johnc Posted October 28, 2005 Share Posted October 28, 2005 Assume the following: 1. 2,000 lb car with a 50/50 weight distribution (500 lbs. of static load on each corner). 2. 8" tall 250 lb. in. springs at all 4 corners. 3. No aero downforce or lift. 4. No anti-roll bars. What is the load on each tire and what is the height of each spring at 1G lateral acceleration? Can the car generate more then 1G lateral acceleration? Quote Link to comment Share on other sites More sharing options...
PeterZ Posted October 28, 2005 Share Posted October 28, 2005 where's the CG Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 28, 2005 Share Posted October 28, 2005 I think you need RC to calculate transfer due to lateral g's and CG to calculate transfer due to accel/decel. Could be wrong. Quote Link to comment Share on other sites More sharing options...
johnc Posted October 28, 2005 Author Share Posted October 28, 2005 Let's keep it simple: purely lateral acceleration; no bumps; no banking; no geometric anti-roll or pro-roll; no aerodynamic downforce, no unusual roll centers, perfct CG, etc. Quote Link to comment Share on other sites More sharing options...
PeterZ Posted October 28, 2005 Share Posted October 28, 2005 Would this be an instantaneous load calculation simultaneuos to a train leaving Chicago in the opposite direction with an equal acceleration? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 28, 2005 Share Posted October 28, 2005 I don't think you're giving enough information to come up with an answer. As an example, How to Make Your Car Handle gives an acceleration weight transfer as follows: 1/2 g acceleration of 2000 lb car with 50/50 weight distribution with wheelbase of 100" and 20" high cg and says Weight transfer = inertia force x cg height / wheelbase. In their dragster example it works out as 1/2g * 2000 * 20 / 100 = 200 lbs. So in that example 200 lbs shifts to the rear. Lateral as I understand it is different because you need cg (I was wrong before you do need cg) and track width so you get a simple equation of: Weight transfer = Centrifugal force * cg / track width That simple equation doesn't take into account transfer from body roll, or roll center heights or unsprung weight, which according to How to Make Your Car Handle need to be calculated and added together to give a complete view of how much transfer is actually there. I think the answer your looking for is that it wouldn't be 100% of the weight transferred to the outside tires (it would be something like 25/75), and that the car would be capable of more than 1G in a turn and the outside springs would not be a whole bunch more compressed than the inside springs, but you're not really giving the info to figure it out anything close to accurately according to the sources I have. Quote Link to comment Share on other sites More sharing options...
Phantom Posted October 28, 2005 Share Posted October 28, 2005 Actually we would be assuming 25/25/25/25 load - that each corner bears an identical load in a state of rest - correct? I also assume that 8" springs at 250lb/inch is in the uncompressed state which would have them sitting at 6" in the rest state? Many assumptions have to be made about the dynamic friction between the tires and the road surface, the caster, the location of the CG in repect to the centerline of the wheels, etc. Assuming the the vehicle was in a full 1 G turn and other necessary assumptions were in place I would hazard that essentially 100% of the load would be born by the outside suspension which would have the outside springs at 4" and the inside at 8". No, it would probably not be capable of more than 1 G lateral accelleration without additional mechanical devices to contribute. Quote Link to comment Share on other sites More sharing options...
Bartman Posted October 28, 2005 Share Posted October 28, 2005 So if what phantom states is true, then the 1G of lateral acceleration is cancelling out the force of gravity on the inside of the car? Or maybe more accurately the weight of the car (is transferred) plus the force from 1G of lateral acceleration is placed on the outside suspension. If the above is accurate, then the outside wheels are each carrying 2,000 lbs of force? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 28, 2005 Share Posted October 28, 2005 But centrifugal force doesn't negate gravity. So it will transfer some of the weight to the outside of the car, but it takes way more than 1 G to completely transfer ALL of the weight off of the inside tires, in fact it should be closer to 2 G's if I'm correct. I'm sticking with my answer. I'll say that the inside springs would be 1" compressed while the outside will be 3" compressed. The weight is going to be roughly 25% inside and 75% outside and the car can generate more than 1 G on the skidpad. Quote Link to comment Share on other sites More sharing options...
Phantom Posted October 28, 2005 Share Posted October 28, 2005 I think it's all a mute point on ice! Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted October 28, 2005 Share Posted October 28, 2005 Without a coefficient of friction I don't see how you can make an assumption one way or the other about lateral G's. If you know the coefficient of friction, then the weight of the car is irrelavent as far as determining lateral G's. As are spring rates. Also have to agree you need some information about the dimensions of the car (width and height) to determine the lateral loadings. Perhaps you are making some additional assumptions? Quote Link to comment Share on other sites More sharing options...
tube80z Posted October 28, 2005 Share Posted October 28, 2005 Quote Assume the following: 1. 2' date='000 lb car with a 50/50 weight distribution (500 lbs. of static load on each corner). 2. 8" tall 250 lb. in. springs at all 4 corners. 3. No aero downforce or lift. 4. No anti-roll bars. What is the load on each tire and what is the height of each spring at 1G lateral acceleration?[/quote'] What is the motion ratio? You gave wheel loadings and a spring rate so I'm a little confused on that one. Quote Link to comment Share on other sites More sharing options...
