LooseRocks Posted December 2, 2019 Share Posted December 2, 2019 How did you route your fuel lines? Did you cross over in the tunnel to the driver’s side? When you came out of the tunnel how/where did you terminate the lines before hooking to the engine (bracket on firewall, regulator on firewall, somewhere else)? Quote Link to comment Share on other sites More sharing options...
Exposed Posted December 4, 2019 Share Posted December 4, 2019 (edited) i ran my lines near the top of the trans tunnel then routed them to the "cold" side of the engine. When I redo them again Ill probably build a heat sheild with a bulkhead connector Edited December 4, 2019 by Exposed Quote Link to comment Share on other sites More sharing options...
HuD 91gt Posted December 4, 2019 Share Posted December 4, 2019 (edited) I ran 3/8” lines through the tunnel using the stock mounting (Rubber froze then drilled). The return line crossed over just before the engine bay. The feed runs on the cold side. If your redoing then, running straight lines alongside the frame rails seems like the best route. Edited December 4, 2019 by HuD 91gt Quote Link to comment Share on other sites More sharing options...
LooseRocks Posted December 4, 2019 Author Share Posted December 4, 2019 (edited) 1 hour ago, Exposed said: i ran my lines near the top of the trans tunnel then routed them to the "cold" side of the engine. When I redo them again Ill probably build a heat sheild with a bulkhead connector Did you cross over to the cold side in the tunnel? Or did you come out of the tunnel where the OEM ones come out and then routed them over. I'm in the process of installing new hard lines from the back to the front. The plan is to use the OEM brackets with new lines (enlarge the rubber mounts). I was thinking I would pop out of the tunnel where the OEM lines come out then bend them up and over to the cold side along the fire wall. Terminate them to a pair AN bulkhead connectors at a custom bracket mounted to the firewall below the hood latch just to the driver's side. From there I could make the connection to the engine with soft lines. I'm not oppose to going to the last OEM bracket in the tunnel then crossing to the center or driver's side in the tunnel and coming out to that bracket. Maybe located the bracket lower on the firewall. Just trying to get some ideas about what other people are doing. Edited December 4, 2019 by LooseRocks adding more comment Quote Link to comment Share on other sites More sharing options...
EF Ian Posted December 4, 2019 Share Posted December 4, 2019 5 hours ago, LooseRocks said: I'm in the process of installing new hard lines from the back to the front. The plan is to use the OEM brackets with new lines (enlarge the rubber mounts). I was thinking I would pop out of the tunnel where the OEM lines come out then bend them up and over to the cold side along the fire wall. Terminate them to a pair AN bulkhead connectors at a custom bracket mounted to the firewall below the hood latch just to the driver's side. From there I could make the connection to the engine with soft lines. Mine is pretty much this. I''ll actually be redoing it, will be the same but the rear lines will end up mounted nearer the filter and the filter will be mounted higher up. Quote Link to comment Share on other sites More sharing options...
Exposed Posted December 5, 2019 Share Posted December 5, 2019 12 hours ago, LooseRocks said: Did you cross over to the cold side in the tunnel? Or did you come out of the tunnel where the OEM ones come out and then routed them over. I'm in the process of installing new hard lines from the back to the front. The plan is to use the OEM brackets with new lines (enlarge the rubber mounts). I was thinking I would pop out of the tunnel where the OEM lines come out then bend them up and over to the cold side along the fire wall. Terminate them to a pair AN bulkhead connectors at a custom bracket mounted to the firewall below the hood latch just to the driver's side. From there I could make the connection to the engine with soft lines. I'm not oppose to going to the last OEM bracket in the tunnel then crossing to the center or driver's side in the tunnel and coming out to that bracket. Maybe located the bracket lower on the firewall. Just trying to get some ideas about what other people are doing. Yes I crossed over while in the trans tunnel, will probably do the same thing when I get to that point. Currently have the entire setup done with soft lines and brackets. Quote Link to comment Share on other sites More sharing options...
