toolman Posted July 24, 2025 Author Share Posted July 24, 2025 (edited) Finishing Details of the Super Duty 8.8 Conversion- Strut Spring Tubes- The Threaded Strut Tubes were obtained from BC RACING. If you don't have a TIG WELDER, Vladmir can weld his Strut Tubes Brackets on. BC RACING STRUT TUBES STRUT TUBES with Brackets WELDED ON After installing the Complete Strut Assemblies with Coil Springs and car on the ground, you can adjust the Spring Preload and Spring Height. Adjust the Spring Height to your preference. Double check Wheel to Body Clearance by testing the suspension under various road conditions. Exhaust System Modifications- I raise the Dual Exhaust Pipes for extra clearance(Speed Bumps, etc), REAR EXHAUST PIPES also, had to widen to accommodate the Wider 8.8 FORD DIFFERETIAL. l Rear View of Exhaust System Bottom View of 2024Ford Motorsport Super Duty 8.8 Differential with Torsen Limited Slip with 3.55 Gears. Right Side View of the Differential -note the Huge Axle Shaft capable of handling 800+ HP!! Pic of Right Side Rotor and Mustang GT Disc Brakes. Mounted also is 1" Wheel Spacers to provide Caliper/ Wheel Clearance. . Bottom View of the Differential Side View of Converted 5 Lug 17" x 11 1/2" wide Wheel with Extra Long Lug Nuts and 315 Nitto Tires. Rear to Front View of Tire and Wheel with Rocket Bunny Flare. Road Test and Comments-Next Edited August 2, 2025 by toolman Quote Link to comment Share on other sites More sharing options...
toolman Posted August 19, 2025 Author Share Posted August 19, 2025 (edited) Road Test and -Comments- The Firsr Road Test after the 8.8 Conversion went Fine. Normally, the car under under hard acceleration, a Shift into Secong Gear would cause the Right Side to break loose and the Rear End would start to come around. So I would have to back off the throttle or risk a Spin Out. With Torsen Gear, the torque was applied smoothly and evenly. The car handles well and controllable. However, when I returned to my garage and check underside of the car, I noticed a trail of grease above the Left Rear CV Axle. This grease trail was directly over the Left Inner CV Joint. So I jacked up the rear of the car, Removed the Left Inner CV Axle. After inspecting the CV Axle , I found a Small Tear in the CV Booot. The Hole was under the CV Boot Clamp so I figured the person who assembled the CV Axle must have cut it The bigger problem was finding a replacement CV Boot. I tried my local Ford Dealer, NAPA, OReilys, Auto Zone, Rock Auto and even Ebay. Nobody had it. Then, I remembered those Universal CV Axle Boots that allowed the mechanic to replace the Damaged CV Boots without completely removing the CV Axle. It saved the mechanic alot of Labor Hours. Those boots were pretty universal. An inventory of 4 to 5 these Universal Boots would fit many Front Wheel Drive Cars and even ATV. Even Snap On sold these Universal CV Axle Boots. Afrer Removing the Rubber Boot by taking the Boot Clamps off, You just remove the Large Snap Ring. Then remove the CV Joint. Once the CV Joint was removed, The Universal Boot was installed by stretching the boot over the axle. I just cut the bottom section of a oil funnel. With a little muscle, pull the Boot over the axle using the funnel to make it easier. The messy part was put the CV Axel Grease into the new boot. Finally , install both CV Clamps. Then, take the car for another road test to check for any leakage. Edited August 31, 2025 by toolman text and pic Quote Link to comment Share on other sites More sharing options...
