Finishing Details of the Super Duty  8.8 Conversion-
      Strut Spring Tubes- The Threaded Strut Tubes  were obtained from BC RACING.   If you don't have a
TIG WELDER, Vladmir can weld his Strut Tubes Brackets on.
BC RACING STRUT TUBES
STRUT TUBES with Brackets WELDED ON
After installing the Complete Strut Assemblies with Coil Springs and car on the ground, you can adjust the
Spring Preload and Spring Height.    Adjust the Spring Height to your preference.
Double check Wheel to Body Clearance by testing the suspension under various road conditions.
Exhaust System Modifications-
    I raise the Dual Exhaust Pipes for extra clearance(Speed Bumps, etc),
REAR EXHAUST PIPES also, had to widen to accommodate the Wider 8.8 FORD DIFFERETIAL.
l
Rear View of Exhaust System
Bottom View of 2024Ford Motorsport Super Duty 8.8 Differential with Torsen Limited Slip with 3.55 Gears.
Right Side View of the Differential -note the Huge Axle Shaft capable of handling 800+ HP!!
Pic of Right Side Rotor and Mustang GT Disc Brakes.  Mounted also is 1" Wheel
Spacers to provide Caliper/ Wheel Clearance.
Bottom View of the Differential
Side View of Converted 5 Lug  17" x 11 1/2" wide Wheel with Extra Long Lug Nuts
and 315 Nitto Tires.
Rear to Front View of Tire and Wheel with Rocket Bunny Flare.
Road Test and Comments-Next
Edited by toolman
  • 4 weeks later...
Road Test and -Comments-
     The Firsr Road Test after the 8.8 Conversion went Fine.   Normally, the car under  under hard acceleration, a Shift  into
Secong Gear would cause the Right Side to break loose and the Rear End would start to come around.  So I would have to
back off the throttle or risk a Spin Out.   With Torsen Gear, the torque was applied smoothly and evenly.   The car handles
well and controllable.
     However, when I returned to my garage and check underside of the car,  I noticed a trail of grease above the Left Rear
CV Axle.
This grease trail was directly over the Left Inner CV Joint.
    So I jacked up the rear of the car, Removed the Left Inner CV Axle.
After inspecting the CV Axle , I found a Small Tear in the CV Booot.
The Hole was under the CV Boot Clamp so I figured  the person who assembled the CV Axle must have cut it
The bigger problem was finding a replacement CV Boot.   I tried my local Ford Dealer, NAPA, OReilys, Auto Zone,
Rock Auto and even Ebay.  Nobody had it.   Then, I remembered those Universal CV Axle Boots that allowed  the mechanic to replace the Damaged CV Boots without completely removing the CV Axle.  It saved the mechanic alot
of Labor Hours.  Those boots were pretty universal.    An inventory of  4 to 5 these Universal Boots would fit many
Front Wheel Drive Cars and even ATV.
Even Snap On sold these Universal CV Axle Boots.
 Afrer Removing the Rubber Boot by taking the Boot Clamps off,   You just remove the Large Snap Ring.
Then remove the CV Joint.
Once the CV Joint was removed,  The Universal Boot was installed by stretching the boot over the axle.   I just cut the bottom section of a oil funnel.   With a little muscle, pull the Boot over the axle using the funnel to make it easier.
The messy part was put the CV Axel Grease into the new boot.  Finally , install both CV Clamps.  Then, take the car for  another road test to check for any leakage.
Edited by toolman
text and pic
The Follow Up Road Test  went fine.   There was no CV Axle Grease leak and the Diffferential performed well.   The Differential Gear Ratio was now 3:55 compared to the old r200 3:70 so my
shift points were now more spread out.   I think that 3:55 gear ratio for city driving by providing less
gear shifting.   Highway driving was better by running at less RPMs too.
    The Blue Angels-the Navy Stunt F16 planes were coming to participate in an Air Show at Kaneohe Marine Base.
 There also had a Car Show along with the Two Day Air Show.  Although, the show was
on the other side of my island , I decided to enter my 240z in the Car Show.   The trip would take about one Hour but most of it was on freeway roads.  The Freeway would take me over the mountain to the other side of my island.
 On the downward leg of the trip, I noticed that a lot of pedal effort was necessary to slow down,   My conclusion was that a Bigger Brake Power booster would  be needed.   The OEM Brake Booster was 7" booster so the next  size booster would be 1978 280z
booster which is 8 !/2".  The local auto places did not have a 280Z  booster available so I ordered one from Z Depot.
    The Air Show was terrific but unfortunately, it create a large Traffic problem.
  However, The Good News is that I won the TOP TEN  Trophy for Aloha Mother Fest 2025 -CAR Show that was combined with the Blue Angel Show.
