Lockjaw Posted October 10, 2002 Share Posted October 10, 2002 OK sds guys, how about posting some times. I want to know what kind of sds you have, and what your car runs. Thanks Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted October 10, 2002 Share Posted October 10, 2002 Don't Scottie and Turbo240 both run SDS? Scottie is capable of getting well into the 10's and Turbo beat him with an 11.26 (I think) in Montgomery. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted October 10, 2002 Author Share Posted October 10, 2002 I know Scottie does, James has an Electromotive. I know people have them, and I would like to know what they run. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted October 10, 2002 Share Posted October 10, 2002 Best time thus far 13.1 @ 110 with SDS. I am still learning to tune the car and just found out my fuel pressure plummets after 10 psi , so after the new Walbro arrives, the fun will really begin. Formerly Patrick's 240z, now Tyler's car here in Orlando ran 11.7 @ 119 on pump gas and street tires w/ stock internals and SDS. Quote Link to comment Share on other sites More sharing options...
SHANE Posted October 10, 2002 Share Posted October 10, 2002 scottie runs SDS on the buick motor??? he said something about a chip so i would think he is on the buick computer. and does'nt James run a TEC 2? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 10, 2002 Share Posted October 10, 2002 Originally posted by Lockjaw:I know Scottie does, James has an Electromotive. I know people have them, and I would like to know what they run. Scottie runs the GM computer. I believe it is loosely based on the Haltech. The confusion arises because he ran SDS on his L28ET before the GN motor swap. Quote Link to comment Share on other sites More sharing options...
rags Posted October 11, 2002 Share Posted October 11, 2002 If I remember correctly, Scottie is using a thumbwheel in the GM ECU. Quote Link to comment Share on other sites More sharing options...
Guest eric-z Posted October 11, 2002 Share Posted October 11, 2002 I could very well be wrong on this but I think stony runs sds on his RB26dett. he is pretty quick from what I hear. eric Quote Link to comment Share on other sites More sharing options...
stony Posted October 11, 2002 Share Posted October 11, 2002 11.2 @ 127 MPH on a rb26dett @ 15 PSI. With better turbos and more booste should get well into the 10s easy. Oh yea and a rearend that will withstand a clutch launch without breaking ;> Im working on a 300z stub axle swap we'll see how it goes Quote Link to comment Share on other sites More sharing options...
yo2001 Posted October 11, 2002 Share Posted October 11, 2002 Originally posted by RB26Z:11.2 @ 127 MPH on a rb26dett @ 15 PSI. With better turbos and more booste should get well into the 10s easy. Oh yea and a rearend that will withstand a clutch launch without breaking ;> Im working on a 300z stub axle swap we'll see how it goes you cheated j/k I wish I had a DOHC 24v I-6 with twin turbo. Hey, the christmas is coming up, I can cut some of the limbs off the bottom of the christmas tree so the crate of a motor and trans can fit. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted October 11, 2002 Author Share Posted October 11, 2002 Are you guys using coil packs? Or are you using the one without? Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted October 11, 2002 Share Posted October 11, 2002 Coil packs here. Quote Link to comment Share on other sites More sharing options...
SHANE Posted October 11, 2002 Share Posted October 11, 2002 coil packs, distributors are way too 1970's Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted October 14, 2002 Share Posted October 14, 2002 If you are referring to fastest turbo Z-car, it looks like Stony has the crown. Quickest car I know of belongs to Carlos, the SDS distributor here in Orlando. His RX-3/13B runs a T-70 turbo with alcohol and has a quickest time of 9.54 @ 139.6. I run the stock GM ECU with a 16-position thumbwheel chip to allow for some adjustments and an aftermarket (Buick-specific) datalogger. Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted October 17, 2002 Share Posted October 17, 2002 Last weekend - 12.9@110 with em3-6F. Coil packs and 52lb injectors. STOCK TURBO/STOCK INTERALS/12 lbs boost/supra IC/3.7 LSD. Big drag radials and ambient temps in the low 50's. Limiting factor is the turbo and IC. It's starting to get fun at the track. Cheers-Doug Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted October 17, 2002 Share Posted October 17, 2002 Doug, congrats and nice going. Wait until you see what 18psi with a hybrid turbo feels like Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 17, 2002 Share Posted October 17, 2002 Originally posted by Doug71zt:Last weekend - 12.9@110 with em3-6F. Coil packs and 52lb injectors. STOCK TURBO/STOCK INTERALS/12 lbs boost/supra IC/3.7 LSD. Big drag radials and ambient temps in the low 50's. Limiting factor is the turbo and IC. It's starting to get fun at the track. Cheers-Doug That rocks, nice going. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 21, 2002 Share Posted October 21, 2002 11.054@126.31 Nitrous turbo motor 3.0 L series stroker motor. SDS for the injection , MSD for the ign. Quote Link to comment Share on other sites More sharing options...
