AydinZ71 Posted October 18, 2020 Share Posted October 18, 2020 Hi guys! People said they existed, but honestly never saw one in the wild. I pulled the valve cover from the 71’ SCCA car today, and low and behold it’s a P90A with solid lifters. Am I crazy, or are these rare? I also can’t make out the cam. The fire-wall side is blank on the end, but it does have an “A” on the casting. 🤷🏽♂️ the block is an L24. Curious what the CR is for this setup, but for now the best I can do is run cylinder pressures. Will do when I get the bat back in. has anyone else seen this setup before? Curious what you all think. I think I’m going to steal this head for the L28et so I can install an upgraded cam into it. Currently, it has a P90a with hydraulic lifters, which will not allow for aftermarket cams. Quote Link to comment Share on other sites More sharing options...
jonbill Posted October 18, 2020 Share Posted October 18, 2020 P90A is quite common in the UK and all have solid lifters. Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted October 18, 2020 Author Share Posted October 18, 2020 On 10/18/2020 at 7:46 PM, jonbill said: P90A is quite common in the UK and all have solid lifters. Expand Hmmm interesting! Well That’s good to know! I wonder why the previous owner Mounted this on an L24 block. I heard the P90’s flow well, but really no idea compared to thier predecessors. Quote Link to comment Share on other sites More sharing options...
jonbill Posted October 18, 2020 Share Posted October 18, 2020 It's a great head. but the original chamber size is 53cc, so on an L24 you've got to weld a lot or skim a lot to get a decent CR. Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 18, 2020 Share Posted October 18, 2020 On 10/18/2020 at 7:13 PM, AydinZ71 said: pulled the valve cover from the 71’ SCCA car today, and low and behold it’s a P90A with solid lifters. Am I crazy, or are these rare? the block is an L24. Curious what the CR is for this setup, Expand Just saw jonbill's reply. This is just a follow-on, below, that I was writing. Seems like an interesting motor. The other thing people like about the P90 is that it has the square exhaust ports without liners. The block has probably been bored or modified to allow the bigger valves to miss the sides of the cylinder wall. And there is a very common Timesert modification that people do to get rid of the hydraulic pivots. They're not actually "lifters". The P90 with flat top pistons would be similar to a ZX engine except that the swept volume would be less if it hasn't been bored much and still has the L24 crankshaft. Probably about 8:1, but hard to say for sure. Check the bottom of the P90A letters to see if the head has been shaved. That would up the CR somewhat. There are engine calculators out there too that you can play with. Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted October 18, 2020 Author Share Posted October 18, 2020 Ah cool!!! What is the stock measurement from the bottom of the letters to the deck? I can use a caliper to check. I don’t have a Spare head gasket or chain tension tool To pull the head at this time. I should be able to next week. This was an SCCA car, so I’m hoping the previous owner knew what he was doing. I doubt the CR from a flat top piston L24 block and stock P90a head would be very attractive Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted October 18, 2020 Author Share Posted October 18, 2020 (edited) Here is the accessible information I’m using, and I’m assuming it is accurate 🤷🏽♂️ http://zcsd.org/tech-articles/power-quest2.php Edited October 18, 2020 by AydinZ71 Quote Link to comment Share on other sites More sharing options...
madkaw Posted October 18, 2020 Share Posted October 18, 2020 I’d bet that head has been cut , maybe not . Wouldn’t be very stellar CR - but maybe over 8:1 Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted October 22, 2020 Author Share Posted October 22, 2020 (edited) Yeah... I don’t know if it was common to put these heads on L24 blocks for racing 🤷🏽♂️. The CR alone doesn’t make much sense. I picked up an N42 from a local guy, and will swap it after cleaning it up. the guy I bought it from ran mega squirt and blew a head gasket, but he thinks it was from improper ignition timing At high rpm. I don’t see any valves bent, but I will spray some lightweight oil down the runners and see if it leaks past the valve/seat when closed. When I pull the P90a, I will use a syringe and plastic plate to estimate the chamber volume. Then il know if it’s appropriate for the L28et. Fingers crossed. It might still be OK with the dished JE pistons, but id prefer if I settle on a CR sub 8 for the ~16psi I was running. Otherwise, I will need to use a 2MM gasket (if they still make those), or turn my boost down. I’m going to need to look into a knock sensor. It’s hard to hear over the wastegate dump. Edited October 22, 2020 by AydinZ71 Quote Link to comment Share on other sites More sharing options...
