savageskaterkid Posted December 28, 2005 Share Posted December 28, 2005 I was looking for bore and stroke and all sorts of other things for the L engines, and I can't seem to find them all in the same place. I cannot get the Lengine program to work either. I do have all the info now but I was wondering if we can make a FAQ or sticky with all this info. Like Bore, Stroke, Chamber CCs, ect.... for all the L series engines. (including diesel) I was looking threw the old threads and alot of questions about these things and a bit of usefull info scattered throughout the pages newbies being told to search. Would someone possibly make a FAQ? Link to comment Share on other sites More sharing options...
SuperKid Posted December 28, 2005 Share Posted December 28, 2005 I'll try a little: L24: 83mm X 73.3mm 2393cc Head = 42.4cc L26: 83mm X 79mm 2565cc Head = 44.7cc L28: 86mm X 79mm 2753cc Head = 44.6cc LD28: 84.5mm X 83mm 2792cc Head = ??? That's all I can remember. Although someone may want to double check my numbers. Edit: added head cc's. Link to comment Share on other sites More sharing options...
savageskaterkid Posted December 28, 2005 Author Share Posted December 28, 2005 This is EXACTLY what I was looking for, atleast now its all in the same place. And when I said Chamber cc's i meant the combustion chamber not the entire displacement. But that is exactly what I needed. Link to comment Share on other sites More sharing options...
SuperKid Posted December 28, 2005 Share Posted December 28, 2005 This is EXACTLY what I was looking for, atleast now its all in the same place. And when I said Chamber cc's i meant the combustion chamber not the entire displacement. But that is exactly what I needed. Yeah, I figured you wanted the combustion chamber of the head, but what I gave was from memory, and I don't know the combustion chamber cc's. I'll have to look that up. I'll go look for it now. Link to comment Share on other sites More sharing options...
TimZ Posted December 28, 2005 Share Posted December 28, 2005 Does this help? Link to comment Share on other sites More sharing options...
Mikelly Posted December 28, 2005 Share Posted December 28, 2005 Made it a sticky... Mike Link to comment Share on other sites More sharing options...
SuperKid Posted December 28, 2005 Share Posted December 28, 2005 Yeah! I'm part of a sticky! lol. Now we just need more people to throw in some of their knowledge so this can be truly worthy of being a sticky! Come on people! I know their has to be more info out there! EDIT: Do you think someone could change the name of the thread? "possible sticky or faq?" doesn't exactly tell people what's in here. Just a thought... Link to comment Share on other sites More sharing options...
zcarnut Posted December 31, 2005 Share Posted December 31, 2005 This page is fairly useful and appears to be accurate: http://www.ozdat.com/ozdatonline/enginedesign/ Link to comment Share on other sites More sharing options...
jfairladyz Posted January 27, 2006 Share Posted January 27, 2006 I realize this post is kind of old but since its a sticky I though I'd chip in here. The spec for the L28 above are not entirely accurate. The cc's anyways. It's correct in that the early N47 heads were 44.6cc's. But the later P (p79, p90/a)series heads (found on the F54 block) were actually 53.6cc's. Link to comment Share on other sites More sharing options...
ww Posted February 6, 2006 Share Posted February 6, 2006 Is there any way we can change the name of this thread? It's kind of non-descriptive in it's current form... Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted March 3, 2007 Share Posted March 3, 2007 Does this help? Thats a good info page, into my bookmarks it goes lol. Does anyone have the flow rates on each head? Link to comment Share on other sites More sharing options...
