madkaw Posted May 28, 2025 Author Share Posted May 28, 2025 On 5/17/2025 at 2:33 AM, jonbill said: It's a welded p90a. I think the ports are 38mm. I think they must be as big as they can be since the head bolt holes broke through when we drilled them for m12 bolts. Did you have to use the air bleeds to balance ports ? I tried opening one up and didn’t get any response in the air . Quote Link to comment Share on other sites More sharing options...
jonbill Posted May 29, 2025 Share Posted May 29, 2025 Yes I did on the FAJs, I just about got the amount of adjustment I needed. Quote Link to comment Share on other sites More sharing options...
madkaw Posted May 29, 2025 Author Share Posted May 29, 2025 14 hours ago, jonbill said: Yes I did on the FAJs, I just about got the amount of adjustment I needed. I don’t need much and it’s just on the first ITB. Maybe really have to crank out the bleeder to get anything out of it ? Quote Link to comment Share on other sites More sharing options...
jonbill Posted May 30, 2025 Share Posted May 30, 2025 I don't really remember I'm afraid, but I know there wasn't a lot of adjustment available. Have you looked at recentering the throttle plates to see if you can get more consistent air flow when closed? Quote Link to comment Share on other sites More sharing options...
madkaw Posted May 31, 2025 Author Share Posted May 31, 2025 19 hours ago, jonbill said: I don't really remember I'm afraid, but I know there wasn't a lot of adjustment available. Have you looked at recentering the throttle plates to see if you can get more consistent air flow when closed? I guess I don’t know how that’s done and what it does . I run cable that moves first ITB that moves the rest . The first ITB needs more air but there’s no way I can see to adjust its linkage without moving the others . I hooked up the cable and this engine started and idled great - so no real complaints ! Quote Link to comment Share on other sites More sharing options...
jonbill Posted May 31, 2025 Share Posted May 31, 2025 (edited) There should be adjuster like this between each, to make each pair flow the same, and the bleed screw is to balance flow within a pair. If the bleed screws don't have enough, then hold the throttle body up to the light with the throttle closed. You'll probably see the butterfly isn't perfectly centered because they weren't assembled very carefully. So they flow different amounts of air. You can slacken the two fixing screws and recenter the butterflies to balance them. But.... Why does the first need more air on yours? That doesn't sound right. Edited May 31, 2025 by jonbill Quote Link to comment Share on other sites More sharing options...
madkaw Posted June 6, 2025 Author Share Posted June 6, 2025 The synchronizer reading will be 5 on the first carb and 7 on the other two . Not sure how much off that really is . If I try and adjust the idle screw on the first ITB , that moves the other two based on how the linkages are overlapped . Quote Link to comment Share on other sites More sharing options...
jonbill Posted June 6, 2025 Share Posted June 6, 2025 I think thats a significant difference. Adjusting the throttle stop on that carb will move the others. Have you got a pic of how the throttle bodies are linked? I balance them by disconnecting the linkage and using air bypass to get each pair in balance with themselves and the throttle stops to get the 3 three balanced with each other. Then connect/adjust the linkage so they're still flowing the same at idle. They should then stay in balance as you open them. Quote Link to comment Share on other sites More sharing options...
madkaw Posted June 8, 2025 Author Share Posted June 8, 2025 The thing runs so good I can’t believe they aren’t very closely synced . First time doing ITBS so don’t know what to expect . I think they have been very good . Alpha N is a bit of a learning curve . I think I figured out I how to get 32 table for VE - but it runs well with 16 . I have a good MAP signal and I can see why some would use or try MAP density . I have a 3/4” log and soon it will be 1” . I will try it sometime just to prove to me - ha . Quote Link to comment Share on other sites More sharing options...
