1974.5 260Z ATLAS build
06-20-2026 ATLAS Z UPDATE.  I wired the firewall forward body wiring today.  I managed to get it all done except for the fans.  I also installed the turn signal surrounds and upper and lower grill.  In doing this, I also started the run of braided line back to the water methanol tank from the nozzle up front.  The electricals for the Boost switch was also wired today into the passenger footwell of the cockpit.  I don't have a horn picked out yet, but I now have wiring ready for it.  PICS:
  • Like 1
06-21-2026 ATLAS Z UPDATE. I started with installing my side view mirrors, and then poured in the engine oil....then decided it was time to get the R200 differential and swap pieces done and out of the way.  I first had to clean up the gasket surfaces, then I installed a factory NISSAN gasket, and then filled it with 75W140 Synthetic gear oil.  Then I masked off and painted the rear cover with silver engine block paint and then a coat of clear. Tthe case itself I wire wheeled clean,t hen wiped it down and gave it a coat of clear.  After that, I painted up the 280Z mustache bar in gloss black and then after cleaning and wire wheeling it clean, I painted the front differential mount in gloss black as well, and then put all of it in the corner out of the way.  Quite a bit of work to get it all ready for install.  I will remove my existing R180 diff and then clean up the entire area like this before installing the rear end.  I also have some TT3 Techno Toy Tuning axle shafts with the Porsche 930 CV joints to put in.  PICS:
  • Like 1
06-23-2026 ATLAS Z UPDATE. Cut and fit the 4" pipe for the intake. Using a 45 degree bend, and the 90, I cut turn/twist, cut on angles, and as you can see in the pics, trim off pie cuts to get the angles going where I want them to. This requires drawing a line where the pipes have to meet and welded in just that spot. It's exactly what I did with the other pipes. After welding, the welds are sanded down smooth and then my polisher does his part to make it look like a seamless one piece unit. I also used the new air cleaner and marked where further cutting on the hood was necessary and then cleaned up those edges. later, I will spray gloss black into the cap and use some q tips to paint the cut edge and it will blend right in. I also got the call to go pick up my 3 parts I had wrapped in black DRY carbon fiber....the cowl, rear spoiler and front bumper. PICS:
  • Like 1
06-24-20226 ATLAS Z UPDATE. Yesterday I picked up my rear spoiler, cowl and front bumper from getting wrapped in dry carbon fiber vinyl. Today I mounted them. PICS:
06-28-2026 ATLAS Z UPDATE. The amount of work done today was hampered by work I needed to start on my 240Z, but I then made time to knock out a few things on the ATLAS Z today. The way my MAF meter sits in the piping is functional, but looks bad. I decided to take some left over 4" tubing, and cut it in half and form it to fit over that area, which will make it look like one solid piece, I will get it polished along with the last piece which is finished (I jsut need to go pick up and then drop off at the polishers). I then did the hood pin for my "window frame" hood. I am using one hood pin, and I bought it off of amazon, with the striker plate in black versus chrome. I then took the number decals I ordered for the car and lightly taped them on there to see what I think. They are supposed to be adhesive, but they have a weird clear coating over them I have to figure out. PICS:
07-01-2026 ATLAS Z UPDATE:  Well in between working on my other Z, I am still working on this Z car.  I went ahead and started working on getting the blue painted portions of the body ready for clear coating, and caulking the border of the carbon fiber pieces.  Initially I had planned to paint on a fresh coat of factory blue before clear, but I think I may go with the patina finish that is left after smoothing out the paint and getting it ready for the next step.  Using "Poppy's Patina" in a high gloss finish....2 coats.....apply and then the next day apply again for 2 coats is the plan for now.  This car is meant to just have fun with.  It's the project car while I have the other Z anyway.  my 240Z is giving me some timing issues to contend with so I have plenty to do.  Also put my water meth pump on some steel to start getting the ideas flowing. PICS:
  • Like 2
07-04-2026 ATLAS Z UPDATE.  HAPPY 4TH OF JULY!  I removed the front bumper and traced out and cut some spots in the carbon fiber to allow it to fit properly and re-installed the bumper.  The edges will be hidden under a thin line of black silicone caulk.  I also cut some aluminum stock I had and placed it under the intercooler and Tek screwed it down.  it is basically just helping to support the weight.  The 260Z fender emblems are on, taped to sit overnight and let the silicone cure.  The rest of the day was spent fixing the other Z car I have.  PICS:
07-05-2026 ATLAS Z UPDATE: I finished feathering out the remaining blue paint, got it nice and smooth, then blew the car off and taped up the front fender and went ahead and caulked the seams.  260Z Fender Badge placement on the fenders looks good.  Poppy's Patina Gloss arrives tomorrow, so we continue on! PICS:
07-07-2026 ATLAS Z UPDATE:  I picked up a set of carbon fiber covers for the hood inspection doors from ZOCIETY.  Many ways to attach them, I will try silicone first.  Since my inspection doors are powder coated, I will do a light scuff and then bond them on with pure silicone, taped down overnight.  By the way, they are TOP QUALITY.  $360 bucks.
