21 hours ago, 74_5.0L_Z said:
I track my Ford powered 260Z.  My personal experience is that transmission gearing is extremely important to getting the most fun on the track.
In Florida, you will most likely be doing track days at Daytona and Sebring.  Both tracks have very fast sections.
Before doing track days, I autocrossed the car.  In autocross, you only really need second gear if you have the right differential / tire height.  I used Hoosier 275/35-15 tires and have a 3.36 rear end.  With a 1.94 second gear in a T-5 and 6,500 rpm, 2nd gear was good for 73 mph.
When I started doing track days, I needed all the gears.  I had replaced the stock 1st through 4th with G-Force gears and shafts, but fifth gear was still stock.  With that set-up, these were my gear ratios.
1st     2.95:1
2nd   1.94:1
3rd    1.33:1
4th    1:1
5th    0.59:1
Worked great until I needed 5th gear.  that big a drop absolutely killed the fun (no acceleration in 5th).  After my first time a Daytona, I changed 5th gear to 0.81:1.  The .81 gear absolutely transformed the car.  Now 5th gear is warp drive.
The transmission that you show probably doesn't have a good selection of gear ratios, and probably won't hold much power.
If it were me, I would get the new TKX with the close ratio rears.  That transmission will handle the power and maximize you fun on track.  If I didn't already have so much invested in my T5, I would get a TKX.
This is the TKX I would get:
https://www.speedwaymotors.com/TREMEC-TCET18084-TKX-Close-Ratio-5-Speed-Ford-Manual-Transmission,452007.html?srsltid=AfmBOoq-x1paVSDoNvgI38myLy79UBWXzZFW-QeQ4bK1_vWnSHM7bEEJ
Gear Ratios
  • 1st - 2.87, 2nd - 1.89, 3rd - 1.28, 4th - 1.00, 5th - 0.81
This is some great info, thanks for sharing. I’m looking into transmission upgrades now and I haven’t sourced my diff yet. Any thoughts on diff gearing, I’m going back and forth between 3.3 and 3.54. I’ve a big brake kit so I’ll be running 19” wheels, so I’m leaning toward the 3.54. You got me excited on the transmission now, I was kind of lost. Was thinking of a TREMEC TKO, but I’ll look into what you were suggesting. Thanks again for the info.
Graphed some trans and diff gearing options along with my current speeds at Sebring and some theoretical speeds for my build. Apples and Oranges on the cars, but the thing should be faster both in corners and on top speed. I might be a little optimistic on my theoretical speeds, but had to give it a shot. Thinking of option 3 as I get some use of 5th gear.
What size tires will you be running?
What rpm are you expecting to set as redline?
Also, your calculator has the speed profiles for the option 3 and option 4 swapped.  You will have a higher top speed with the 3.3 gear.
Edited by 74_5.0L_Z
More info
  • Thanks 1
Wow, good catch, I was in the weeds just typing data and didn’t notice.
I was thinking of 6,000 rpm’s and thats what the calcs were based on. Not 100% on tires yet, but thinking 19s based on clearing brakes and tire selection, but 18s are possible but smallest I can go. Calcs on speeds were based on 19s 26.67” tire height
I’m hoping to get some work done on the car this weekend. So close to being done with tearing stuff down and ready to add stuff. Just got this dual master cylinder kit that I hope I can make work. It’ll let me adjust front/rear brake bias in the car.
Posted (edited)
Got the front suspension and sway bar off today. Fought me a little bit, but impact helped a lot and had to take a sawzall to the toe arms, but it’s all out.
Edited by FastFloridian
On 5/12/2025 at 7:15 AM, 74_5.0L_Z said:
Do you plan to do any chassis reinforcement?  Cage?
Car had a cage already when I bought it. I’ve got a front strut brace that also ties into the firewall (apex), and braces on the inside of the fenders I’ll be welding on soon (apex also). Debating whether I need to beef up the frame rail or not since I’ve got the cage. Below is a pic when I bought it last year that shows the cage a little.
17 hours ago, FastFloridian said:
I hate working under the dash area.
Yep, join the club.  I'm surprised you haven't pulled the dash completely out yet....aren't you putting in a whole new dash eventually?  Even if you weren't replacing the dash, the wiring under there is likely a mess, and you would want to get all that fixed up/cleaned up/etc.  If you don't have the FSM and wiring schematics yet, you can download free FSMs for all years here:  https://www.xenonzcar.com/s30/fsm.html
You're making great progress....keep it up, and please keep the updates coming!
  • Thanks 1
Posted (edited)
Yep, dash is coming out, and wasn’t expecting to be under there too much yet, lol. It’s getting hot in Florida, already in the 90s, so I’ll be working on the new dash soon and fitting my digital gauges to it inside the nice cool house shortly 😁
  • Like 1
Good luck. A lot depends on the compromises you are willing to make. Ultimate Track Car and dominating time trials is a lofty goal. A good, fast, reliable, safe track car is very achievable and will bring many smiles.
  • Like 1
Thanks. I’m certainly no pro driver so maybe a little less ultimate track car build. Definitely want fun, safe and reliable. But I’m trying to build the best thing I can, no cutting corners when it comes to performance. So trying to put in a solid racing suspension, brakes wheels/tires and a good amount of horsepower.
Good progress!
At the risk of stating the obvious, hang on to that front crossmember even if you're not planning to use it yourself in the near term.  You may decide you need it in the future; and if not, someone else surely will.  They're getting harder to find in good condition these days.
On 6/8/2025 at 1:58 PM, jhm said:
Good progress!
Thanks for the tip, tbh I was probably going to toss it. I haven’t been having much luck selling anything coming of the Z and don’t have much room in the garage. Only stuff I’ve sold has been off the 302 engine such as carbs and headers. I’ll make a spot and hang onto it.
  • Like 1
