KA 5 gear swap using Z bellhousing; The low down...
datsunlover
So i could take any bellhousing from 70-83 and it would bolt up to the l28 and a KA tranny? That sounds too easy to me.
Your intuition is correct. From my understanding, it "will" bolt up, but the distance for the clutch assembly won't be right.
Feel free to correct me if I'm wrong. :P
  • Replies 59
"front case" not "bellhousing", and yes, with the bearing swap and the one hole enlarged, and in same cases a tiny bit of internal case clearancing yes it bolts one, and yes it can use the stock clutch!, fork and t/o bearing, even the slave
  • 10 months later...
Ok, didn't want to bring up an old thread but it seemed the best way to get the correct answer from people who have done this swap.
will the completed KA transmission assembly line up with the stock rear tranny mounts for the crossmember on a 78' 280Z using a 78' 4 speed bellhousing? i am working on all the little things under the car right now before i sandblast it and coat it with por-15. the reason i ask is because i plan on setting my engine back 4-8 inches and i need to know if i need to move the tranny mounts accordingly or if i need to offset them a little in either direction?
any help is appreciated. thanks,
Brady
no, the trans crossmember has to be reshaped a bit, the ka trans sits at a bit of an angle towards the passanger, and in the series one chassis the mount had to be moved back about 1.5" not sure ont he later chassis, it actually worked otu the same and the T5 I upgraded to alter, as for moving things back, I guess you are cutting out he firewall?
thanks, that is helpful. i guess it really won't matter in the end. i am doing the transmission mounts now and i will position the engine mounts accordingly as i install it. but it's nice to know what to expect.
so it does still use the same type of transmission crossmember i take it?
yeah, i will be cutting out a small portion of the firewall above the transmission tunnel, no more heater so that will be easier. i know you can move 4" back without cutting so i will have to cut 4" out of the firewall at most. just a pocket for the head and bellhousing to fit into and still get a allen wrench into the valve cover bolts.
  • 4 weeks later...
I also have a question on this, but the other way around.
KA+ L28 5speed.
Reason= Its what I have.
Question: On a L28+ KA tranny swap, whats the distance needed to be milled or adapter plate/spacer for the bell housing? So I can space or mill accordingly for my odd combo.
I see no reason why you can't reverse the swap assuming you have a 5 speed L28 trans otherwise the selector shaft for reverse won't be large enough diameter
and the L28 KA swap requires no adapter plate, go back and read this thread, it's covered in detail
  • 2 months later...
Digging up an old thread, seemed the only one pertinent to this swap.
Can someone that's done this swap post a pic of their trans mount modifications? A few posts back someone said it had to be "reshaped". Will that involve cutting welding or drilling, or just some bending? I need to know what I'm getting myself into if I pick up a KA tranny.
I have a whole album on my motortopia.com page dedicated to this swap with lots of pictures and detailed info on just about everything you'd want to know (click the picture):
When you are are searching for a transmission, try to get one from an S14. From what I've found out, they have the widest gears and a dual cone synchro on 2nd.
Nigel
  • 3 weeks later...
I'm in the middle of this swap, and thought I'd bring up another issue a member mentioned to me.
People were talking on here about "swapping" the bearing from the L to the KA gearset. Apparently, when you pull a bearing off with a puller, it pulls on the outer race and destroys it. So, a new bearing is needed (nobody in my town had it in stock). Just an FYI
Hmm... I've pulled a few and never seen any obvious damage as a result. But I was pulling them to replace them with new bearings...
Nigel
Im the one that told him that. Its not really noticeable to the naked eye but it does put little divots on the bearings and the races. its just standard practice in the mechanic field to replace a bearing for this reason when you have to pull it using the outer race.
For the cost of a bearing, it makes sense to use a new one anyway...
Nigel
Well the machining is done, the tranny is together, and I'm picking up my driveshaft later today.
After reading some stuff on this thread and not thinking about the difference between the long (750mm) and short (700mm) driveshafts, I had them shorten my long one 1.5" (they didn't know how much 50mm was, lol).
I remember someone here saying they shortened theirs 3/4", and someone else 50mm, so I figured 1.5" would be fine (not reading that they STARTED with a short one for the 3/4", and a long one for 50mm). Oops.
So, my driveshaft will be just short of 712mm. I sure hope that will fit. Worse comes to worse I guess I can cut down the yoke a little, but I REALLY don't want to do that after them balancing the thing.
Actually, 50mm is ~2". I think 1.5" will still work, but it might be tight. The early Z shaft I used is 50mm shorter and it worked perfectly...
Nigel
'73 240ZT
It worked, thank god.
Hopefully there are no ill-effects of removing that collar.
So, for further reference:
If you have the longer 750mm driveshaft, SHORTEN IT 50mm or 2 inches
If you have the shorter 700mm driveshaft, IT WILL FIT
Well, I'm glad to hear that that worked out for you in the end...
Nigel
'73 240ZT