madkaw Posted June 26, 2025 Author Share Posted June 26, 2025 Latest updates are more tuning . I’ve now figured out have to get 2 x16 tables for VE and timing . I’ve also converted AFR so now I’m total Alpha male - lol. I haven’t driven since converting timing to Alpha N so that will take some time and knock ears . Weather has been so hot I haven’t driven the car in days . I also still have an issue with one bank O2 sensor . I must have a small leak somewhere that hard to find - maybe underside the header flange . I’ll have to try a smoke test to try and find it . Spark plugs all looked the same though my reading is wacky on 4-6 cylinders . So far mpg has been decent though that isn’t much of a consideration right now . Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 9, 2025 Author Share Posted July 9, 2025 Okay so the two tables for VE has given my some more fidelity with the tune . Can’t seem to pull off the two timing tables with AlphaN. Cant figure a way to include or delete a MAP sensor that doesn’t screw with the tune badly. I think with MS you have to use ITB mode which I thought took more expertise and data logs than I have . Runs good with SD running the timing , but I’d like more refinement. Still working on my air box and a buddy is printing me Velocity stacks to try . Also trying to put AC in the car ! I think the IAC idea might be scrapped for timing correction IAC . Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 19, 2025 Author Share Posted July 19, 2025 Well much rain is forecasted so I’m taking her off the road to attend to issues as in exhaust leak somewhere and # 3 port pulling more air than the others . Of course the only way to see the butterfly in the ITB is to remove it . I think the exhaust leak is at the header flange so that’s a remove project - ugh . I also think I might have pulled off my air box scheme . Taking me a while to get better at forming the plexiglass but the new buck is spot on for the most part . Hopefully I get all these issues resolved during the downtime . The engine is really running good but I’m hoping longer stacks will bring me into the sweet spot . A friend is printing out the 75mm stacks and I’ll probably also do a set of 90’mm . I think I have plenty of room to fit 90’s without impeding flow around them . 1 Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 22, 2025 Author Share Posted July 22, 2025 Well while the z was in the back garage I pulled the exhaust off . I had tried something that I won’t do again but I used a square port gasket ( Nissan ) on my mn47 head with my square port header . I was getting some small leaks when I pressurized the exhaust during leak checks . I went back with the gasket to match the head which worked fine before . Also stared at the ITBS for a long time trying to figure out why #3 was sucking more air . As you can see in the pics the linkage was digging into the side of the ITB . Shining a light into the ports before hand did seem to show 3 open a hair more . It was such a small difference I can’t swear I did anything , but I’m betting it’s enough . I ended up just filing the tab on the linkage down . I also figured a way to run my coolant bypass on #6 . I’ll run it under my ITBS on top of the heat shield . Might also try again to run air for a remote IAC . It’s actually getting too busy under the ITBS . Also on the to do list is to find some different cooling fans . I want to run brushless for the versatility and power since I want to install AC . AC is ordered from AC solutions but that’s a month out at least . Cold air box got glued tonight . 75mm Stacks are getting printed out and I’m getting close to finalizing this long project ! Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 31, 2025 Author Share Posted July 31, 2025 While waiting for my stacks to get printed I jumped on this other project . I ordered AC but my cooling system wasn’t up for the task. My 15” Mishimoto with no should struggles to keep up in traffic . Watched a couple of YouTube videos and decided to step up to some brushless fans from a Chevy Volt . I went with them because they look like they would fit the radiator . It’s TIGHT -even after carving on it for a day . It’s been a learning curve on how I was going to power and control them . Hope this works ! Quote Link to comment Share on other sites More sharing options...
Derek Posted July 31, 2025 Share Posted July 31, 2025 I'm in Florida and I use 2 smaller fans in puller config an a single larger fan in front of the condenser in pusher mode that comes on with the AC clutch. Sitting still you really need air passing through that condenser. I have the radiator fans controlled by my Megasquirt. Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 31, 2025 Author Share Posted July 31, 2025 33 minutes ago, Derek said: I'm in Florida and I use 2 smaller fans in puller config an a single larger fan in front of the condenser in pusher mode that comes on with the AC clutch. Sitting still you really need air passing through that condenser. I have the radiator fans controlled by my Megasquirt. These are pullers and I will have them set up to come on with AC . Megasquirt 3X just came out with firmware to control with PW . I think the only option is fans at full speed with AC . I have a buddy that said he can make a controller that will do a better job . I have no idea what CFM these fans are except they are 300 watts and they are SPAL fans OEM 1 Quote Link to comment Share on other sites More sharing options...
madkaw Posted August 5, 2025 Author Share Posted August 5, 2025 So after much searching and an upgrade to 1.6 firmware I was able to control these fans very well . They must have some built in controller that can decipher the low PW signal from MS . Testing at 87hz -which is what MS3 offers - they worked smoothly with no humming or any strange behavior . My GOD they move some air . Still wish I knew how much CFM they really are . The 1.6 firmware allows for a low/partial speed and full speed . Haven’t tried any AC controls since I don’t have AC yet . Quote Link to comment Share on other sites More sharing options...
madkaw Posted August 6, 2025 Author Share Posted August 6, 2025 Back to synchronizing itbs . #4 reads less than #3 port . Bleeder screws do nothing on any ITB - are they just there for looks ? No blockage I can see anywhere . I can pull the needle completely out and it does nothing to change air flow . I thought previously it was #3 was hanging on the linkage but that turned out to not be the issue . If I got any adjustment out of the bleeder screws I think I could get it dead nuts . I’m at a loss . Been searching on line but with no luck . Maybe cheap Chinese stuff . Quote Link to comment Share on other sites More sharing options...
jonbill Posted August 6, 2025 Share Posted August 6, 2025 I'd take them off and have a close look. If the bleeder screws have holes through and the screws seal, then they MUST have an effect. If you can't measure a difference with the synchrometer, then there must already be an overwhelming amount of air going past the butterfly. Either they're already open, or they're poorly centered. Quote Link to comment Share on other sites More sharing options...
madkaw Posted August 24, 2025 Author Share Posted August 24, 2025 (edited) So I took my Z to C&C -150 mile round trip. Engine ran strong but not right. Afrs were off between the banks. Thought I had a sync issue but I believe I have an injector issue. One plug looked rich and that was the bank running rich. #4 valve clearance checked and compression test is good. I've swapped injectors around to see if it follows. Weird thing is the AFR,s smooth out under more load-its worse under light throttle. It seems more than what a small butterfly sync issue , but maybe not . Used my new airbox also. It does quiet down the stacks. Speaking of stacks can someone buy me some TTT horns ? lol My 50's look to small in the box Edited August 24, 2025 by madkaw Quote Link to comment Share on other sites More sharing options...
