johnc Posted October 27, 2005 Share Posted October 27, 2005 Nissan Type A 4 Speed Weight: 70 lbs. Length (bellhousing to end of tailshaft housing): 31" Shifter position (bellhousing to center pivot): 31" Nissan Type B 4 Speed Weight: 72 lbs. Length (bellhousing to end of tailshaft housing): 31" Shifter position (bellhousing to center pivot): 29" G-Force T5 5 speed Weight: 101 lbs. Length (bellhousing to end of tailshaft housing): 31.5" Shifter position (bellhousing to center pivot): 29" - aftermarket Long shifter Link to comment Share on other sites More sharing options...
rudypoochris Posted December 29, 2005 Share Posted December 29, 2005 Thanks! Would you mind posting what year cars the different tannies came in. I believe the two 4 speeds are 240's and the type B was a redesign for a different length driveshaft with a different style U-joint (i think) and new location of the post Series 1 consol, or something of the sort. The 5-speed came in 280zx and beyond??? Thanks again. Link to comment Share on other sites More sharing options...
rags Posted May 23, 2006 Share Posted May 23, 2006 John, Do you have info on the z32 and z33 tran's? Weight, lenght, etc... Also, do the VQ and VG motors use the same bolt pattern for the the bell housing? Thanks. Joe Link to comment Share on other sites More sharing options...
johnc Posted May 23, 2006 Author Share Posted May 23, 2006 The Type A 4 speed came in the Series 1 240Z although I don't know when the cutoff was. They are easy to identify because they have a separate bellhousing. The Type B 4 was available from the 240Z through the 280Z. The T-5 was installed in the 280ZX turbos. I don't have dimensions on the Z32 and Z33 transmissions. Link to comment Share on other sites More sharing options...
240hoke Posted May 24, 2006 Share Posted May 24, 2006 I have a z32 transmission sitting out in the garage waiting for my adaptor. Ill try and weigh it for you guys. Its certainly more beefy then the stock unit!!!! And just a head up for those of you looking to do the swap, you can get a z32 trans for cheap. I picked up mine with 88K miles and very clean for 300 bucks including hte shifter assymbly. They are known to hold over 600hp. Alrighty here are the deminsions, Z32 Manual Transmission: Length (bellhousing to tailhousing): 30.25" Shifter Position (bellhousing to center pivot): 34.5" Trans MOunt position (bellhousing to center of mount): 24.5" *z32 Shifter is straight up and down unlike the shifters on the first gen trannies which slope back towards you so this helps offset the shifter location diffference. Link to comment Share on other sites More sharing options...
mom'sZ Posted September 11, 2006 Share Posted September 11, 2006 Does anyone know the bellhousing to end of tailshaft housing length for the early 5-speed? The one that came in 280Zs? Is it the same as the type B 4 speed? Do the drive shafts interchange between the type B 4 speed and the early 5 speed ?(280Z not ZX) Link to comment Share on other sites More sharing options...
COZY Z COLE Posted September 11, 2006 Share Posted September 11, 2006 mom said: Do the drive shafts interchange between the type B 4 speed and the early 5 speed ?(280Z not ZX) Driveshafts can be interchanged between A and B and early 4 and 5 speed trannies. Shifters can not be. Early Trannies.... F4W71A "A" type 4 speed.... Build date 69-8/71. F4W71B "B" type 4 speed.... Build date 9/71-76. FS5W71B "B" type 5 speed....77-78 280Z and 79 280ZX. LARRY Link to comment Share on other sites More sharing options...
JMortensen Posted September 11, 2006 Share Posted September 11, 2006 I think you're wrong there Larry, but in a weird way. The 69-71 diff was mounted 1" forward from the later cars, so the driveshaft for the 70 and 71 cars is 1" shorter. While it will plug on and probably work on a later car, the correct shaft for a later car would be the longer 72-78 shaft. I know this to be true because I moved the diff back on my 70 to correct the halfshaft angles and went and got a longer shaft for it at that time. So to answer mom'sZ's question, the 72-78 shafts are all the same as far as I know, and the length is correct for any A or B type 5 speed (including NA 280ZX). I suspect that if someone were misguided enough to put the crappy early 4 speed in a later car the later shaft would be the correct one in that case as well. Link to comment Share on other sites More sharing options...
cybermecium Posted April 15, 2007 Share Posted April 15, 2007 What 5speed transmission was used in the 80 280ZX NA? Is there a difference in splines from tranny to tranny? thanks Link to comment Share on other sites More sharing options...
jonus079 Posted April 19, 2007 Share Posted April 19, 2007 any info on a t56?? Link to comment Share on other sites More sharing options...