toolman Posted September 1, 2025 Author Share Posted September 1, 2025 (edited) The Follow Up Road Test went fine. There was no CV Axle Grease leak and the Diffferential performed well. The Differential Gear Ratio was now 3:55 compared to the old r200 3:70 so my shift points were now more spread out. I think that 3:55 gear ratio for city driving by providing less gear shifting. Highway driving was better by running at less RPMs too. The Blue Angels-the Navy Stunt F16 planes were coming to participate in an Air Show at Kaneohe Marine Base. There also had a Car Show along with the Two Day Air Show. Although, the show was on the other side of my island , I decided to enter my 240z in the Car Show. The trip would take about one Hour but most of it was on freeway roads. The Freeway would take me over the mountain to the other side of my island. On the downward leg of the trip, I noticed that a lot of pedal effort was necessary to slow down, My conclusion was that a Bigger Brake Power booster would be needed. The OEM Brake Booster was 7" booster so the next size booster would be 1978 280z booster which is 8 !/2". The local auto places did not have a 280Z booster available so I ordered one from Z Depot. The Air Show was terrific but unfortunately, it create a large Traffic problem. However, The Good News is that I won the TOP TEN Trophy for Aloha Mother Fest 2025 -CAR Show that was combined with the Blue Angel Show. Next- Upgrading the 7" OEM Booster with the 78280z 8 1/2"Brake Booster Next-Upgrading the Brake Power Booster with a 78 280Z Unit Edited September 3, 2025 by toolman text correction and pics 1 Quote Link to comment Share on other sites More sharing options...
toolman Posted October 5, 2025 Author Share Posted October 5, 2025 (edited) Upgrading with a 8 1/2" Power Brake Booster Sorry for the delayed posting, I was doing renovations on my house. I am upgrading my 7 1/2"with a larger 8 !/2"Power Brake Booster. When I added the 8.8 Super Duty Differential Conversion, the Large Discs Brakes called for a Larger Brake Booster to be added. I bought the booster from Z Depot as my local parts supplies did not have in stock. Comparison Pics of the 7 1/2" and 8 1/2" Boosters As you see with these pics, the Mounting Lugs are spread out more than the old one. Roughly about 3/4" or 1 1/2" across. Luckly, the Brake Master Cylinder Assembly does not required disconnecting the brake lines. You can just loose the brake line mounts and Proportioning Valve Assembly. This will allow the removal of the old booster and room to install the new one. Now, plenty of room to work on the Booster Mounting Holes is available. However, I found that making the wider mounting holes would occur close to edge of the Brake Pedal Assembly on the opposite side of the Firewall. So instead of just putting large washers in would not be strong enough. So I decided I would remove the Brake Pedal Assembly and would weld up some steel plate on the pedal assembly to give it more strength. First, I made a Template for a Rubber Gasket behind the Booster Body. Then, Cut the gasket from a !/8" Flat Rubber Sheet. Masking tape applied on Rubber gasket material Test Fitting the Gasket. Rubber Gasket on Booster I decided that it was better to removed the Brake Pedal Assembly to work on it. So I had to remove the Steering Column and Electric Power Steering Motor together. So I constructed a 4 Foot x 1 x 1/2" Foot Plywood Platform so I could work easier than bending my back on the rocker panel. Also, to remove the Brake Pedal Assembly, there are Two 12mm short Hex bolts on the top of the assembly. To remove these bolts, you must remove the Tachometer to access these bolts. There is only a couple of inches of space above the bolts so 12mm Ratcheting wrench or small Ratchet is recommended. the Two Hidden Bolts 12mm Ratcheting Wrench aids bolt removal. Mig Welded 1/8" Steel Plate over the Mounting Holes to provide additional strength. Firewall View of Modified Pedal Bracket After Test Fitting the Pedal Assembly, I found the Clutch Master Cylinder was very close to the new Brake Booster. I was thinking that, in case, I needed to install a Larger Clutch Master for a Bigger Clutch, a Larger Master might be needed. So I decided to move the Clutch Master over while i got Pedal Assembly apart now. Next - Modifying the Pedal Assembly to move the Clutch Master over. Edited October 5, 2025 by toolman correct tect and pics Quote Link to comment Share on other sites More sharing options...
toolman Posted November 3, 2025 Author Share Posted November 3, 2025 SEMA SHOW 2025-LAS VEGAS NOV. 3-7 I know that many HybridZ forum members are unable to attend this show so I will try to look for any product at this show for you. Please list your request as detailed as possible( manufacturer name and description of the item). I will, of course, look for items related to Z cars but there are thousands of vendors and it is easy to miss items. Toolman Quote Link to comment Share on other sites More sharing options...
