Dnaught14 Posted July 17, 2005 Share Posted July 17, 2005 I know people have talked about these engines, but has anyone done this swap. The engine would be out of a bonneville or monte carlo, they also have them in the buick rivera and can be had for 400-500 dollars with hardly any miles on them. The make 240hp and can be converted to use a t5 with a belhousing adapter. I also know that they have a weak bottom end, but if you were planning for no more than 300hp, i dont see the issue, and instead see a low cost swap. Let me know what you think, i have become curious. Quote Link to comment Share on other sites More sharing options...
Dnaught14 Posted July 18, 2005 Author Share Posted July 18, 2005 I realized that put pobiac instead of pontiac. I feel like a retard. Any thoughts though? I'm going to do more research. Quote Link to comment Share on other sites More sharing options...
johnc Posted July 18, 2005 Share Posted July 18, 2005 No ones done it that I know of but there have been some discussions on this board. Try a search on the GM 3.8 or 3800. Quote Link to comment Share on other sites More sharing options...
Dnaught14 Posted July 18, 2005 Author Share Posted July 18, 2005 I looked throught the forum for about an hour. It seems like the general concensus is that this would make a good daiey driver. I figure you turn the boost up with a smaller pulley and some basic mods, youd be closer to 250, 260 and the engine and mods required owuld be under 1200 dollars. The wiring would prolly suck, and fabbing mounts for the engine and transmission would be needed, but other than that it sounds good. Why hasnt anyone done this swap? I am puzzled. Quote Link to comment Share on other sites More sharing options...
Greg55_99 Posted July 19, 2005 Share Posted July 19, 2005 Go here for info: http://l67swap.com/forum/viewforum.php?f=15&sid=33a0722fc5166d548c7b8c3ad841d21c Greg Quote Link to comment Share on other sites More sharing options...
Calico Posted August 6, 2008 Share Posted August 6, 2008 link didnt work Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted August 6, 2008 Share Posted August 6, 2008 Probably b/c it's 3 years old. Don't think anyone has done the 3800 swap yet that i've seen, but there are several people rocking the M90 superchargers on the L28. Quote Link to comment Share on other sites More sharing options...
janaka Posted August 6, 2008 Share Posted August 6, 2008 bottom ends in the 3.8L series II or III is not weak by any means. These are basically a built proof motor if mods are done right to them. I know more than a handful of friends of mine in the 11's and 12's with this motors either SC'd or Turbo'd. one of the Top 10 motors ever. Quote Link to comment Share on other sites More sharing options...
Quin Posted August 6, 2008 Share Posted August 6, 2008 I was under the impression that the intake would be aimed directly at the firewall with very minimal clearance in a RWD configuration (hence why every guy with a V6 f-body with exhaust doesn't have a blower too)... Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted August 6, 2008 Share Posted August 6, 2008 It would, but if you're custom mounting the motor anyway, you could probably figure something out. Also, the Aussie holden superchargers work around this problem nicely. Quote Link to comment Share on other sites More sharing options...
Calico Posted August 13, 2008 Share Posted August 13, 2008 yeah i know about the turbo sway, someone actually swapped a series II motor in an 87 buick grand national. he says the turboed series II is actually much smoother and over all better. I was thinking.... l67 block(supercharged Gtp) l36 heads (off 3.8 98 +f-body) 97 intake manifolds off fbody 97 throttle body 4l60e trans from v6 fbody *custom driveshaft* *custom downpipe* turbo *custom header* modify wiring harness from GTP?? GTP Ecm? swapped in a s130 chassis Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted August 13, 2008 Share Posted August 13, 2008 Sounds like a winner, definitely unique. While you're at it you might as well upgrade to the northstar throttle body too. Would be nice to find a newer block too, for the forged rods (02+?). Couldn't hurt. Might be fun to megasquirt a series III... hmm Quote Link to comment Share on other sites More sharing options...