Six_Shooter Posted March 14, 2008 Share Posted March 14, 2008 Doing some searching on the manual trannies to night, since I may have a 4 speed to go in my car instead of a 5 speed. The reason I say this is because I was going through the gears with the tranny sitting on the floor and could not find a 5th gear, I thought I did, once, but every time after that, I could only find 4 gears. Is there anyway to tell? I could not find any markings, or numbers on the tranny case to identify it. I also see on THIS page that the 280Z, not ZX could also come with a 5-speed. I know this tranny came out of a 280Z, and was pretty sure I was told it was a 1978, that would, according to that page mean that it should be a 5-speed. Any insight into this? Link to comment Share on other sites More sharing options...
Zsane Posted April 8, 2008 Share Posted April 8, 2008 Not sure about the cutoff but I have a 77' 280 stock with a 4 speed here at the house. So they did have them. Link to comment Share on other sites More sharing options...
blaze73 Posted December 18, 2008 Share Posted December 18, 2008 Has anyone got a weight on the Z32 trans yet? Link to comment Share on other sites More sharing options...
Oddmanout84 Posted February 8, 2009 Share Posted February 8, 2009 Six_Shooter said: Doing some searching on the manual trannies to night, since I may have a 4 speed to go in my car instead of a 5 speed. The reason I say this is because I was going through the gears with the tranny sitting on the floor and could not find a 5th gear, I thought I did, once, but every time after that, I could only find 4 gears. Is there anyway to tell? I could not find any markings, or numbers on the tranny case to identify it. I also see on THIS page that the 280Z, not ZX could also come with a 5-speed. I know this tranny came out of a 280Z, and was pretty sure I was told it was a 1978, that would, according to that page mean that it should be a 5-speed. Any insight into this? I'd also like to see how to identify these. I say this because the only number I've found is a serial # on top of the bellhousing, not a part number. The transmission was removed at some point in this car's life, because the bottom half of the plate that seals the tranny to the engine is missing. I have no clue if the tranny was also replaced, all I know is that its a 5 speed. I don't know if there's any difference between the "A" type and the "B" type, or if the shifter hookup is different between the 280Z and 280ZX. I want to purchase a short throw shifter, but I don't want to drop money on something that's not going to fit. I'm pretty sure this isn't a Borg Warner T5 in my car... Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted February 8, 2009 Administrators Share Posted February 8, 2009 T-56 for GM LSx. Link to comment Share on other sites More sharing options...
HowlerMonkey Posted February 16, 2009 Share Posted February 16, 2009 Pathfinder FS5R30....Length (bellhousing to tailhousing): 28.50" Shifter Position (bellhousing to center pivot): 27.0" Trans Mount position (bellhousing to center of mount) forgot the number but seems to be about 25.0" to 25.5" It also sports a very cool longshifter that angles backward such that the knob in neutral ends up about 30 inches from bellhousing. Link to comment Share on other sites More sharing options...
AK-Z Posted February 17, 2009 Share Posted February 17, 2009 Any body know "for sure" if the SR20DET transmission bell housing is the same as a KA24DE transmission bell housing? Link to comment Share on other sites More sharing options...
Mack Posted February 23, 2009 Share Posted February 23, 2009 the bellhousing is NOT the same, you can swap them out tho. the SR20 and KA24 trans are the same internally and have the same rear covers, but the bellhousing bolt patterns are different. I can get Z33 measurements by thursday, as I have a 6spd in my garage. EDIT: you could get either a 4spd or a 5spd on 280Z cars, it was an option, and in 1979, you could even still get a 4spd on the 280ZX. those 280sxs have the highly desireable 3.36 R200 gears. Link to comment Share on other sites More sharing options...
spacecase70 Posted November 18, 2009 Share Posted November 18, 2009 any thoughts on the 82 maxima trans. I would like to know the ratios on it since i put one in my 74 ? Link to comment Share on other sites More sharing options...
Guest sasahdois Posted November 19, 2009 Share Posted November 19, 2009 I think this is enough ..... I do agree with you. Those are the most effective way:icon44: Link to comment Share on other sites More sharing options...