WizardBlack Posted August 22, 2007 Share Posted August 22, 2007 Also, can anyone add the information about which heads have solid lifters and which are hydro? Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted August 22, 2007 Administrators Share Posted August 22, 2007 Also, can anyone add the information about which heads have solid lifters and which are hydro? E-31, E-88, N-42, N-47, MN-47 P-79, P-90 are mechanical. P-90A is the only head that came with hydraulic slack adjusters and the only way to know for sure with a P-90A head is to remove the valve cover for visual verification. Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted August 22, 2007 Share Posted August 22, 2007 Still no one has average flow rates for any L heads? Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted August 23, 2007 Administrators Share Posted August 23, 2007 Still no one has average flow rates for any L heads? Just curious, what benefit/value would those flow figures serve? Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted August 23, 2007 Share Posted August 23, 2007 Numbers to compare self improvements on L series heads? Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted August 23, 2007 Administrators Share Posted August 23, 2007 Flow rates? (every time someone wants to know and/or compare cylinder head port flow rates, I get this terrible uncontrollable twitch in my shoulder…) This has been covered before. Flow benches are an invaluable tool, much like a Torque wrench but only to the person using that tool, i.e. the person performing the head massaging. Those figures have NO performance value to the customer, end user, driver, tuner, gas pump attendant, neighbors cat, etc. The actual HP and Torque the engine produces as measured on a Dynamometer and/or Drag strip ET and MPH with the vehicle weight, are the figures that really matter most, not port flow rates. Comparing flow figures is like comparing head bolt torque values, i.e. serve no real function, especially from different flow benches utilizing different testing inlets/outlet horns, etc. For those figures to be of any real benefit, the test conditions NEED to be exactly duplicated on the “same” bench for accurate indications of possible flow gains. Flow figures are primarily for cylinder head massagers to use as a guide to whether or not they made any improvements in “static” air flow and that should be done on the SAME flow bench. Generally an improvement in “static” flow is indicative of the head being able to produce more power by virtue of flowing more air. Also, this "static" flow testing is only a very small part of a very complex scenario. Keep in mind the term “static” flow. A flow bench does NOT replicate what is actually taking place within the port in regards to air flow on a “running” engine such as helmholtz, valve events vs engine/piston speed, combustion efficiency due to chamber shape, how the exhaust tract affects scavenging, reversion, and the list goes on and on. Also, just porting a head for MAXIMUM flow can be achieved with overly aggressive bubba style hogging, and that head would be a lousy street engine. The real trick is getting those high flow numbers without making the ports the size of the Holland Tunnel. In short, flow rates are not to be bench raced or used for anything other than the person performing the port work to use as a “general” idea if an improvement in “static” flow has been achieved as measured on the SAME flow bench after mods have been performed. With that said, "1 fast Z" has been kind enough in the past to share flow numbers as he progressed in porting some L-series heads, i.e. repeatable useful flow numbers. Maybe he’ll chime in, though good luck getting him to share what the “exact” mods performed were for those different flow figures/graphs. Link to comment Share on other sites More sharing options...
Daeron Posted September 2, 2007 Share Posted September 2, 2007 is there a rule about posting superfluous questions in a sticky? Mods, feel free to delete this post. Link to comment Share on other sites More sharing options...
kiwi303 Posted May 25, 2008 Share Posted May 25, 2008 L28: 86mm X 79mm 2753cc Head = 44.6cc LD28: 84.5mm X 83mm 2792cc Head = ??? so a LD28 crank into a L28 gives a stroker with: 86 x 83 Using http://www.online-calculators.co.uk/volumetric/cylindervolume.php (my maths sucks without a fancy calculator, better than the MS windows build in calc) to give a cylinder size of 482.32485714285673 then multiplying the result by 6 for number of cylinders gives: 2893.9491428571405 or close enough to 2894cc. 2.9 litres. Yet I all a read on this forum in terms of stroker builds are 3.0 or 3.1 not 2.9 do the strokers also get bored out, or does installing the LD28 crank into L28 do something I'm missing from the straight bore x stroke lists here? Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 11, 2008 Share Posted June 11, 2008 Does anybody have a list of throttle body bore sizes for Nissan engines? I know: L28ET throttle body= 50mm KA24 throttle body= 60mm VH45DE throttle body= 90mm Anyone have the standard L28E throttle body size? (if different than the L28ET unit, confirmation maybe?) Also the Maxima L24E? *challenger and BRAAP both agree w/ 50mm stock L28E throttle body size, although BRAAP isn't taking well to the metric takeover(just playing!)* 2” ID OE L-28 EFI throttle valves with full diameter throttle shafts Link to comment Share on other sites More sharing options...
