sharkys280 Posted May 20 Share Posted May 20 Hey guys, I'm in the process of an engine swap in my 280z. The revised motor mount makes it necessary to change up the steering linkage, does anyone have experience with using an aftermarket steering linkage kit? I'm looking at the ones that add a joint to work around the mount. Do these negatively affect the steering feel? Anything not obvious I need to keep in mind, or is it pretty straight forward? Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 20 Share Posted May 20 What engine is going in? Quote Link to comment Share on other sites More sharing options...
sharkys280 Posted May 21 Author Share Posted May 21 2jzge, single turbo Quote Link to comment Share on other sites More sharing options...
jhm Posted May 21 Share Posted May 21 On 5/19/2025 at 11:33 PM, sharkys280 said: Do these negatively affect the steering feel? Anything not obvious I need to keep in mind, or is it pretty straight forward? Lots of folks have had to adapt their steering setup for various reasons; and I haven't seen any that complained of negative issues afterwards. Most of the adaptations that I've seen have been custom fabrication; but if you've found a good kit, go for it. Main thing would be to ensure the functional hardware is good quality and the installation is solid....competent welds, stiff bracing, etc. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted May 27 Share Posted May 27 Years ago, I had to add an extra u-joint to get around my headers. I used a Sweet Manufacturing U-joint and a rod end. This was way back in 2003, so I don't remember the specific part numbers. You do need to add the rod end as an additional support. You need to align the universal joints so that they are phased properly. 1 Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted May 28 Share Posted May 28 Wow....that pic above is a great solution but is the starter really in the way on OP's car? Quote Link to comment Share on other sites More sharing options...
jhm Posted May 29 Share Posted May 29 On 5/28/2025 at 11:21 AM, HowlerMonkey said: but is the starter really in the way on OP's car? I think the OP said that the motor mount was obstructing the steering linkage. Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 30 Share Posted May 30 Here's some visual food for thought. Looks like lots of space. Maybe no problem? Found the picture on eBay. I'd share the link but they put way too much stuff in it. There's an extra T. Don't know if it matters. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted June 1 Share Posted June 1 Yeah........I remember having to pull the mount bracket out to replace a dipstick tube O'ring on many lexus and toyota cars. The aluminum brackets are pretty big and in the way. Quote Link to comment Share on other sites More sharing options...
sharkys280 Posted June 4 Author Share Posted June 4 Sorry for disappearing for a hot minute... the starter is up and out of the way, its the rubber isolator and mount bracket that end up blocking the linkage. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted June 4 Share Posted June 4 (edited) There are couple of ways that you can attack this. 1. You can add a u-joint and rod end support between the existing to get you under the motor mount. 2. You can raise the motor mount pad to allow the existing shaft to pass under. That may cause other issues like hood clearance and drive line angle. 3. You can shift the entire steering column inboard and down. I did this on my car using some 1/4" aluminum plate at the firewall and where the column bolts to the pedal box. But mine is just a race car. My seat is moved 1" closer to the centerline, and I wanted the steering wheel centered on me. Edited June 4 by 74_5.0L_Z 1 Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted June 4 Share Posted June 4 http://www.woodwardsteering.com/PDF/7. Steering Universal Joints, Splined Couplers and Shafts.pdf Quote Link to comment Share on other sites More sharing options...
tube80z Posted June 4 Share Posted June 4 6 hours ago, 74_5.0L_Z said: http://www.woodwardsteering.com/PDF/7. Steering Universal Joints, Splined Couplers and Shafts.pdf If you're using the stock rack you need the 113 u-joint listed above. You can then mix and match to any custom (weld-in, double-D, etc.) linkage between the rack and the steering coupler. 1 Quote Link to comment Share on other sites More sharing options...
sharkys280 Posted June 17 Author Share Posted June 17 Thanks for the links, saved me so much extra work. Here's the new layout, seems to operate smooth, clears everything. Hopefully I didn't miss anything important.... 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted June 17 Share Posted June 17 one last thing to do. take all of that apart and paint and detail it, K member, everything, to include the engine compartment. Quote Link to comment Share on other sites More sharing options...
sharkys280 Posted June 17 Author Share Posted June 17 Yep...on the very long list of things to do. 1 Quote Link to comment Share on other sites More sharing options...
