74_5.0L_Z Posted Monday at 08:30 PM Share Posted Monday at 08:30 PM It's hard to tell from the pictures, but it looks like you could lower the engine quite a bit if you used a remote oil filter. 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted Tuesday at 02:44 AM Author Share Posted Tuesday at 02:44 AM On 11/9/2025 at 11:10 AM, NewZed said: I'm sure that you've considered it and I don't know what you would do to cure it if it is a problem but those engine mounts are very long lever arms. What happens if you grab the top of the engine and pull it side to side? Probably best to test it now than to wait. Even the mass of the engine in a turn will place a lot of force on them. Just something that grabs the eye from the pictures. Unusual engine mounting. Edit - fore and aft also. Much lifting force on the rear mount under braking. Fatiguing of the front crossmember engine mounting points might be a problem. It wasn't designed for that type of twisting force. And you've moved the elastic portion up to the engine at the top of the lever arm. The attachment to the crossmember is all metal. Hate to be a Debby Downer but you have access now to work on it, rather than later. well, the factory motor mount for the L series six is a solid design with a rubber pad on the bottom. I have poly bushings where the engine mounts attach to the arms coming from the crossmember. The arms are made of 3/16" steel, very thick and heavy and professionally welded. In short they won't break, and they won't bend. Twisting forces, I guess that could be an issue down the road, but if it is present, then regardless of what style is used it would be present. the style used is one that is currently used by a ton of guys running LS powered cars. If you can grab this engine at the top and pull on it, and bend those 3/16" steel plates you have balls of cast iron. In fact I would be seriously willing to wager $1,000 that you could not do so. You could take these out, put one of them on its side and stand on it and it wouldn't bend. I will allow that something could go wrong.....I'll address it when it does. I appreciate the points to ponder though. Cheers. 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted Tuesday at 02:47 AM Author Share Posted Tuesday at 02:47 AM it is the angle of the pic. Look at the one right above this. It is clear of any obstruction. Quote Link to comment Share on other sites More sharing options...
NewZed Posted Tuesday at 02:48 AM Share Posted Tuesday at 02:48 AM (edited) Did you grab the engine and see if it moves? That's all I was suggesting. Trust (your ideas). But verify (that they work). “Give me a lever long enough and a fulcrum on which to place it, and I shall move the world. ” ― Archimedes Edited Tuesday at 02:50 AM by NewZed 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted Tuesday at 04:41 PM Author Share Posted Tuesday at 04:41 PM It is as firm as a rock. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Thursday at 01:48 AM Author Share Posted Thursday at 01:48 AM Today my fiberglass smooth cowl I bought from Jhousa Ramos arrived and I got my caliper / lower strut assemblies back from welding. The cowl is really a nice clean part. JP Fiber Shop – The world of your car Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted Thursday at 04:06 PM Share Posted Thursday at 04:06 PM Those struts look really long. How much can they be shortened and still maintain sufficient travel? Quote Link to comment Share on other sites More sharing options...
A to Z Posted Thursday at 07:37 PM Author Share Posted Thursday at 07:37 PM just barely screwed them on and took a pic. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Thursday at 07:49 PM Author Share Posted Thursday at 07:49 PM I had a couple hours this morning, so I went ahead and worked some more on the layout for my brake master cylinder backing plate, and then installed my brake "parts", that divert fluid to all 4 wheels (I don't know what to call them). I used Finishing Lines for the hoses. These hoses are the new PFTE hoses that do not swell, etc. Guys are completely running brake lines in whole cars with these and they work great! I will be doing a combo of hard lines and this. Everything past the firewall back is the stock stuff. www.finishing-lines.com. They advertise a lot of Honda stuff, but they DO have our 10mm fittings etc. Great people to work with. I then went ahead and pulled the back window as part of gutting the rusty hatch out and then installing my new hatch I got form Resurrected Classics. My hood is at the sandblasters right now, should pick it up tomorrow, and then I can cut the hole and repair the spear with all metal filler a tad, as I can see some mud in it. Seriously thinking about having the hood and the deck lid powder coated gloss black to contrast the light blue metallic. Black spoiler and air dam also (they are already black, I can put a coat or two of 2K clear on them), I have glossy black flares........I will attach a pic that a guy did this with..... but the car is red.....it is giving me these ideas. Pics follow, Cheers! Quote Link to comment Share on other sites More sharing options...
jhm Posted 11 hours ago Share Posted 11 hours ago 17 hours ago, A to Z said: and then installed my brake "parts", that divert fluid to all 4 wheels (I don't know what to call them) I believe you are referring to the Proportioning Valve and the Brake Line Pressure Differential Warning Switch. Is the switch still functional (I couldn't see any wiring from those photos)? Did you decide to relocate them to the fender well for a cleaner look under-hood? If that's going to be their permanent position, I would fabricate some kind of metal shielding to protect them from road debris damage....the stock plastic inner fender liners are probably not sufficient. Good tip on the "Finishing Lines"...will check it out for sure! 👍 Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted 9 hours ago Share Posted 9 hours ago You don't really need the brake line differential pressure warning switch. It does function as a decent junction block. You are also likely to want an adjustable proportioning valve instead of the stock unit unless you plan to run stock brakes. Quote Link to comment Share on other sites More sharing options...
A to Z Posted 48 minutes ago Author Share Posted 48 minutes ago stock brakes Sir. of the two "blocks" I assume you are talking about the one with the electrical probe on there. Rather than try to figure it out, I knew I was going to run stock brakes so just copied how Nissan built it. (shrug) Quote Link to comment Share on other sites More sharing options...
A to Z Posted 47 minutes ago Author Share Posted 47 minutes ago 10 hours ago, jhm said: I believe you are referring to the Proportioning Valve and the Brake Line Pressure Differential Warning Switch. Is the switch still functional (I couldn't see any wiring from those photos)? Did you decide to relocate them to the fender well for a cleaner look under-hood? If that's going to be their permanent position, I would fabricate some kind of metal shielding to protect them from road debris damage....the stock plastic inner fender liners are probably not sufficient. Good tip on the "Finishing Lines"...will check it out for sure! 👍 Yep that is there forever home. I can cover them if needed, but this is an around town hotrod only. no wipers, my version of a cooler AC Corbra. Quote Link to comment Share on other sites More sharing options...
A to Z Posted 47 minutes ago Author Share Posted 47 minutes ago dropped off my new hatch from resurrected classics, my grille, and my 240 taillight outer panels at R&S Powdercoating for a coat of gloss black powdercoat. I had the hood sandblasted and found damage, so I ordered a new hood for Resurrect Classics, and will make my cut out and then have it powder coated gloss black as well. The car will be light metallic blue, with black hood, hatch, flares and rear spoiler/Air Dam. here is the inspiration for my change in direction: (Just picture the light metallic blue instead of red) Quote Link to comment Share on other sites More sharing options...
A to Z Posted 43 minutes ago Author Share Posted 43 minutes ago My rollpan is almost ready to ship as well. I got it from Chop Suey Hot Rod Shop, he is filling in the exhaust cut out for me. It bolts on to the rear. Quote Link to comment Share on other sites More sharing options...
