Those are incredible. I'm with Mitchel on needing to know the weight difference. You gotta put them on a scale for us. Very interested in fitment and your thoughts along the way. They look like they allow for roll up windows and factory door handles too. very nice.
  • Like 1
3 hours ago, Mitchel0407 said:
I would love to see a full weight comparison between the original and carbon fiber door. I know from lugging my 280z doors around that the factory doors are quit heavy.
They are super light, I’ll get a weight on the shell this week and share, and in a few months when I get around to installing them I’ll get a full weight with windows/hardware.
Trickflows are a great choice. I have a turbo 351 so not a direct comparison but when I switched from GT40s to 11r 190s it made a massive difference.
Unrelated to the engine. I weighed my stock 280z door today. Its gutted so I can paint them. so no glass, regulator, handle, lock, hardware, window frame ext. just a empty door shell. 34lbs.
  • Like 1
  • Thanks 1
Unrelated to the engine. I weighed my stock 280z door today. Its gutted so I can paint them. so no glass, regulator, handle, lock, hardware, window frame ext. just an empty door shell. 34lbs.
Got around to weighing the door and the heads. Old heads were 50.8lbs new ones are 29lbs. The carbon fiber (shell) is 10.4lbs, looks like big weight savings.
Posted (edited)
On 4/22/2026 at 10:49 AM, 74_5.0L_Z said:
Don't forget to use sealant on the short head bolts / studs.  They go into the water jackets of the stock block.
Thanks for the reminder, I had not. That’s a couple things you’ve caught, I really appreciate it as I’m doing a lot of these things for the first time. I owe you a few beers if we ever meet up.
Took the lower bolts out one at a time, cleaned and torqued back with plenty of thread sealant. Got the second head on today too.
Edited by FastFloridian
What intake gaskets do you intend to use?
I like the FelPro 1262S3 or 1250S3 depending on the intake part size.
The S3 version of the gaskets are much more durable than the standard Felpro gaskets.
I also apply a really thin smear of Right Stuff RTV around the water jackets when I install the gaskets and lower intake.
  • Like 1
Good tip. I’ve got trickflow heads, so I got their gasket kit.
2 hours ago, 74_5.0L_Z said:
If they have the standard paper intake gaskets, throw them on the garbage and get the FelPro S3 gaskets.
No, they look really good, have a little metal in it, and have some rtv type material around all jets, not paper.
I’ve been struggling with these Apex rear axles. They require OEM 370Z axles, no aftermarket and not G37 ones. I ordered used ones on eBay, which they recommend, one wasn’t OEM because it had 6 bearings, OEM has 8. So I think I have correct axles and after struggling for a while with the side that has the internal snap ring I looked at the donor axle and the groove is deeper than the new ones. So not sure if new ones have an issue, or if I still don’t have the OEM 370Z axles. Sent Apex and email, we’ll see what they say.
Apex said that batch with the new vendor had the groove to short, they are sending some new ones. Glad it wasn’t me, was racking my brain trying to figure out what I was doing wrong.
Go the rockers and intake on today, engine is getting close to done.
  • Like 1
12 hours ago, flatout said:
engine looks great.
Really loosing confidence in APEX parts.
Most of the Apex kit has been good, a few minor fitment issues on some parts and that front bracket to attach the subframe with the hidden carriage bolts was a PIA to get in. Getting these axles has been a mess. I ordered the rear kit 8 months ago and still waiting on parts. Luckily I’ve got lots of other things in my build to work on, but if I didn’t I’d be really upset.
  • Sad 1
Flatout got a set of control arms that were made too narrow and don't fit. Apex seems to have been sending things very slowly lately and then having a low rate of good parts when they do send them.
  • Sad 2
New axle shafts came in today, woohoo. Now that’s how the snap ring is supposed to sit. Hopefully I can put them together this weekend. Also got some other goodies, push to start electronic locks and window kit.
  • Like 2
On 5/14/2026 at 7:07 AM, flatout said:
interested in the power window kit, my cage makes my window crank a bit of a challenge so i was considering a window kit aswell.
Might be a month or so before I get to it, but I’ll post updates. Figured I’m moving all the guts to the carbon fiber doors, why not see if the auto stuff will work.
Played with one of the axles last night, fitment seemed good and went together really quick when they are manufactured correctly 😅.
  • Like 2
