Rb26 is now home :>
stony
Specs:
RB26DETT
T88 34-D.Turbine.Kit
HKS.1.2mm.Dragger.Head.Gasket
HKS.280/280.10.3mm.Cams
Tomei.Valve.Retainers
Sub.Zero.Custom.Intake.Manifold
Q45.Throttle.Body
Jun.Full.Port/Polished.Head
HKS.87mm.Pistons
HKS.H-beam.con-rods
Jun.Oil.Pump
Kakimoto-kai.cat-back.exhaust
Straight.Pipe
Greddy.Type.R.Blowoff
Blitz.3-Core.Front.Mount.Intercooler
Oil.Cooler.Kit
Oil.Relocation.Kit
1000cc.Injectors
Trust.Fuel.Rail
Aeromotive.Fuel.Pressure.Regulator
SplitFire.Coil.Packs
Why use a Jun balanced crank instead of balancing the stock crank - since some people run it along 1 200 hp?
Just being envious (and curious) - very sweet engine indeed : )
Maybe the thought of having a brand new one from JUN is a lot nicer than balancing a 15 year old piece of fatigued metal?
I'd imagine Stonys engine to be out of a R34 (since its a red top), thus not
I am by no means a skyline know-it-all, but all the red top RB's I've seen
have been housed in a R34. Also, the valve cover with the GT-R print is
yet to be seen on a stock R32/33 GTR-engine.
Not trying to step on anyones toes here. I was just asking.
Thanks for the reply Stony. Now try not to break it :)
I'd imagine Stonys engine to be out of a R34 (since its a red top)' date=' thus not
being 15 years old (that is, without the use of time travel) [img']http://www.collectiblez.nl/forums/images/smilies/wink.gif[/img]
Maybe he painted it! Haha, or I was just assuming most RB26's stateside were R32 units. BTW, off topic, HKS does make some schweet looking valve covers.
It's not an R34 motor/crank.
By JUN balanced, he means that it was balanced by JUN.
An R32 crank will handle as much power as an R34 crank. The oil pump drive is the difference.
The stock crank will not support the rpm's to make 1200hp and live. It is not fully counter weighted and not stiff enough. The flex at 12,000 rpm is unreal and it will wipe out bearings in very short order. Accelerating a roller on a dyno and accelerating a 3000lb car put completely different loads on the crank.
