BLOZ UP Posted June 22, 2016 Share Posted June 22, 2016 How do you get so much done... I'm a year into my wife's VG30DETT rebuild.... Quote Link to comment Share on other sites More sharing options...
JoeK Posted June 23, 2016 Share Posted June 23, 2016 I sure wish I could build my exhaust while the car was still on the rotisserie. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 23, 2016 Author Share Posted June 23, 2016 Ha, I don't exactly know. To be honest I have been neglecting quite a few other things to get the car "complete". Having a dyno tune day set really is making me feel crunched for time but it helps to have a goal or a deadline. If you have kids and wife I understand. Family always comes first! How do you get so much done... I'm a year into my wife's VG30DETT rebuild.... Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 23, 2016 Author Share Posted June 23, 2016 JoeK, if you can still do it somehow, I would suggest it. My shoulders hurt from crawling in and out from under the car for days. I can't imagine doing this 30 years down the road! I sure wish I could build my exhaust while the car was still on the rotisserie. Quote Link to comment Share on other sites More sharing options...
bramagedained Posted June 24, 2016 Share Posted June 24, 2016 PM me the date/time(I assume still the 11th) for your dyno appointment at DB. I'd like to come watch/hang out if you don't mind. Quote Link to comment Share on other sites More sharing options...
JoeK Posted June 24, 2016 Share Posted June 24, 2016 If I had one of those plastic mockup engines, and a mockup trans, I'd probably go for it. Speedway motors has damaged mockup block right now for $200, but I can't find a T56 mockup and just finished putting all the internals back in mine. Wish I'd thought of it a couple weeks ago. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 24, 2016 Author Share Posted June 24, 2016 Will do sir! I am pretty excited and relieved at the same time. After that day, things should slow down a bit. But who knows what other wild hair I might have by then. PM me the date/time(I assume still the 11th) for your dyno appointment at DB. I'd like to come watch/hang out if you don't mind. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 24, 2016 Author Share Posted June 24, 2016 When I see people using mockup engine and trannies I get pretty jealous. If you got your motor rebuild, could you still spring for the mock up engine and find a tranny somewhere? If I had one of those plastic mockup engines, and a mockup trans, I'd probably go for it. Speedway motors has damaged mockup block right now for $200, but I can't find a T56 mockup and just finished putting all the internals back in mine. Wish I'd thought of it a couple weeks ago. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 24, 2016 Author Share Posted June 24, 2016 I wrapped up the exhaust tonight and took it out for a good hour or so. Man does it sound good! I am used to H pipes but this X makes it sound like nascar over here! I am very happy with the fact there is very little rasp and no drone at all. I just need someone else to drive the car so I can hear how it really sounds. It is QUITE a bit more mellow than open headers thank god. I checked yesterday and also again today and I think I am exhaust leak free. I will look for some black sooting after a few hundred miles and fix it from there. I just wanted to fix any leaks prior to scuffing and hi temp painting. Gonna take the car to work tomorrow Quote Link to comment Share on other sites More sharing options...
JoeK Posted June 24, 2016 Share Posted June 24, 2016 Finding a tranny somewhere would be the hard part. T56's are like gold these days, broken ones fetching over 1k. I'll be giving some thought to the idea of taking the trans apart again, probably 5 hours work but seems like it would be worthwhile to do the exhaust without having to climb under the car 50+ times. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 24, 2016 Author Share Posted June 24, 2016 I didn't know broken ones were going for so much. And I guess who knows what internal damage may lie in there.... If I were you I'd put it in and deal with climbing in and out a bagillion times. 5 hours would get most of the exhaust work done But again, I'm 28 and feel pretty spry yet! Finding a tranny somewhere would be the hard part. T56's are like gold these days, broken ones fetching over 1k. I'll be giving some thought to the idea of taking the trans apart again, probably 5 hours work but seems like it would be worthwhile to do the exhaust without having to climb under the car 50+ times. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 24, 2016 Author Share Posted June 24, 2016 Kind of thinking about porting the stock intake and throttle body before the dyno now. Seems pretty simple. Might see gains with the intake and better throttle response with the TB. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 24, 2016 Author Share Posted June 24, 2016 The rest of the exhaust was pretty straight forward with not too much complexity. I felt I did a better job on the mid pipe though. I took the U/180 deg. bend pipe and cut it in half. These got tacked on to the mufflers and had the perfect clearance for the diff mount and gas tank. Then a 90 deg. bend pipe was shortedned on one end and lengthened on the tailpipe side to get it all to line up. The great part is the mounts I got from Summit months ago at the EXACT height I need to mount the end. The stock mounting location on the drive side was utilized and some angle iron was used for the other side. The only down side if the pipes are not exactly level/parallel with the ground. The tips gave me enough leeway to get them close to parallel. The tips are nice and even and don't look kittywampus! What really turns me on is how easy the full system is to drop and install! It literally is 2 nuts and 2 V band clamps to remove the back half. Then 2 more V band clamps for the mid pipe. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted June 24, 2016 Share Posted June 24, 2016 How loud is it? My truck is so loud with long-tube headers and a single 3" that I have to turn the truck off at drive-thru windows. What you have there looks pretty dang loud! Quote Link to comment Share on other sites More sharing options...
bramagedained Posted June 25, 2016 Share Posted June 25, 2016 I bet loud. I have two bullet mufflers(which admittedly are not much for mufflers) on the header collectors and two summit turbo mufflers at the back in the stock location and it's fairly loud. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted June 25, 2016 Share Posted June 25, 2016 Looks reeel good. A+ man. Quote Link to comment Share on other sites More sharing options...
tim.d Posted June 25, 2016 Share Posted June 25, 2016 What size tips are those? Quote Link to comment Share on other sites More sharing options...
~KnuckleDuster~ Posted June 25, 2016 Share Posted June 25, 2016 Looks great can't wait to hear the exhaust. I really like the all black rbr's.. Quote Link to comment Share on other sites More sharing options...
Boben Posted June 26, 2016 Share Posted June 26, 2016 Could you post up a video of the sounds. Looks very nice, but probably loud. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted June 26, 2016 Author Share Posted June 26, 2016 Hey guys thanks for the kind words! Ive been out of town so far this weekend but I'll be sure to get some videos for you guys. Overall, its really mellow at idle and while shifting prior to 2k. Its only loud when you get on it. I think its a perfect midway. Quote Link to comment Share on other sites More sharing options...
