Stock L28 Turbo intake manifold stuff
On the stock intake manifold there is a bunch of just polution stuff and the BOV. I was talking to a z car spiecialist (sold me the eng) and he said that what alot of people do is shave off all of that stuff off the top keeping the BOV. I was wondering what yall have done with that stuff (kept it or got rid of it) :confused2:
Another Question : what do i need to do (modify) to reach 350 RWHP?
Thanks
Fred
The "BOV" you speak of isn't a blow-off valve at all. It is a pop-off valve. (POV?) And it has a distinctly different purpose than the BOV, though the mechanicals are similar.
The POV vents the intake in case of overboosting, this helps prevent engine damage. Can be replaced with a 1" pipe plug if you are upping the boost.
The BOV vents the tube leading into the intake before the throttle body when the TB is closed, so that the negative pressure wave reflecting off the TB doesn't collide with the turbine wheels and cause the turbo to slow down. This can make your car faster, as you don't have to wait quite as long after a shift for the turbo to spool again.
Thanks
Fred
There are a number of threads you can search for the answers to that question. There were 2 distinct threads this summer on this exact subject.
The short answer depending on your budget : fuel management, big fuel system, intercooler, big a$$ turbo, exhaust, body reinforcement, better brakes, and a good motor and driveline, with HD clutch. Same as any turbo car, I could have written that for any number of target vehicles.
