Pretty pleased so far. Quote Link to comment Share on other sites More sharing options...
Richard Oben Posted August 28, 2015 Share Posted August 28, 2015 With them there (as opposed to further back) most driveways and speed bumps should not be an issue. I do not have any marks on my cross member but the exhaust has a few scrapes on my other car. I know you have had initial remorse for the CXR kit do you still? I am still leaning that way, I guess we will know more when you get it fired up and the exhaust is on. Nice work, Richard. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted August 28, 2015 Share Posted August 28, 2015 What size headers are they? Quote Link to comment Share on other sites More sharing options...
crapforum Posted August 29, 2015 Share Posted August 29, 2015 Hurry up and finish that thing, you have no idea what your missing out on yet! Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted August 30, 2015 Author Share Posted August 30, 2015 Richard, No regrets so far.... Zfan, 1.65 od stainless longtubes to 3" collectors, came with kit More progress Crapforum..... the batteries are dead in my magic wand or I'd be driving now LOL. Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted September 8, 2015 Author Share Posted September 8, 2015 fuel system is complete, Rad hoses and drive belt on.... drive line, exhaust and wiring to go..... Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted September 16, 2015 Author Share Posted September 16, 2015 (edited) I need a little help/advise.... How do I hook up water temp to the stock Datsun Gauge???? I drilled and tapped the top of the water pump for the steam vent, and there is enough room to put the Datsun sending unit there as well, but im looking for a better/proven option. Thanks, Jim Edited September 16, 2015 by trackzpeed Quote Link to comment Share on other sites More sharing options...
Richard Oben Posted September 17, 2015 Share Posted September 17, 2015 Pull the port on the other side of the engine in the head if there is room for the sender behind the header. Or there are companies (speedway?) that made adapters to fit the temp on the block by the crank sensor I think, either way it is under the head. HTH, Richard. Quote Link to comment Share on other sites More sharing options...
alainburon Posted September 17, 2015 Share Posted September 17, 2015 I think I may still have the JCI adapter for the water sending unit. It puts the sending unit in the block. Let me know if you want it and I can look for it. You can have it at no charge. Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted September 18, 2015 Author Share Posted September 18, 2015 Yes thanks I would love that. Ill send you a PM with may address. Thanks again. Jim Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted September 18, 2015 Author Share Posted September 18, 2015 PICK UP MY DRIVELINE TODAY..... MORE PROGRESS PICS COMING SOON. Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted September 22, 2015 Author Share Posted September 22, 2015 Here is the shot of where I tapped for my steam vent..... I'm going to try and use the port on the passenger side head for water temp sending unit... JTR has a 1/2 and 3/8 NPT adapter for the Datsun sending unit, will either of these fit in that port? Thanks guys. Quote Link to comment Share on other sites More sharing options...
CableSrv Posted September 22, 2015 Share Posted September 22, 2015 did you take the waterpump off before you drilled and tapped? or is there some way to not get metal shavings in the radiator flow? Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted September 22, 2015 Author Share Posted September 22, 2015 I started with it dry as a bone and drilled a tiny pilot hole.... use compressed air with lg bit to keep chips out until just before I started to break through then pulled the axle grease method on the drill and tap to keep it clean. going super hand slow with the drill helps alot as the housing peels off versus chips and is easy to manage. I'm confident I kept her clean.... Quote Link to comment Share on other sites More sharing options...
Fullauto Posted September 22, 2015 Share Posted September 22, 2015 Jim, Domsz had a thread on the stock sending unit. I followed his advice and threaded the sending Unit ..brass so really easy.. Then scrwed it right into the head.... Quote Link to comment Share on other sites More sharing options...
Fullauto Posted September 22, 2015 Share Posted September 22, 2015 Btw have you drilled your tunnel holes yet, Im about to test fit the motor n tranny for first time. Wondering if everthing still lining up really well Im cx kit too. Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted September 23, 2015 Author Share Posted September 23, 2015 The sending unit threading is brilliant! that will be up next. I have not drilled out the tunnel mounts yet since I was waiting to get my driveline in to check for angulation. It all looks pretty good so the mounts will be done this weekend as well. Thanks for the water temp sender suggestion. Jim Quote Link to comment Share on other sites More sharing options...
CableSrv Posted September 23, 2015 Share Posted September 23, 2015 I bought both the water temp and oil temp brass adapters.. the oil will NOT work with normal oil pressure senders as the intake manifold is in the way. However the 12x1.25 brass adaptor for the water worked perfect for my gauges. I ended up using the aluminum bracket by the oil filter and drilling and tapping that for my oil pressure sender. Doing this tho... meant I had to dent my header as it was slightly in the way. Quote Link to comment Share on other sites More sharing options...
Fullauto Posted September 24, 2015 Share Posted September 24, 2015 Thx Jim, on my stock oil sending unit im using an adaptor then a 12 inch 3an braided line then ill mount the stock sender on the Firewall.....havent seen this done but might look kinds cool. Kinda of a remote sending unit no clearance issues then.. Quote Link to comment Share on other sites More sharing options...
