Moth balls in gas
Has anyone ever heard of putting moth balls into the gas tank to help remove
water and to up the octane?
Little of the subject of Hybrids
Just bought an older motorhome with 440 and 1 year old tank of gas.
need to drive this beast about 80 miles to home and I do not want to emty the tank
and refill.
i know balls of a moth in gas would hurt but will it work?
Thanks
Any info would be great
-Adam
Yes, I`ve heard of it and done it. When I was younger I pulled a 22 ft camper with a 3/4 ton ford van around the state of michigan to set up sound equipement at county fairs. my boss insisted on my using moth balls in every tank to help with spark knock. There were a few times that I forgot to put them in. Believe it or not, it did make a difference. I`m not sure if moth balls still have the same properties, but it worked 15 yrs ago. ;) By the way, I ran our boat this weekend on a full tank of gas that had been in there for over 3 yrs. It ran great for about 3 hrs(untill the timing chain went out) cuss.gif
Guest Anonymous
Yeah, I'm sure the moths aren't happy about it, and look how many of them it takes. ;) Ya beat me DAW but we had the same language... :D
Regards,
Lone
My step dad used to always tell me about putting moth balls in his 427 fairlane to raise the octane. JFYI, I'm pretty sure you will need to disolve them in gas before you put them in your tank. Toluene also works good as well. Buddy of mine has had good luck with it in is WRX.
JT
Well, two bottles of 104 octane and they way it went.
The RV ran great all the way home. To my surprise the RV ran handled great also.
This thing has been sitting for two years.
Only 65,000 miles
Now can any Mopar fans or motor heads tell me the difference between a
440-1 and a 440-3 motor?
They take different spark plugs.
Thanks again
-Adam
Here's the balls ;)
  Quote
6.20 Can mothballs increase octane?
The legend of mothballs as an octane enhancer arose well before WWII when
naphthalene was used as the active ingredient. Today, the majority of
mothballs use para-dichlorobenzene in place of naphthalene, so choose
carefully if you wish to experiment :-). There have been some concerns about
the toxicity of para-dichlorobenzene, and naphthalene mothballs have again
become popular. In the 1920s, typical gasoline octane ratings were 40-60
[11], and during the 1930s and 40s, the ratings increased by approximately 20
units as alkyl leads and improved refining processes became widespread [12].
Naphthalene has a blending motor octane number of 90 [52], so the addition of
a significant amount of mothballs could increase the octane, and they were
soluble in gasoline. The amount usually required to appreciably increase the
octane also had some adverse effects. The most obvious was due to the high
melting point ( 80C ), when the fuel evaporated the naphthalene would
precipitate out, blocking jets and filters. With modern gasolines,
naphthalene is more likely to reduce the octane rating, and the amount
required for low octane fuels will also create operational and emissions
problems.
Guest bang847
  Quote
posted June 25, 2002 11:15 AM
Bang847:
I think you got a hold of a bunch of female moths! Shame on you for looking!!
It was Adam who started it!!
  Quote
Here's the balls
problems.
Hey SleeperZ, I was wondering where you quoted this from....
Also I think I will whip up a batch this week... It is a cheap A$$ present for all the gearheads friends... YUP.. MY own homemade moonshine. make yer ker Goes Fatter!!!
  Quote
Originally posted by bang847:
intersting... very interesting... but where are the balls??? twak.giftwak.giftwak.giftwak.gif
I skipped the Moth Balls because of this:
  Quote
Besides, I have easy access to large quanities of (free) Toluene.
Formula #1 - Toluene
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
