Cleaning Tail Lights (pics)
240hoke
Hey guys,
My tail lights like just about every body elses were really dark. Anyway I desided to clean them up and im really happy with the results.
First of all just polishing the outside doesnt do it, soot fills up the inside of the tail lights and makes them look really dark.
1.) Carefully go around the lense with a screwdriver prying it up out of the plastic housing. Go very very slowly here, dont want to crack anything. A helper is a good idea. Once they are free clean up the gluee from teh lenses.
2.) Once the lenses are off you can really see the soot built up on the inside! I used 409 to clean the soot out.
3.) Polish up the lenses with a plastic restorer, I used 3M marine clear plastic restorer, You can get it at west marine or any boat store.
4.) Wash the lenses again to get all the polish off and let them dry
5.) Use a adhesive to glue the lenses back together. I chose to use a genral contractor adhesive (subfloor adhesive) jsut because I had it around and it bond pretty much anything.
6.) Arent they pretty??
This was the best housing, from teh passenger side, you can see the soot buildup here, not nearly as bad as teh drivers side.
Here are the lenses all cleaned up and ready to be glued back into place.
Here is a before and after picture.
and another
Hope this helps some people
Nice Info, Looks much better almost new.
I found an easy way to get the lens seperated from the housing,
I set my oven (a regular kitchen oven I use for powdercoating) to about 200 degrees or so and put the taillight on a piece of cardboard on the middle rack , after about 20 to 30 seconds pull it out and test prying up the lens the heat softens the caulk, you may have to keep popping it in the oven till it softens enough to get the lens off easily, after the lens is off clean the goo out of the housing with a small screwdriver , popping it in and out of the oven to keep the adheasive soft.
Ive heard of throwing them in the oven as well, alot of honda guys do that to seperate the headlight housings so they can "black out" the inside. Just gotta be carefull not to let it get too hot. My friend ruined one of his headlights setting the oven too high go figure lol.
  • 4 years later...
How I did my 240 tails:
1) Remove the chrome strip, a one way lock washer in the back of the housing must be removed, is deep in a recess of the housing, if you break it, and you probably will due to where its placed, don't worry, the trim can be glued back.
2) Just place the tailight under the kitchen faucet and let the hot water run for a few minutes, it will soften the sealant enought to pull the lens off.
3) Wash, clean and polish the lens I used a drill mounted polishing wheel and some turtle wax, if there are deep scratches, sand with 600 grit all the way to 1500 grit then polish at slow speed and constant movement otherwise you will burn the plastic.
4) On the bottom of the housing and the bottom of the lenses there are two drain notches, these should have a small piece of foam to keep the inside free of dust. If they are damaged or missing, get a foam paint brush (the throw away kind) and cut small pieces to fit the notch and deep enought to get caught by the lens but not compressed too much that it will not drain ant humidity insude the housing.
5) go to Home Depot and in the roofing section there is a metal roof seam sealer, Its a roll of a white sticky mastic tape about 1/2 in wide (its rolled onto a disposable waxed paper strip. (I will try to get the SKU from the Depot) its only about $5.00
6) Apply the sealer onto the lens edge all the way around except where the notches are.
7) Make sure everything is clean and free of debris, bring the lens to the housing align and press then clamp with your hands around the edges as hard as you can (don't press against a hard surface, you will break the housing or lens)
8) Clean and polish the chrome trim (use a chrome polish such as Flitz)
9) Glue trim piece back on. I used double faced foam tape the kind used on auto trim available at any auto parts store (it usually has a red protective tape, but ask anyway)
OK then I'll yell at giorgio61 for bringing it back a month too late. :burnout:
It's not one of those things I even thought about doing until I saw this thread tonight. I suppose it's not a bad idea to clean the rear end after 30 or so years. :-)
I've been married so long, I don't even look for dates anymore!
  Quote
I got the info on the tail light assembly (lens to housing) sealer.
Its called Roof Strip Mastic and it comes in a whooping 45' roll but its only $4.98 at Home Depot SKU 714021.
Anyway I found its also great to seal loose rubber body plugs, hold screws in the screw driver and a many other uses!
