jerryb Posted July 9, 2006 Share Posted July 9, 2006 Whats the best spot to place the BOV return line.....I know it should be after after the MAF but does it matter where? Before or after the turbo? I was thinking just before the entry side of the intercooler??? Quote Link to comment Share on other sites More sharing options...
Twizted Posted July 9, 2006 Share Posted July 9, 2006 I had put mine before the turbo with a nozzle pointed in that direction. It seemed to help the turbo stayed spooled. Although I have gone thru turbos every other oil change so it may not be the most reliable. But I'm sure that that wasn't caused my turbo failures. 30+ boost is what I feel the culprit was. Quote Link to comment Share on other sites More sharing options...
Sparky Posted July 9, 2006 Share Posted July 9, 2006 yupp, after MAF, before turbo. Quote Link to comment Share on other sites More sharing options...
Clifton Posted July 9, 2006 Share Posted July 9, 2006 Atmosphere. Quote Link to comment Share on other sites More sharing options...
jerryb Posted July 9, 2006 Author Share Posted July 9, 2006 Atmosphere.? Doesnt that screw up the MAF readings...hence fuel ratio? Quote Link to comment Share on other sites More sharing options...
Clifton Posted July 9, 2006 Share Posted July 9, 2006 It didn't mess it up on mine when I had an afm. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted July 9, 2006 Share Posted July 9, 2006 You just have to make sure that it doesn't leak at idle. Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted July 17, 2006 Share Posted July 17, 2006 ive noticed with nissans that recirculating the BOV pressure back into the intake helps with keeping the idle steady, esp when coming to a stop. The ECU reads the air that came in through the MAF, and when the excess air is released into the atmosphere the system looses pressure and the ECU compensates for that by throwing in a little more fuel, which is why youl maybe notice a small backfire or black smoke and stumbling idle. So save your self some money on gas and spark plugs. Recirculate that BOV. Quote Link to comment Share on other sites More sharing options...
z_cars_rule Posted July 17, 2006 Share Posted July 17, 2006 or have it go to atmosphere and get an aftermarket ECU that runs on MAP and TPS Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted July 19, 2006 Share Posted July 19, 2006 or have it go to atmosphere and get an aftermarket ECU that runs on MAP and TPS All that money just to hear your BOV go Paaaashiiiek. I think you should just do what you intended on doing IMO. Quote Link to comment Share on other sites More sharing options...
z_cars_rule Posted July 19, 2006 Share Posted July 19, 2006 All that money just to hear your BOV go Paaaashiiiek. I think you should just do what you intended on doing IMO. all that money to get a good tune and more power from what you already have. and i am not really a fan of atmo BOVs, i am putting a filter on mine because there is no where for it to plumb back to. Quote Link to comment Share on other sites More sharing options...
CRAVED Posted August 9, 2006 Share Posted August 9, 2006 this was 3 weeks ago, but make sure that the air flows towards the turbo and none can make it back to the AFM ,, ie if it comes in at a T connection air goes both ways and will make the AFM measure airflow and dump fuel into the engine.. Quote Link to comment Share on other sites More sharing options...
jerryb Posted August 11, 2006 Author Share Posted August 11, 2006 Thanx for all the pointers..... Quote Link to comment Share on other sites More sharing options...
