1/4 mile times
Guest 83supaZ
Guest 83supaZ
i see ppl in the inline 6 forums posting they have around 190rwhp and are running 13-15 1/4 mile times... so what the heck are ppl with the 450 hp 383 strokers or 400sbc's running? mid to high 10's?
My 71 240 with 350cid and N20 has run 10.7 at 135mph (6.9 at 110mph 1/8 mile) with drag slicks but stock R200 diffs and axles don't last more than 10 passes. It not fun when parts keep breaking. I feel low 12's/high 11's are about it for the stock Z rear end components if durability is an issue.
Guest 83supaZ
so if im going to take a v8 datsun to the track any.. it would be in my best intrest to get a 300zx rear? what is it a r230? and.. am i correct in that rear isnt independent suspension?
Over the edge 357 ci, powerglide, 9 inch ford, 9 inch slicks, traction limited, 10.50's at 136mph smoking the slicks off the line past the 60 ft mark while pedaling it. I'm going to play with spring rates in the coil overs as well as tire pressure, but it looks like a backhalf job is upcoming so I can stuff some 17x33's under it. I think if it hooks up, it'll be in the 9's at 5300 ft elevation and lower 9's elsewhere.
Well, when my boy bought the 260z in AZ last August, it had inspection stickers from Phoenix firebird raceway. He had timeslips and said that it had a completely bone stock 350 with a th350 auto, no stall, 4.56 gears in the nine inch rear, and it ran 13.20 at 105mph. Not too shabby, enough to blow most cars in the weeds.
9.7:1 compression 327 SBC, 274/280 adv. duration, 236/242 duration @.050, 2.02/1.60 pocket ported camel hump 461 heads, Holley Dual plane, 700 cfm Holley Pro-Jection, blockhuggers through 2.5" duals, Tremec TR-3550, 3.7:1 LSD, 255/40-17 Toyo Proxes RA-1 tires, rookie driver:
12.78 @ 110.4 - near sea level (Capital Raceway, Crofton MD)
I estimate that at 375hp at the crank, working back from the MPH and 15% driveline losses.
Seems slow now.
TT383 Chevy blowing through carb, no intercooler,TH400 trans, 9" Ford rear, Full exhaust system with mufflers, street slicks...... "street legal"(emission exempt).
Quarter Mile ....10 psi.......10.29/137 mph.
1/8 th Mile ......15 psi........6.33/116 mph......no traction first 60 ft.
Getting kicked out for not having competition license & certified rollcage........
"Priceless"
Guest 83supaZ
well here's my setup.. most of the parts are in.. still waiting on a few.
350 block w/machine work completed bored .040" over
350 stroker crank 3.75" stroke making it a 383
5.7" eagle sir i-beam rods w/arp cap screws
KB hyper's for 383.. flattop making about 9.6:1 compression w/76cc heads
melling oil pump
lunati cam adv duration 285 lift .507/.524 lobe sep 110
stock heads.. have porting done to produce extra 30 hp
valvetrain upgraded
700r4 automatic tranny w/2400 stall and b&m shift kit
edelbrock performer rpm intake
holley 750 vacuum secondary double pumper carb
as of now... r200 rear from 83 280zx
all in a 83 280zx coupe
what kind of time you guys think ill be running?
Totally stock LS1 except edited ECM, K&N intake & headers. T56 through 3.70:1 R200 LSD and Yokohama 225/50-16 street tires. 12.9@110 best run. Traction limited so only got 2.0 60' and exhaust limited on upper end because only a single 2.5" exhaust at the time. It has dual 2.5" now but no recent runs.
