P90 and P90A cam same?
Ivan280zt
This is new to me about the difference in cams between P90A and P90. Yo, how did you find this out?
I have a Nissan re-manufactured L28ET in my Z, with a P90A with solid pivots. Makes me curious how I can optimize my setup...
FL327, I'm not sure how the difference in the '83 inital ignition timing advance has to do with a camshaft timing difference, but given Yo's info about camshaft timing, they could be related I suppose.
I have my cam timed straight-up, and I plan to swap on my old P90 soon, but I may play a little with initial ignition timing.
Cody - i believe only the '83's are 24* and both the '81 & '82 are 20*. Wish i had my cam out of my '82L28ET P90 right now because i have my cousins '83L28ET P90a cam sitting on the bench. I could've snapped some comparison pics of it to post. If i can find some good shots of a P90 cam on the net, i'll try and duplicate the picture using the same angle of the P90a cam.
There are 3 turbo cams. Look on the back of the cam for a letter stamped there. The J grind is 81-82 manual transmission, B grind is 81-82 auto, and the M is 83 manual and auto.
There is not enough difference in them to matter, but for what it is worth, I was running the B grind, and have not come across a J yet.
All 3 cams are interchangeable. Where you run into issues is using an aftermarket cam with a hydraulic (note proper spelling) head. Unless everything is just right, get ready to buy a new cam.
