PUSHER Posted January 7, 2005 Share Posted January 7, 2005 I know i've asked like 17 lsd questions but humour me please. If I bought an lsd for a r200 on a 240sx, what would I have to do to get it to work in my r200 on my datsun? Will it just not physically fit? wont bolt up to gear? mix n match stuff? Stupid question, appreciate your time on an answer. Quote Link to comment Share on other sites More sharing options...
2126 Posted January 7, 2005 Share Posted January 7, 2005 Install it, as it will work, and get on down the road. If you've never set-up a differential before, take it to a qualified mechanic....if not you may find that you will be spending more money than you originally intended. Again, R200 carriers will work in other R200s. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 7, 2005 Share Posted January 7, 2005 The major issue will be your halfshaft input spline matching up with whats inside the new carrier... Quote Link to comment Share on other sites More sharing options...
PUSHER Posted January 8, 2005 Author Share Posted January 8, 2005 So thats 1 yes, and 1 it could work? Anyone with a more definate answer? I'm pretty sure it isnt just a bolt in and am wondering what is required for it to bolt in and work. Quote Link to comment Share on other sites More sharing options...
2126 Posted January 10, 2005 Share Posted January 10, 2005 Pusher, The LSD carrier will fit into the R200 housing, but as J. Soileau mentioned, the number of splines is at question. Count the number of splines on your half shaft input (into diff) and find out if they will match the LSD carrier. If they have the same spline count, your in business. It's likely to be 29 splines. Quote Link to comment Share on other sites More sharing options...
EZ-E Posted January 10, 2005 Share Posted January 10, 2005 They will fit, what Im not sure of is if they will work the the half shafts, as the others have said. I know for fact that 240sx users that have gone turbo use the 87 LSD in there case. So I dont see why it wouldnt fit. Its just what axles will you need. I dont know if the CV's for teh 240sx are the same as the 280zx 300zx. Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted January 11, 2005 Share Posted January 11, 2005 This has been beat to death. Use the search function and search for a "viscous lsd" I think you will find the what you want to know. Don The search function seams to only go back one month? Still the info is in there. Quote Link to comment Share on other sites More sharing options...
5foot2 Posted January 11, 2005 Share Posted January 11, 2005 This has been beat to death. Use the search function and search for a "viscous lsd" I think you will find the what you want to know. Don The search function seams to only go back one month? Still the info is in there. Try the search you suggested. 4-5 Threads return "viscous lsd", including this one. If this forum has lost that much data, maybe we should cover some of these things again. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 11, 2005 Share Posted January 11, 2005 Searched the drivetrain forum for "240sx" and found these: http://forums.hybridz.org/showthread.php?t=92808&highlight=240sx http://forums.hybridz.org/showthread.php?t=72261&highlight=240sx Quote Link to comment Share on other sites More sharing options...
