Dat73z Posted September 30, 2015 Author Share Posted September 30, 2015 CableSrv, absolutely impressed with the level of quality and detail in that install! Likewise can't wait for the final results video. Thanks to all for weighing in, a lot of great points to think about and consider. Quote Link to comment Share on other sites More sharing options...
Jay Gadsby Posted September 30, 2015 Share Posted September 30, 2015 I concur, great job so far on the install and documentation as well. Looking forward to seeing it finished. Quote Link to comment Share on other sites More sharing options...
greghassen Posted October 1, 2015 Share Posted October 1, 2015 (edited) Shouldn't you put silicone on the bolts holes that you drilled? The other side is wet when it rains? Edited October 1, 2015 by greghassen Quote Link to comment Share on other sites More sharing options...
CableSrv Posted October 1, 2015 Share Posted October 1, 2015 https://www.youtube.com/watch?v=iVmc9SGwGR4with it running! mind you I still don't have a center vent and not sure what I'm going to do about that yet.Greghassen: absolutely correct!!! once It's finished I'll be taking it apart and making sure all is nice and cable maintenced up and silicon that so no leaks as well as close up my original outside vent. Quote Link to comment Share on other sites More sharing options...
socorob Posted October 1, 2015 Share Posted October 1, 2015 (edited) Do not use clear silicon on metal painted surfaces! Use adhesive caulk or some other sealer that is paint friendly. Bad place for screwing, make sure you use stainless hardware and seal it well, that's already a problem spot in a lot of early Zs I have seen around the southeast. It would be better to use one of the screws in the cabin nissan already has in place. They did that so as not to have a hole in the bottom of the sump. Not trying to bust your balls, but would hate to see you have to pull all that out a year or so down the road because its leaking and or rusting out. Edited October 1, 2015 by socorob Quote Link to comment Share on other sites More sharing options...
Derek Posted October 1, 2015 Share Posted October 1, 2015 Here is what I did for my center vents. Made a world of difference. http://forums.hybridz.org/topic/81658-dereks-custom-dash-work/ Quote Link to comment Share on other sites More sharing options...
socorob Posted October 1, 2015 Share Posted October 1, 2015 I had a 280 so what I did was take the front parts with the vents, glued with heavy body abs glue a piece of flat abs on the back. The center outlet on vintage air is 3" I think. I need a 45 bend so I went to Lowe's plumbing section and got a 45 abs plumbing elbow that had a 3" OD. Drilled a 3" hole in the flat piece I put on the back where I needed it to be so the hose was as straight as possible, and glued the elbow over the hole.tons of air goes thru it. Quote Link to comment Share on other sites More sharing options...
CableSrv Posted October 1, 2015 Share Posted October 1, 2015 I ordered this for the center vent.. http://www.ebay.com/itm/141784001294?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT we'll see how well it works. Socorob, as for the screws, I agree they are all Stainless steel and I will be using a sealing caulk. I do remember reading years back on having silicon on the paint and it destroying it. Once she's ready for a final assembly I will use some rubber washers as well as some sealing caulk on both sides. Quote Link to comment Share on other sites More sharing options...
