Major electrically problem
Start by checking all of your ground connections in the electrical system. Check your chassis ground, engine ground, etc. Also just because the battery shows 12v doesn't mean it is any good you need to load test it to make sure it can support the all-star draw of the stater. Almost 90% of electrical problems are a bad ground connection. GL
later i came back out (several hours later) and turned the key and IT TURNED OVER. still no lights or fuel pump or injectors worked. BUT THE CAR WOULD RUN OFF STARTER FLUID.
You can use the small diagrams in various chapters from the Post #6 link, or this giant one - http://www.atlanticz.ca/zclub/techtips/wiringdiagrams/78_280Z_wiring.pdf
At least you have a meter.  You could have used it to determine that you had power to the coil, for example, beofre using the starting fluid.
You have the basic tools, and some knowledge.  You just need to use it in an orderly fashion.  Instead of checking the relays, check what they power, for example.  If it doesn't have power, check the relay power source (the ignition switch for example, or the power wire to the EFI system at the battery terminal with its green fusible link), then check the relay.  You'll be surprised how easy it was when you find the one thing that wasn't getting power that should have been.
I noticed that when the key is turned no power is drawn (according to the voltmeter), it that ignition or ignition relat ?
the problem was the interior relay ( two relays, 4 prong relays, that connect to the fuse block) and then i had a bad ground to the ecu.
After reading the FSM several times i was able to figure it out.
Edited by McGruber21
Congratulations.  You're ahead by -10 days.