Next- Upgrading the 7" OEM Booster with the 78280z  8 1/2"Brake Booster
Next-Upgrading the Brake Power Booster with a 78 280Z Unit
Edited by toolman
text correction and pics
  • Thanks 1
Upgrading with a 8 1/2" Power Brake Booster
   Sorry for the delayed posting, I was doing renovations on my house.   I am upgrading my 7 1/2"with a larger 8 !/2"Power Brake Booster.  When I added the 8.8 Super Duty Differential Conversion, the Large Discs Brakes called for a Larger Brake Booster to be added.   I bought the booster from Z Depot as my local parts supplies did not have in stock.
                                 Comparison Pics of the 7 1/2" and 8 1/2" Boosters
As you see with these pics,  the Mounting Lugs are spread out more than the old one.   Roughly about 3/4" or 1 1/2" across.
     Luckly, the Brake Master Cylinder Assembly does not required disconnecting the brake lines.   You can just loose the brake line mounts and Proportioning Valve Assembly.   This will allow the removal of the old booster and room to install the new one.
Now, plenty of room to work on the Booster Mounting Holes is available. IMG_7810.JPG.218d800e0757bb40ee749a093447a1fe.JPG
However, I found that making the wider mounting holes would occur close to edge of the Brake Pedal Assembly on the opposite side of the Firewall.   So instead of just putting large washers in would not be strong enough.  So I decided I would remove the Brake Pedal Assembly and would weld up some steel plate on the pedal assembly to give it more strength.
    First, I made a Template for a Rubber Gasket behind the Booster Body.
Then, Cut the gasket from a !/8" Flat Rubber Sheet.
IMG_7804.JPG.253d4d12c2cdac52cc3233a8d25fc4ec.JPG Masking tape applied on Rubber gasket material
Test Fitting the Gasket.
IMG_7813.JPG.bd010c7226eaba2d2161f9f843a040ca.JPG Rubber Gasket on Booster
I decided that it was better to removed the Brake Pedal Assembly to work on it.   So I had to remove the Steering Column
and Electric Power Steering Motor together.  So I constructed a 4 Foot x 1 x 1/2" Foot Plywood Platform so I could work easier than bending my back on the rocker panel.
Also, to remove the Brake Pedal Assembly, there are Two 12mm short Hex bolts on the top of the assembly. To remove these bolts, you must remove the Tachometer to access these bolts.  There is only a couple of inches of space above the bolts so 12mm Ratcheting wrench or small Ratchet is recommended.
the Two Hidden Bolts
12mm Ratcheting Wrench aids bolt removal.
Mig Welded 1/8" Steel Plate over the Mounting Holes to provide additional strength.
Firewall View of Modified Pedal Bracket
After Test Fitting the Pedal Assembly, I found the Clutch Master Cylinder was very close to the new Brake Booster.  I was thinking that, in case, I needed to install a Larger Clutch Master for a Bigger Clutch, a Larger Master might be needed.   So I decided to move the Clutch Master over while i got Pedal Assembly apart now.
Next - Modifying the Pedal Assembly to move the Clutch Master over.
Edited by toolman
correct tect and pics
  • 4 weeks later...
SEMA SHOW 2025-LAS VEGAS  NOV. 3-7
    I know that many HybridZ forum members are unable to attend this show so I will try to look for any
product at this show for you.  Please list your  request as detailed as possible( manufacturer name and
description of the  item).  I will, of course, look for items related to Z cars but there are thousands of vendors
and it is easy to miss items.
                                                   Toolman
I don’t know if they attend or what can be found at SEMA but I’m interested If Apex Engineered will be there. I just saw that they dropped a new line of suspension upgrades this weekend called the Retro Mod line of suspension. The Retro line allows you to keep the stock R180 or R200 diff and looks a lot like there I guess existing suspension (non track attack) line that seems to be renamed to the Pro Touring line.
12 hours ago, Apex Engineered said:
Hello, we will not be there but there will be 2 (that we know of) Zs running our full line up at SEMA, A green 2+2 and a wrapped 240z! Feel free to check them out, ask questions and let us know if you have any questions :)
Unfortunately I live in the Netherlands so I will probably never be able to attend SEMA and there aren’t a lot of S30 Z’s running around here let alone modified with Apex Engineered hardware. I do plan to change that over time as the suspension kits look really good not to mention the perfect timing of new Retro Mod line which retains the original differential setup.
The wife isn’t happy with me spending money on the car but I really want my 280z back on the road this spring. I’ll wait till black Friday to see if there are any good deals and then contact for an order for at least the frame rails and rear suspension.
  • Like 1
Hydraulic Clutch Pedal Modifications-
  I enlarged the Clutch Master to Shift to move about 1" to the Left.
