scottyMIz Posted July 30, 2003 Share Posted July 30, 2003 I was just wondering who has them on their car still and if they are important enuf not to remove them from the car.I still have mine and it looks like it's been thru a war and back was thinking of takingif off and didn't want to screw anything up. Quote Link to comment Share on other sites More sharing options...
jeffp Posted July 30, 2003 Share Posted July 30, 2003 The damper significantly reduces the pulsation that occures in the fuel rail from the injectors opening and closing. Without the damper you will have a very hard time getting the fuel management to do its job effectivly. The idea here is to keep as constant pressure at the inlet of the injector as possible so that it will deliver a consistant amount of fuel each time the injector opens. Some of the new cars run two dampers, and I think that is not a bad idea. There is a company that has made a ball type damper that I have considered installing on my car as well. You can find them on the web if you do a search for fuel damper. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted July 30, 2003 Share Posted July 30, 2003 I've examined my fairly closely, and it is not in the least restrictive. You can see daylight through the thing - it just has a spring loaded diaphragm inside to smooth out pressure pulses. If yours is bad, it's way easy to pull one off another car in the scrapyard.... Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted July 30, 2003 Share Posted July 30, 2003 Is the NA damper the same as the turbo damper? I don't have one on my car right now. I just have a filter before the fuel pump. I'm wondering if not having a fuel damper is causing my top end problems. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted July 30, 2003 Share Posted July 30, 2003 Is the NA damper the same as the turbo damper? I don't have one on my car right now. I just have a filter before the fuel pump. I'm wondering if not having a fuel damper is causing my top end problems. I'm using the N/A dampener. They are the same size, about 5/16". Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted July 31, 2003 Author Share Posted July 31, 2003 ok thanks guys just wondering how important it was and if i should take it off or not i'll keep i til it dies Then i'll get another to replace that one. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 31, 2003 Share Posted July 31, 2003 Hmm, I'm not using a damper of any type... I have a bit of a 'hiccup' every once in a while, under light throttle cruising. Anyone done any comparisons before/after? Quote Link to comment Share on other sites More sharing options...
z-ya Posted August 1, 2003 Share Posted August 1, 2003 I get the same occasional hickup during light throttle cruising too, and I'm also not running a damper. Hmmmm.... Pete Quote Link to comment Share on other sites More sharing options...
yo2001 Posted August 1, 2003 Share Posted August 1, 2003 SOme of the hick up is from the dampner I'm sure but I get hick up with my BOV flattering every now and then. Quote Link to comment Share on other sites More sharing options...
fl327 Posted August 1, 2003 Share Posted August 1, 2003 I left the damper in place when i did the swap (stock 280z damper) no hiccups then. I did pick up a hiccup when i pushed down plug gap to 35 and messed with timing a little...hmmm? Quote Link to comment Share on other sites More sharing options...
yo2001 Posted August 1, 2003 Share Posted August 1, 2003 that's from weak sparks. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted August 5, 2003 Share Posted August 5, 2003 never used it and most modded L28ETs with aftermarket pumps do not. No problems that I ever heard of. Quote Link to comment Share on other sites More sharing options...
bumble zee Posted August 10, 2003 Share Posted August 10, 2003 im not running a dampener... mine ran fine. Quote Link to comment Share on other sites More sharing options...
