Weak front brakes
I know about most of the upgrades, but I think something is wrong with my brake system. My rear brakes seem to be doing most of the work, I have a gravel driveway and can slam on the brakes in loose gravel and the rears will slide a long way and the fronts will barely lock. Entire system is stock but all seemingly in good working order. Have been driving the car for 4 years and has always been this way. Where should I start, master cylinder, proportioning valve? I wouldn't think it was the proportioning valve because both sides equally suck!
I can't even do a good burnout because even with tires smoking, can't hold it still!
thanks
Jeff
Entire system is stock but all seemingly in good working order. Jeff
Doesn't sound like its in good working order at all. How old is the brake fluid? With that 350 running headers is quite possible you have "cooked" the fluid from the header heat. Make sure the brake lines have been moved away from the headers. That happened to my clutch fluid in my V8 280Z. Then check the master cylinder, proportioning valve and then the front calipers. Rear wheels locking up first is very dangerous situation since you would have no control of the car in a panic stop.
Front callipers aren't frozen, they function just not very good. Deja, I guess what I should have said is all systems are "functioning" :) I flushed the entire system when I put the car on the road about 3 years ago and it has always been this way, even prior to the SBC install.
Is there a scientific way to check the master? I know it squirts out of both ports but not sure if the front is week.
Same question for the proportioning valve?
I figure the problem is with one of those items but am hoping to prove without just dumping money on swapping parts.
Thanks Again
Jeff
Food for thought....
A proportioning valve that splits the pressure ratio between the front and rear will most likely "mask" the root cause.
If it is stock as you say then something is dead wrong.
If you have replaced the front pads check them. If not replace them.
If you feel confident that it's not the pads, and both sides of the front are weak, you have no choice but to suspect the master cyl. Its the only place that a stock sys splits front/rear duty.
Think about it, both front calipers equally malfuctioning? Prob not.
The cyl that operates both front calipers being bad, yep.
2eightynine, that's what I'm thinking.
I don't understand enough about the proportioning valve to know how it would effect me. Is it splitting the pressure between the front and back or just the balance between the 2 fronts?
Double emphasis of this point. Can't imagine how an MC could be operating at 50% effectiveness for 4 years. Those pigs either work or they don't.
Do a search for good street pad, put them on, replace the rotors and bed the pads. Get some stainless steel brake lines while you are at it. See what that does. There was a thread just the other week where someone fixed their brake effectieness with better pads.
I bought some good pads yesterday, nothing special, just the best that that parts store had, skimmed my rotors and flushed all the brake fluid out and it seems to be better. Thanks for your help guys, I had done all that before but I may have used cheap pads.
Jeff
Front callipers aren't frozen' date=' they function just not very good. Deja, I guess what I should have said is all systems are "functioning" :) I flushed the entire system when I put the car on the road about 3 years ago and it has always been this way, even prior to the SBC install.
Thanks Again
Jeff[/quote']
No way I know of, but it sure sounds like master to me. PITA to swap out on a guess but its better than crashing your car in an uncontolled panic stop.
BTW instead of that deserted road I'd do the testing in a big empty parking lot, much less stuff to hit.
good luck, let us know when you figure it out.
  • 2 months later...
