Get the lead out
JMortensen
Bringing this thread back from the dead as I am now ready to start filling dents all over the car.
Based on numerous recommendations to use "marine epoxy filler" and Richard's mention of "West System" I've come up with the following potential bondo substitutes. Which is the right one for filling dents and finishing the edge of the drip rail?
Microlight (seems easy to sand):
http://www.marine.com/product_info.php/products_id/308
Low Density:
http://www.marine.com/product_info.php/products_id/304
High Density (sounds like it's a bitch to sand):
http://www.marine.com/product_info.php/products_id/297
Or is there another better product I should be looking at?
Here is a link to address your original lead question:
http://autobodystore.com/forum/showthread.php?t=4994
In making repairs to areas with pinholes or old lead, I found a thread on autobodystore's rust repair forum suggesting Dynahair, another recommending All Metal filler.
Every suggestion ( at autobodystore's forum) comes down to; use a layer of the waterproof filler and then a layer of your favorite finish filler like Rage Gold or Rage Extreme.
Another good link:
http://autobodystore.com/door_rust.shtml
Sorry, I cant help you choose what West Product, but I guess you are on the right track with the low density stuff, since you will probably top coat it with a finer filler anyway.
Why not just use bondo and mix in some fiberglass resin? They use the same catalyst
I don't know jack about body work, but I do know that there are 500 threads saying don't use bondo, as it is porous and will allow moisture into it and the sheetmetal can rust underneath it. I'll get a good deal on this stuff, because a friend of mine works at West Marine, which I guess is a pretty big company with 400 something stores in the US.
As to how thick it has to be, there are no spots that I think will be deeper than 1/4", and that one 1/4" deep spot is a small dent in the roof that I put there spinning the car on the rotisserie when there was something underneath it. D'oh! The rest of it should be 1/8" or less I think. I'm not so much going for perfectly flat as I am trying to make it reasonably presentable. It's a track car, not a show car.
Hmmm....
Long strand fillers are a lot more like fiberglass resin, they take longer to set up and they are a bitch to mix, but they provide unparalleled strength and resistance to cracking.
Medium strand and short strand fillers are much easier to form for filling holes and depressions. They are easy to mix and they set up quickly like bondo.
Sandable fillers are often thin, easy to apply, and easy to sand. They set up quickly and are only suitable for small imperfections in layers less than 1/8" thick. These are the most used and most abused.
As far as porosity, I am not sure everyone is on the same page here. I primed and sealed the areas I am applying filler. I also used OSPHO under everything. I could care less if they are porous.
  • 1 year later...
Jon,
Could you rehost the pictures that were in this thread? None of them are showing up for me. I'd like to see the pictures you have since it looks like I'm going to be going through this exact same process.
I knew there was rust because that flat area in the back wasn't flat, you can kinda see it pooched out on the last two pictures. Also there was a little rust on the flange where the quarter windows get screwed in.
What do you mean by pooched out? Did it look like this?