Mitchel0407 Posted November 3, 2025 Share Posted November 3, 2025 I don’t know if they attend or what can be found at SEMA but I’m interested If Apex Engineered will be there. I just saw that they dropped a new line of suspension upgrades this weekend called the Retro Mod line of suspension. The Retro line allows you to keep the stock R180 or R200 diff and looks a lot like there I guess existing suspension (non track attack) line that seems to be renamed to the Pro Touring line. Quote Link to comment Share on other sites More sharing options...
Apex Engineered Posted November 3, 2025 Share Posted November 3, 2025 11 hours ago, Mitchel0407 said: o Hello, we will not be there but there will be 2 (that we know of) Zs running our full line up at SEMA, A green 2+2 and a wrapped 240z! Feel free to check them out, ask questions and let us know if you have any questions Quote Link to comment Share on other sites More sharing options...
Mitchel0407 Posted November 4, 2025 Share Posted November 4, 2025 12 hours ago, Apex Engineered said: Hello, we will not be there but there will be 2 (that we know of) Zs running our full line up at SEMA, A green 2+2 and a wrapped 240z! Feel free to check them out, ask questions and let us know if you have any questions Unfortunately I live in the Netherlands so I will probably never be able to attend SEMA and there aren’t a lot of S30 Z’s running around here let alone modified with Apex Engineered hardware. I do plan to change that over time as the suspension kits look really good not to mention the perfect timing of new Retro Mod line which retains the original differential setup. The wife isn’t happy with me spending money on the car but I really want my 280z back on the road this spring. I’ll wait till black Friday to see if there are any good deals and then contact for an order for at least the frame rails and rear suspension. 1 Quote Link to comment Share on other sites More sharing options...
toolman Posted November 11, 2025 Author Share Posted November 11, 2025 (edited) Hydraulic Clutch Pedal Modifications- I enlarged the Clutch Master to Shift to move about 1" to the Left. Interior Side of Clutch Master Mounting Bracket checking Push Rod Clearance Measuring Master Cylinder Piston Depth then adjusting Booster Clearance to 3MM. Modified Clutch Pedal by moving the Clutch Pedal Push Rod over about 3/4" to the Left. This small movement of the Clutch Push Rod Pin Mounting Bracket should allow even Larger Clutch Master, in case of Installation of a Larger Clutch Assembly. Finished Installation Next-ROAD TEST Edited November 11, 2025 by toolman test and pic change Quote Link to comment Share on other sites More sharing options...
toolman Posted November 14, 2025 Author Share Posted November 14, 2025 (edited) IMPORTANT MESSAGE-CONCERNING NEW COMPLETE 240Z BODY ASSEMBLIES FOR SALE I just posted information concerning new complete early model 240z bodies assemblies that may be available in the near future. It is posted on the BODY KITS AND PAINT SECTION of Hyprid Z Forums on Monday. There are a lot of pics and text discussing their construction and quality. Information about the manufacturer is also listed. There was a lot of interest in their line of reproduction vehicles( Toyota Land Cruisers,Toyota A86, Ford Bronco bodies). Also, I also will post text and pics of ALL ALUMINUM BODY PANELS FOR 240Z MANUFACTURED IN JAPAN. Weigh savings are about 20 to 30 percent and very corrosion resistant. The workmanship was excellent and looked beautiful. This is a limited production run so if you are interested, I would put your order in. Star Road in Japan is handling the sales of this product. I will also start posting pics and text of other cars and products that I found at the SEMA SHOW 2025. This will posted in my usual Hybridz Forum site at V8 ZForums-Gen III & IV Chevy V8z site soon. Edited November 15, 2025 by toolman text correction Quote Link to comment Share on other sites More sharing options...
toolman Posted November 16, 2025 Author Share Posted November 16, 2025 (edited) IMPORTANT MESSAGE-CONCERNING NEW COMPLETE 240Z BODY ASSEMBLIES FOR SALE I just posted information concerning new complete early model 240z bodies assemblies that may be available in the near future. It is posted on the BODY KITS AND PAINT SECTION of Hyprid Z Forums on Monday. There are a lot of pics and text discussing their construction and quality. Information about the manufacturer is also listed. There was a lot of interest in their line of reproduction vehicles( Toyota Land Cruisers,Toyota A86, Ford Bronco bodies). Also, I also post text and pics of ALL ALUMINUM BODY PANELS FOR 240Z MANUFACTURED IN JAPAN. Weigh savings are about 20 to 30 percent and very corrosion resistant. The workmanship was excellent and looked beautiful. This is a limited production run so if you are interested, I would put your order in. Star Road in Japan is handling the sales of this product. I will also start posting pics and text of other cars and products that I found at the SEMA SHOW 2025. This will posted in my usual Hybridz Forum site at V8 ZForums-Gen III & IV Chevy V8z site soon. Edited November 16, 2025 by toolman Quote Link to comment Share on other sites More sharing options...