Interior Side of Clutch Master Mounting Bracket
IMG_7862.JPG.0db2ba0e1404fa9c61c99e912b2ceabd.JPG checking Push Rod Clearance
Measuring Master Cylinder Piston Depth then adjusting Booster
Clearance to 3MM.
Modified Clutch Pedal by moving the Clutch Pedal Push Rod over about 3/4" to the Left.
This small movement of the Clutch Push Rod Pin Mounting Bracket should allow even Larger
Clutch Master, in case of Installation of a Larger Clutch Assembly.
Finished Installation
Next-ROAD TEST
Edited by toolman
test and pic change
IMPORTANT MESSAGE-CONCERNING NEW COMPLETE 240Z BODY ASSEMBLIES FOR SALE
    I just posted information concerning new complete early model 240z bodies assemblies that may be available
in the near future.  It is posted on the BODY KITS AND PAINT SECTION of Hyprid Z Forums on Monday. There are a lot
of pics and text discussing their construction and quality.   Information about the manufacturer is also listed.   There was
a lot of interest in their line of reproduction vehicles( Toyota Land Cruisers,Toyota A86, Ford Bronco bodies).
    Also,  I also will post text and pics of ALL ALUMINUM BODY PANELS FOR 240Z MANUFACTURED IN JAPAN.   Weigh savings
are about 20 to 30 percent and very corrosion resistant.  The workmanship was  excellent and looked beautiful.   This
is a limited production run so if you are interested, I would put your order in.  Star Road in Japan is handling the sales of this product.
     I will also start posting pics and text of other cars and products that I found at the SEMA SHOW 2025.  This will posted in my usual Hybridz Forum site at V8 ZForums-Gen III & IV Chevy V8z site soon.
Edited by toolman
text correction
    Also,  I also post text and pics of ALL ALUMINUM BODY PANELS FOR 240Z MANUFACTURED IN JAPAN.   Weigh savings
of this product.
Edited by toolman
Sema and Apex Show 2025 -Las Vegas Nov.4 to Nov7
    I have been to the Sema and Apex Show in Las Vegas for over 35 years missing only two shows.   These
Shows have been crowded and always better than the previous year.   That is until now, this year the show were
not better than previous ones.  Not as many vendors and corresponding not as many attendees.   Prices at this
noticable higher than past.   Everyone expects convention prices to higher than outside of convention area.  But, this
year, prices for food, hotel rooms, etc were extremely higher.  For example , one regular16 oz of Water was $9 a bottle.
Mac Donald's Cheese Burger Meal with Fries and Drive ran about $35!!  Prices for everything was higher within 2 Blocks of the Strip.   The lack of human card dealers who were replaced with automated machines was everywhere.   Also, missing
was the people.   I would there was about 20% less people at the convention and maybe 25% less people walking on the
Strip.   This is happening during one of the biggest conventions of the year!!
  Back to the Show-
      IMG_8085.JPG.2586789a5fe9a63999b420b7a30e8557.JPG   Riding the Las Vegas Mono Rail that runs parallel from MGM Grand to the Las Vegas Convention Center.  Regular price was $6 a ride but it was lowered to $5.50 for the convention
goers.
     Cars, Trucks, Food Truck, Vendor Tests, etc outside the Convention Hall.
Blown Cars preparing for the Burnout Box Area
Off Road Motorcycle Jump Area
 Videos of their Jumps
 Sorry, my videos of the motorcycle jumping was able to post.  I will try to correct this if i can.
 A crazy looking Roaster
Beautiful Chopped Chevy Truck Convertible
a Usual Large Amount of Load Speakers  in a truck bed.
Pic of the Crowd of People Outside the Central Hall
Ford GT Racer
Interior pic of a Green 240Z Racer
Fuel Injected Lowered Chevy El Camino
Nismo Accessories Board
Nismo Wheel Display
GReddy Racing Booth
FUGU Z 10year Anniversary
Twin Turbo Setup
Left side of Engine Compartment
Sung Kang Famous 240Z
Right Rear Wheel
Rear View
Engine Compartment
RB25 with Turbo
Left Front Wheel
Left Rear View
Interior Pic
Rear Hatch Area Pic
Sung Kangs New 240Z-24 Valve Overhead Twin Cam Motor
Interior Pic
Left Rear Wheel Pic
Carbon Fiber Rear End Parts
Interior of a Bullet Proof Armored Vehicle  10,000 lbs worth
Exterior View of Armored Vehicle
Outside of Burnout Area
More pics and text to come-
Edited by toolman
text and pic corrections
More from Sema Show-
Fully Modified Toyota Truck with Tilt Front End
IMG_8019.JPG.021bda055b75f256b92671a4766037eb.JPGnject
Fuel Injected V8 motor to power it.
