ZROSSA Posted July 12, 2005 Share Posted July 12, 2005 Hey Tim, What about the 3.0 lt toyota truck engine. 3..... something. There was a post on it earlyer on this site. Sounds very strong. Douglas Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 12, 2005 Author Share Posted July 12, 2005 Doug...hard to come by and very pricey. Wayyy overkill too.....remember, this is a tiny car! Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted July 12, 2005 Share Posted July 12, 2005 Wow, that was fast. Here is the link http://forums.hybridz.org/showthread.php?t=99561 Guess you have already seen it. I would double check all the 4 banger truck engines. Torque is fun no matter how light the car is. Always did like those opels. Only ever seen one here in NZ and it was a left hooker. Douglas Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 12, 2005 Author Share Posted July 12, 2005 Doug, Do you know: Does the 3RZ engines bolt up to the 2x4 2RZ trannys? Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted July 12, 2005 Share Posted July 12, 2005 Should do, Blocks the same. I will do a double check. Heading into town today so I will stop buy a dealer with a tape meassure as well. Douglas Quote Link to comment Share on other sites More sharing options...
MrWOT Posted July 12, 2005 Share Posted July 12, 2005 Heh I always wanted to turbo a 3RZ, with 2.7L imagine the torque Quote Link to comment Share on other sites More sharing options...
Bartman Posted July 13, 2005 Share Posted July 13, 2005 Tim, Have you checked out the opelgt web site? They have a forum on engine swaps http://www.opelgt.com/forums/forumdisplay.php?f=1124 Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 13, 2005 Author Share Posted July 13, 2005 I am a member of that Opel board. The GT is VERY narrow and the oem torque tube diff is pretty damn weak. Pretty much anything over 150hp is gonna grenade it (~200hp with a LSD) There is nothing else that will work easily due to the narrow track. The Isuzu impulse diff can be swapped in easily, but the strength is no better, but does have disk brakes. Late 70s 3 series BMW is also an option...... Thanks Bart.....looked through those....been a member for quite a bit... Quote Link to comment Share on other sites More sharing options...
johnc Posted July 13, 2005 Share Posted July 13, 2005 Volvo B21. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 13, 2005 Author Share Posted July 13, 2005 Volvo B21. Hmmmm....Interesting....but then why not the B23? Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted July 13, 2005 Share Posted July 13, 2005 Went to the local toyota dealer. The parts guy said the 2x4 trans should bolt straight up. I wouldnt take that as gospel though. These guys were real wankers. Couldnt be bothered looking up numbers to double check. There wasnt any 3rz's in the yard. Turbo diesels rule the roost here. Whole episode left me feeling like never buying a toyota again despite haveing owned or raced one or more for the last 20 odd years. Douglas Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 13, 2005 Author Share Posted July 13, 2005 Hey, thanks a bunch for checking it out, Doug!!! Last time I went to a Nissan dealer to talk to them about the whole R200 vs R230 thing.....I will never buy a Nissan/Infinity from those monkeys either!!!!!!1 Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted July 13, 2005 Share Posted July 13, 2005 honda s2000 engine trans if you can find a totalled car.mazda rotary 13bwould work.a local guy around here a a lotus7 kit car with a s2000 motor in it-it hauls. Quote Link to comment Share on other sites More sharing options...
johnc Posted July 13, 2005 Share Posted July 13, 2005 B23 is good too, but the B21 should be cheaper in the junkyards. Quote Link to comment Share on other sites More sharing options...
Oleh Posted July 13, 2005 Share Posted July 13, 2005 Out of those two engines, definetly go with a KA24DE. Its a great engine. Strong, and reliable. idk anything about the other engine. but the KA, in N/A form will make upwards of 220-240rhwp on motor w/o juice. With a turbo, you can manage 350rhwp on stock block, so anywhere from 10-12psi, maybe even 14psi on a T3/T4. The only problem with the KA is the weak ringland. They will blow after 1bar (14-15psi). If you run forged pistons ( many choices, Supertech, Weisco, Ross,) Forged Rods ( Aries handle up to 700rhwp), you should be able to make around 500-600rhwp with 25-30psi on a big turbo. You can run a T66 a SC61 a T3/T4Oe. The head, stock flows pretty well. On N/A cams you can make decent power, If your cheap, swap in a altima's intake cam so you'll get 248/248. Anyways, if your going with a 4 cyl, definetly go with a KA24. If your going for a high revving car, get a 3rotor, 13B, plenty fast with a turbo. Also, dont get a S2000 motor because it would take a shitload of money to make it fast, if you put I/H/E you could actually lose power on it. Quote Link to comment Share on other sites More sharing options...
Guest Champster Posted July 13, 2005 Share Posted July 13, 2005 Crate Motor and Rebuild Companies http://www.tophatperformance.com/cratemotors.html www.phatka-t.com Ivan at Phatka-t had their project s13 put down 638rwhp and 599ft.lbs torque with a GT35 turbo, Arias forged pistons and Crower rods. Tuning was done with AEM EMS. Quote Link to comment Share on other sites More sharing options...
Guest Champster Posted July 13, 2005 Share Posted July 13, 2005 www.phatka-t.com/images/638rwhpka.jpg Quote Link to comment Share on other sites More sharing options...
Deep Posted July 13, 2005 Share Posted July 13, 2005 Have you considered the Toyota 4AG 20V? Its a 1.6L four rated at between 170 (silvertop) and 185HP (blacktop) and bolts up to a T50 RWD tranny. The only problem is that you'd need to either fab a new intake manifold or cut and reweld the TB on the opposite side to fit it for RWD. Its a somewhat popular swap for RWD Corollas, so there is info out there on how to get it to all work. Its a pretty trick engine that comes stock with ITBs, VVTi, crazy high redline and good aftermarket support. In an 1800lbs car, I think it would work well. They're cheap too. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 13, 2005 Author Share Posted July 13, 2005 Are they US Dometic available, or are they JDM only? I need something very available....and again...power and speed are not the over-riding consideration. Cheap, easy and relaible is what I'm looking for. The TT V8 in the Z will be my HP toy. Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted July 13, 2005 Share Posted July 13, 2005 Hey, Tim kinda off the topic of the engine /transmission, but would do us a favor and post some pics of the car/engine bay to give a better understanding of size restraints you have. Not that any hybridz had a problem with fitment issues. Tyson Quote Link to comment Share on other sites More sharing options...