toolman Posted November 16, 2025 Author Share Posted November 16, 2025 (edited) Sema and Apex Show 2025 -Las Vegas Nov.4 to Nov7 I have been to the Sema and Apex Show in Las Vegas for over 35 years missing only two shows. These Shows have been crowded and always better than the previous year. That is until now, this year the show were not better than previous ones. Not as many vendors and corresponding not as many attendees. Prices at this noticable higher than past. Everyone expects convention prices to higher than outside of convention area. But, this year, prices for food, hotel rooms, etc were extremely higher. For example , one regular16 oz of Water was $9 a bottle. Mac Donald's Cheese Burger Meal with Fries and Drive ran about $35!! Prices for everything was higher within 2 Blocks of the Strip. The lack of human card dealers who were replaced with automated machines was everywhere. Also, missing was the people. I would there was about 20% less people at the convention and maybe 25% less people walking on the Strip. This is happening during one of the biggest conventions of the year!! Back to the Show- Riding the Las Vegas Mono Rail that runs parallel from MGM Grand to the Las Vegas Convention Center. Regular price was $6 a ride but it was lowered to $5.50 for the convention goers. Cars, Trucks, Food Truck, Vendor Tests, etc outside the Convention Hall. Blown Cars preparing for the Burnout Box Area Off Road Motorcycle Jump Area Videos of their Jumps Sorry, my videos of the motorcycle jumping was able to post. I will try to correct this if i can. A crazy looking Roaster Beautiful Chopped Chevy Truck Convertible a Usual Large Amount of Load Speakers in a truck bed. Pic of the Crowd of People Outside the Central Hall Ford GT Racer Interior pic of a Green 240Z Racer Fuel Injected Lowered Chevy El Camino Nismo Accessories Board Nismo Wheel Display GReddy Racing Booth FUGU Z 10year Anniversary Twin Turbo Setup Left side of Engine Compartment Sung Kang Famous 240Z Right Rear Wheel Rear View Engine Compartment RB25 with Turbo Left Front Wheel Left Rear View Interior Pic Rear Hatch Area Pic Sung Kangs New 240Z-24 Valve Overhead Twin Cam Motor Interior Pic Left Rear Wheel Pic Carbon Fiber Rear End Parts Interior of a Bullet Proof Armored Vehicle 10,000 lbs worth Exterior View of Armored Vehicle Outside of Burnout Area More pics and text to come- Edited November 26, 2025 by toolman text and pic corrections Quote Link to comment Share on other sites More sharing options...
toolman Posted November 16, 2025 Author Share Posted November 16, 2025 (edited) More from Sema Show- Fully Modified Toyota Truck with Tilt Front End nject Fuel Injected V8 motor to power it. Interior of this Race truck Rear Suspension for this OFF ROAD RACE TRUCK Eating Lunch at a Food Truck outside. Mc Donalds Extra Value Meals like Cheese Burgers Deluxe Costs $35 on the Strip. All the Strip Hotels charge for Parking. Even if you did not ask for a Room with a View. you may be charged for it and you don't find out till you are checking out. Even though I enjoy going to Las Vegas for the Sema Show, the cost of going is not worth it to me. So this maybe the Last Time that I go the Vegas! Even the hotel that I stayed at-Harrah's was empty. This pics show a Robot Vacuuming a Hall Way. Even McDonald"s on the Strip was empty. Eating Lunch at one of the numerous Food Trucks outside of the Main Convention Buildings A Razor Crazy Fully Modified with a Disc Brake with Taxi Cab Performance Casters and 48Vt Electric Motor. I still don't know what the Front Cooler is for. My guess would be the Cooler is for cooling the Electric Motor. Nismo Race Car on a Lift at their booth. Ford Gt with a Coyote Motor in it. HKS Booth with their Turbos, intercoolers and many other accessories. A Cute Mini Bike with a VW Fender Covering it. 240z with many Carbon Fiber Parts all over it. As you can see, the attendance is definitely down. this pic was taken in the Front Entrance of the Main HALL. Normally, there would be Wall to Wall People. Outside View Prismatic Powders-Wall of their wide selection of Powder coatings. Make you own Mid Engine 67-68 Ford Mustang You cut out the Mid Section of your Mustang forn the Firewall to to Rear Tail Light Panel then insert his new frame into the space. The Finished Product should look like this pic. I stiill working posting pics that for some reason are not posting. Edited November 20, 2025 by toolman text and pic corrections 1 Quote Link to comment Share on other sites More sharing options...
