FastFloridian Posted October 6 Author Share Posted October 6 Good idea, I think I might have 2 tubes that would work for the front bolts, I think the rear bolts will be ok with the radiator bracket stiffening it up. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted October 11 Author Share Posted October 11 Got the engine on the hoist, doing some test fitting. Looks like I need to notch the driver side bracket, it interferes with steering shaft. Clearance is really tight with oil pan too, I hope I don’t need to find a different one. I’ll trim the bracket a little, then give it another go in a weekend or two, hopefully it’ll fit, then I can weld the cradle on. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted October 18 Author Share Posted October 18 Made a notch on the engine mount bracket for the steering shaft, hopefully I can test fit the engine again next weekend. I finished sway bar mounts. Tacked in sleeves for bolts to through bolt it to the frame. Also tacked/welded this angle support for sway bay bar mounts, should be very solid now, I can check that off the list. 3 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted October 31 Author Share Posted October 31 (edited) Did another motor test fit and added the bell housing to check for clearance. Looks like the oil pan will be a problem. I’m going to try and cut the corner and weld it back at an angle 🤷♂️. Everything else was looking good though. I had also wanted to weld this 10AN bung so I could attach the oil primer pump, but didn’t feel like taking the oil pan off, so now that I am, I’ll get this added too. Edited November 1 by FastFloridian 3 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted November 9 Author Share Posted November 9 Welded the AN fitting on the oil pan, and my seats came came in 💪 1 Quote Link to comment Share on other sites More sharing options...
jhm Posted November 9 Share Posted November 9 Very nice work (everywhere, on all components). I like the cool vintage-look inserts on the seats! 👍 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted November 10 Author Share Posted November 10 On 11/9/2026 at 10:29 AM, jhm said: Very nice work (everywhere, on all components). I like the cool vintage-look inserts on the seats! 👍 Thanks. I’m excited to start working on the interior. Hopefully I can get this motor in soon, then on to the inside. 1 Quote Link to comment Share on other sites More sharing options...