07-08-2026 ATLAS Z UPDATE.  I picked up my intake pipe and MAF Meter cover plate from my polisher, J&S Polishing here in Colorado Springs today. int he pics, I just laid it in place, not installed yet. His ability to take my cobbled together crap and make it look fantastic is true magic.  PICS:
07-09-2026 ATLAS Z UPDATE:  Installed the intake piping.  You can see the inspection door covers on the car from ZOCIETY, still just laying there I haven't bonded them down yet.  Time to finish caulking in the carbon panels and then clear coat over the blue patina paint. PICS:
07-12-20206 ATLAS Z UPDATE: Well I started today by wiping down all the sections to be cleared with the Poppy's Patina Wax and Grease Remover. Then I went ahead, got my mrespirator ready and glove for my wiping hand and mixed the gloss clear and started wiping. It goes surprisingly quick...and I found that I was sicking the applicator into the paint and then then I LIGHTLY squeezed it out so that I had a lot of the applicator, but not dripping as much. As expected, there is a learning curve. After I was done and the hours went by, I could see spots I had missed. Normally you want until it is completely dry, at least 24 hours, but since I know I am sanding and adding a second coat, I mixed up, a small amount and went over the spots that were missed. Sure enough, it changed the appearance......so don't do it unless YOU KNOW you are adding another coat, which means sanding or at least using the grey scratch pads they send you to rough up the surface a hair before laying on a second coat. I wanted to get a coat of the stuff on there so the second coat later will be a true second coat everywhere. But, I am impressed. It is my intention to get a second good coat on, let it sit 24 hours, and any spots missed to then add where needed and let it sit for awhile....maybe a full week, before I sand it with 2000, 3000, 5000 grit sandpaper, and then use my buffer with the foam pad and some compound to bring it up to a smooth shine......then a good coat of wax. PICS:
07-15-2026 ATLAS Z UPDATE: Today I finished sanding the first coat of gloss clear and then prepped and applied a second coat of poppy's patina. Now 48-72 hours of cure time before color sand and buff. I also finished the work on converting the hatch lock pushbutton to a hood pin setup. PICS:
07-18-2026 ATLAS Z UPDATE:  Today was Doors Day.  I put this off for a long time, because it is just no fun. I deleted the windows for the car to lighten it up and keep it in the mindset of being basically a 4 wheeled motorcycle.  I gutted the doors out except for the door handle mechanisms, leaving the locks in....and then vacuuming the bottoms of the doors out and then taping the holes off, and then I installed my repro door "cards" I got from Hung Vu.  the Arm rests I got from Ebay and the holes left for window crank and door lock I filled with some push in plastic plugs I got off of eBay as well.  I then started on the layout for the rear window.  I am replacing the glass with Clear Polycarbonate from a company in England called Plastics4Performance (.com).  I am getting the rear window in clear, with the special hardened coating, and making it a custom order, having slots cut into it like they do for the Ferrari 488 cars (see pic).  The weight will be easily half of what the heavy glass weights, and I will lay down a layer of rubber int he window well, drop the glass in, and then with holes already drilled, bolt the window down into the hatch itself.  It should look great!  I also installed the door weatherstripping and the threshold plates.  Seems to have made a big difference looking at it after I was done today.  PICS:
07-19-2026 ATLAS Z UPDATE: I started by color sanding and buffing the tops of the fenders and the sail panels with 2000 grit, 3000 grit and 5000 grit and then used Meguires Premium Polish with my foam pad on the buffer at medium speed. Then I re-installed the side view mirrors, and re-installed the emblems and plug for the antenna hole. Then I finished the door panels by putting the latch surround trim under the door release latches on both sides. Then I took some rope and measured out the length for the serpentine belt and the remaining brake lines, which will also be PTFE braided line form "Finishing Lines". All of this took longer than it sounds. PICS:
  • Like 1
07-20-2026 ATLAS Z UPDATE:  my rocker trim I got from Ace King arrived and another ATLAS Z badge I ordered showed up as well.  Z Car Depot sent me a set of hood spacers as well.  PICS:
Ferraris have louvers in the rear because that's the engine cover rather than the rear window. I guess it will be ok as long as it never rains. Hopefully it doesn't suck in too much exhaust.
Edited by calZ
On 7/21/2026 at 12:49 AM, calZ said:
Ferrari's have louvers in the rear because that's the engine cover rather than the rear window. I guess it will be ok as long as it never rains. Hopefully it doesn't suck in too much exhaust.
LanguageResources
Well, this car is akin to an AC Cobra.  Sunny day only....around town hot rod.  I want it as open air as possible.  Mostly gutted out except for some interior bits to make it look nice.  Also the exhaust exits right behind the front wheel!