toolman Posted November 23, 2025 Author Share Posted November 23, 2025 (edited) Aluminum Body Panels of 240Z manufactured in Japan These 240Z Aluminum Body Panels are originally manufactured by Yahagi Industry Company in Japan. They will be marketed by Star Road Specialist in Tokyo, Japan. The body were installed on a private owner's car for the Sema Show 2025. I hope they have a video of the installation process so we can see how to done. That way, potential customer can determine whether their body shop can duplicate the installation. Working with Aluminum is not an easy task and requires some specialized expertise and tools. This vehicle was on display at the Toyo Tires Booth at Sema. Pic of Hood Bottom of the Hood the Hood Skin was riveted to the Hood Ribs. the Engine was a Turbocharged Nissan Motor. View of the Front End Rear Hatch Lid Right Side Door Rear End Panel Roof Panel Left Rear Quarter Panel Right rear Quarter Panel and Fuel Tank Door Left Door Left Rear Quarter Panel Left Front Fender Front Cowl Section Front Grill Section Headlight Bucket Information Sheet Weigh Saving Information Card These Aluminum Body Panels are very well made and looks great. It will provide a another option for restoring 240Z and save many Zs from being scrapped. i talked to the guys who actually manufactured the aluminum panels with the little Japanese that I know. They told me that right now, they plan to run only a Production Run of 100 body panels. Star Road is handling the sales side. But they would not give a price yet. I think they are waiting till the Tokyo Auto Salon Show occurring in January 2026 in Tokyo. Edited November 24, 2025 by toolman text and pic correction Quote Link to comment Share on other sites More sharing options...
toolman Posted December 18, 2025 Author Share Posted December 18, 2025 (edited) This You Tube Video goes over the conversion of a regular 240z to one with mostly all Aluminum Exterior Panels. The work seems to done at a home garage located in California. The owner never said level or how much his experience with aluminum panels. However, most of the panels are bolted on to the original sheet metal structure. The aluminum roof, both rocker panels and rear quarter panels were probably attached using a special aluminum to sheet metal epoxy. I worked with Japanese after market body panels and found their fitment was very good. Most of the corrosion damage found on the 240zs was actually caused by rust starting on the exterior panels. Then it spread into internal structural parts. So using these Aluminum Panels ,new Seam Sealers and Rust Preventive Methods will make these 240s last a long time. Edited December 18, 2025 by toolman Quote Link to comment Share on other sites More sharing options...
toolman Posted December 26, 2025 Author Share Posted December 26, 2025 Larry Chen checks out the Aluminum 240Z at Sema Show Larry Chen reviews the owner of the Aluminum 240z at the Sema Show and gets more details about it. Quote Link to comment Share on other sites More sharing options...
toolman Posted January 2 Author Share Posted January 2 (edited) Happy New Year!! I decided to upgrade my alternator on my Z. During my engine swap, I wanted to install an alternator with at least 150 Amp Output. Unfortunately, due to tight spacing, the only alternator that would fit was a General Motors One Wire Connection 110 Amp Output one. That was before added a Silver Mine Electric Power Steering which had Max 50 Amp Draw. So an upgrade was warranted. A POWERMASTER 165 Amp CS130 Alternator was selected. As it was the same alternator model as the original one, no mounting modifications would be necessary. Installation of the POWERMASTER ALTERNATOR in vehicle A larger Battery cable was also installed to compensate for the high Amperage Output. Edited January 2 by toolman Quote Link to comment Share on other sites More sharing options...