johnc Posted October 28, 2005 Author Share Posted October 28, 2005 I was kinda hoping the smart guys wouldn't reply right away... This from Mark Ortiz go me thinking that some other folks might have a misunderstanding regarding load transfer: Quote LOAD TRANSFER QUESTION For argument’s sake, let’s assume the following: 1) Total rear roll resistance is 600 lb/inch of rear suspension travel. 2) The static weight on each rear tire is 400 lb. 3) The car’s rear suspension compresses 1 inch when cornering at the limit. Thus there is 600 lb of load transfer onto the outside rear tire. This car starts to corner and 400 lb of load is transferred from the inside rear tire to the outside rear tire. This leaves zero load on the inside rear tire. The car continues to speed up in the turn, reaching the limit of adhesion, and now there is 600 lb of load on the outside rear tire. Where does this additional 200 lb of load come from? Does it all come off the inside front tire? If you have rear anti-roll bar, it can actually push the inside tire up into the tire well. I guess this would be a negative load on the inside rear tire? If I understand the question correctly, you are supposing that the outside rear suspension compresses one inch from static, implying that the tire gains 600 lb of transferred load, which would make its load 1000 lb. If we are assuming that the car is in steady-state cornering, on a flat, smooth, unbanked turn, with no geometric anti-roll or pro-roll, and no aerodynamic downforce, you are describing an impossible case. Unless something adds load to the rear wheel pair beyond the static value, the outside wheel cannot have more load than the total for the wheel pair. There can be no such thing as a negative tire load, unless the tire can somehow pull upward on the road surface. Short of creating a tread compound that is sticky beyond our usual conception, or nailing the tire to the road (either of which would make it very difficult for the car to attain enough speed to corner hard), that just can’t happen. It is also impossible for load to transfer from the front wheels to the rear wheels when the car is only accelerating laterally. What will happen if the rear suspension reaches 100% load transfer, and then further lateral acceleration is applied to the car, is that the inside rear wheel will lift off the ground. The car will continue to roll, but without any further motion of the rear suspension. That implies that the rear ride height, measured from middle of the frame to ground, will increase as the wheel lifts. The anti-roll bar will push the inside tire up into the wheel well only in the sense that it may prevent the inside suspension from reaching full droop – not in the sense of compressing the inside suspension beyond static position. The suspension’s ride displacement from static will be zero. Its roll displacement will be two-thirds of an inch per wheel. The inside wheel will be off the ground, yet the suspension will be extended only 2/3†beyond static. The outside wheel will be compressed 2/3†from static. The average displacement of the two wheels, from static, will be zero. We may say that in this situation, the rear suspension is saturated in terms of load transfer: it has absorbed all the load transfer that it can. Any further load transfer must be absorbed by the front suspension alone. This implies that the inside front wheel will lose load, but that load will not go to the outside rear; it will go to the outside front. The total load on the front wheels, and the total load on the rear wheels, cannot change. Remember, though, that we made a number of simplifying assumptions here: purely lateral acceleration; no bumps; no banking; no geometric anti-roll or pro-roll; no aerodynamic downforce. In the real world, any combination of these might be present, meaning that we could very well have data acquisition traces showing an inch of compression from static on the outside rear. To know how much added load we would need to get that added 1/3†of ride compression, we would need to know the rear suspension’s wheel rate in ride as well as in roll. The required extra load wouldn’t necessarily be 200 pounds. If the wheel rate in ride were 300 lb/in, we’d have that condition. (100 lb/wheel divided by 300 lb/in = 1/3 in/wheel) If the only factor compressing the rear suspension is banking of the turn, and if the tires are racing slicks with a coefficient of friction around 1.30, we’d need about a 25 degree banking to generate 200 lb of extra load. A banking around 35 degrees would do this without the tires generating any cornering force. If the turn is flat, and the only factor compressing the rear suspension is aerodynamic downforce, we’d need 200 lb of that at the rear axle if the wheel rate in ride is 300 lb/in. If the wheel rate in ride is less, these values decrease. If the wheel rate in ride is greater, the values increase. The suspension geometry can generate a downward jacking force. This would be most likely in a lowered strut-style suspension, when most or all of the load is on the outside tire. In most cases, this will not be enough to compress the suspension a third of an inch unless the ride rate is very soft, but the effect could add to other effects to produce that much compression. Forward acceleration will usually compress the rear suspension. In a front wheel drive car, it always will. We think of steady-state cornering as purely lateral acceleration, but actually there will be a car-longitudinal (x-axis) component, even at constant speed, because of the car’s attitude angle or drift angle. Since any or all of these effects can be present, it is entirely possible for the rear suspension to be compressed more than we would calculate for pure cornering on a flat surface. But something has to add ride compression for the condition described here to occur. Quote Link to comment Share on other sites More sharing options...