Interior of this Race truck
Rear Suspension for this OFF ROAD RACE TRUCK
Eating Lunch at a Food Truck outside.
Mc Donalds Extra Value Meals  like Cheese Burgers Deluxe Costs $35 on the Strip.
All the Strip Hotels charge for Parking.  Even if you did not ask for a Room with a View. you may
be charged for it and you don't find out till you are checking out.   Even though I enjoy going to Las
Vegas for the Sema Show, the cost of going is not worth it to me. So this maybe the Last Time that
I go the Vegas!
Even the hotel that I stayed at-Harrah's was empty.  This pics show a Robot Vacuuming a
Hall Way.
Even McDonald"s on the Strip was empty.
Eating Lunch at one of the numerous Food Trucks outside of the Main Convention Buildings
A Razor Crazy Fully Modified with a Disc Brake with Taxi Cab Performance Casters and 48Vt Electric Motor.
I still don't know what the Front Cooler is for.  My guess would be the Cooler is for cooling the Electric Motor.
Nismo Race Car on a Lift at their booth.
Ford Gt with a Coyote Motor in it.
HKS Booth with their Turbos, intercoolers and many other accessories.
A Cute Mini Bike with a VW Fender Covering it.
240z with many Carbon Fiber Parts all over it.
As you can see, the attendance is definitely down.  this pic was taken in the Front Entrance of the Main HALL.
Normally, there would be Wall to Wall People.
Outside View
Prismatic Powders-Wall of their wide selection of Powder coatings.
Make you own Mid Engine 67-68 Ford Mustang
IMG_8054.JPG.1b35dcef5cbcd69f42c06b79d7cd0b0d.JPGYou cut out the Mid Section of your Mustang forn the Firewall  to
to Rear Tail Light Panel  then insert his new frame into the space.
 The Finished Product should look like this pic.
I stiill working posting pics that for some reason are not posting.
Edited by toolman
  • Like 1
Aluminum Body Panels of 240Z manufactured in Japan
        These 240Z Aluminum Body Panels are originally manufactured by Yahagi Industry Company in Japan.
They will be marketed by Star Road Specialist in Tokyo, Japan.
        The body were installed on a private owner's car for the Sema Show 2025.   I hope they have a video of the
installation process so we can see how to done.   That way, potential customer can determine whether their
body shop can duplicate the installation.  Working with Aluminum is not an easy task and requires some specialized expertise and tools.
      This vehicle was on display at the Toyo Tires Booth at Sema.
Pic of Hood
Bottom of the Hood
the Hood Skin was riveted to the Hood Ribs.
the Engine was a Turbocharged Nissan Motor.
View of the Front End
Rear Hatch Lid
Right Side Door
Rear End Panel
Roof Panel
Left Rear Quarter Panel
Right rear Quarter Panel and Fuel Tank Door
Left Door
Left Front Fender
Front Cowl Section
Front Grill Section
Information Sheet
Weigh Saving Information Card
These Aluminum Body Panels are very well made and looks great.  It will provide a another
option for restoring 240Z and save many Zs from being scrapped.
i talked to the guys who actually manufactured the aluminum panels with the little Japanese that
I know.   They told me that right now, they plan to run only a Production Run of 100 body panels.
Star Road is handling the sales side.  But they would not give a price yet.   I think they are waiting till the Tokyo Auto Salon Show occurring in January 2026 in Tokyo.
Edited by toolman
  • 4 weeks later...
This You Tube Video goes over the conversion of a regular 240z to one with mostly all Aluminum Exterior Panels.
The work seems to done at a home garage located in California.   The owner never said level or how much his experience with aluminum panels.  However, most of the panels are bolted on to the original sheet metal structure.  The aluminum roof, both rocker panels  and rear quarter panels were probably attached using a special aluminum to sheet metal epoxy. I worked with Japanese after market body panels and found their fitment was very good.  Most of the corrosion damage found on the 240zs was actually caused by rust starting on the exterior panels.   Then it spread into internal structural parts. So using these Aluminum Panels ,new Seam Sealers and Rust Preventive Methods will make these 240s last a long time.
Edited by toolman
Happy New Year!!
     I decided to upgrade my alternator on my Z.   During my engine swap, I wanted to install an alternator with at least 150 Amp Output.  Unfortunately, due to tight spacing, the only alternator that would fit was a General Motors One Wire Connection 110 Amp Output one.  That was before added a Silver Mine Electric Power Steering which had Max 50 Amp
Draw.   So an upgrade was warranted.  A POWERMASTER 165 Amp CS130 Alternator was selected.  As it was the same
alternator model as the original one, no mounting modifications would be necessary.
Installation of the POWERMASTER ALTERNATOR in vehicle
A larger Battery cable was also installed to compensate for the high Amperage Output.
Edited by toolman
