jjslade Posted August 5, 2020 Share Posted August 5, 2020 Hi there,i've got a 260z with roundtops on, and it idles like a bag of spanners, and emits a ridiculous amount of white smoke out the back. Normally you would think this would be a blown headgasket, but it is a brand new headgasket, torqued down correctly. I have even tried draining all the water from the system and starting it with absolutely no coolant in for a short period, but with the same cloud of white smoke. What else could this be? a warped head maybe, or vacuum leak? Really getting to my wits end with it now. Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted August 5, 2020 Share Posted August 5, 2020 I'd start with a compression test. and check the spark plugs for water fouling. I'm not familiar with the term "bag of spanners" but I'm going to assume it's not a good thing and there is a lot of valve lash noise as well as poor running. It would be a good idea to reset the valve lash prior to the compression test. Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 5, 2020 Share Posted August 5, 2020 4 hours ago, jjslade said: Hi there,i've got a 260z with roundtops on, and it idles like a bag of spanners, and emits a ridiculous amount of white smoke out the back. Normally you would think this would be a blown headgasket, but it is a brand new headgasket, torqued down correctly. I have even tried draining all the water from the system and starting it with absolutely no coolant in for a short period, but with the same cloud of white smoke. What else could this be? a warped head maybe, or vacuum leak? Really getting to my wits end with it now. Could be a cracked head. Check your spark plugs. They'll be a clue. Quote Link to comment Share on other sites More sharing options...
jjslade Posted August 7, 2020 Author Share Posted August 7, 2020 On 8/5/2020 at 7:56 PM, bunkhouse said: I'd start with a compression test. and check the spark plugs for water fouling. I'm not familiar with the term "bag of spanners" but I'm going to assume it's not a good thing and there is a lot of valve lash noise as well as poor running. It would be a good idea to reset the valve lash prior to the compression test. Haha may be a British term, just means very very rough. I will do a compression test and see what results that yields Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 7, 2020 Share Posted August 7, 2020 Might as well look at the spark plugs when you take them out for the pressure measurement. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted August 13, 2020 Share Posted August 13, 2020 The white smoke without water is an interesting thing, but only with the assumption there was sufficient time to burn off any water that may have leaked in. I've seen really lean cylinders put out white smoke, usually before something lets go. I think it best as others have said to run a compression test. Hydrocarbon test in the coolant or checking for water in the oil would also be two other alternatives or additional tests. Running rough as in loping idle, running and catching, sputtering, front firing? Any additional info will be helpful. Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted August 14, 2020 Share Posted August 14, 2020 A quick test for water in the oil is put one drop of the oil on hot (+ 212 f. ) metal. A hot exhaust manifold will work, If the drop of oil smokes, it's pure oil. If it smokes and sizzles, the sizzle is caused by water. Quote Link to comment Share on other sites More sharing options...
munters Posted August 15, 2020 Share Posted August 15, 2020 Could be oil burning as well. If it's a lot of oil it looks like white with a little hint of blue. Quote Link to comment Share on other sites More sharing options...
jjslade Posted August 19, 2020 Author Share Posted August 19, 2020 So i have done a compression test 1- 100 2- 95 3- 90 4- 95 5-90 6-90 So very low. As i said, it has a brand new head gasket, so could this indicate all the rings are gone? I also had to re grind all new valves in as 10 of them were bent, so perhaps I haven't done it well enough as it was my first time Any other help would be very much appreciated Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted August 19, 2020 Share Posted August 19, 2020 Did you hold the throttle wide open during the tests? If not, retest and turn the engine over throttle wide open, until the c. gauge needle doesn't go any higher. Then put a tablespoon or so of oil in each cylinder and retest. If the compression raises significantly during the wet test, it means the compression is escaping past the rings. If the compression stays about the same the problem is in the valves. Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 19, 2020 Share Posted August 19, 2020 4 hours ago, jjslade said: So i have done a compression test 1- 100 2- 95 3- 90 4- 95 5-90 6-90 So very low. The type of gauge and any adapters or extensions can cause low pressures. The extensions add volume to the combustion chamber. What are you using? The numbers are all very close, which is important. You'll get more ideas if you answer all of the questions that have been asked. There's not much in what you've written that tells much. Idles poorly, white smoke, low cylinder pressures. Just not enough there to even make a good guess. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted August 20, 2020 Share Posted August 20, 2020 Did I miss a new pope being elected? If your car is automatic (unlikely) it could be sipping trans. fluid through the modulator. Also.........oil introduced after combustion can smoke white. Quote Link to comment Share on other sites More sharing options...
jjslade Posted August 21, 2020 Author Share Posted August 21, 2020 Here is a video of it running if it helps, idling at about 1000 rpm, and the smoke is quite a bit more white in person Quote Link to comment Share on other sites More sharing options...
