FAQ Acronym Page
JSM
Is there a acronym page somewhere? Can we start one?
In all my reading I'm continually baffled and don't want to ask what something means. Maybe when I have a question I'll just post it on this same thread.
Please add along if you've got others I'm sure there are.
AFM = Air Flow Meter
CDI = Capacitive Discharge Ignition
COP = coil on plug
CTS = Coolant Temprature Sensor
EBC = Electronic Boost Control
EDI(S) = Electronic Distributorless Ignition, add an "S" and it stands for System
EGR = Exhaust Gas Recirculation
FI = Fuel injection
HO2S = Heated Oxygen Sensor
HP = Horse Power
IAC = Idle Air Control
IAT = Intake Temp Sensor
IC = Intercooler
MAF = Mass Air Flow (meter/sensor)
MAP = Manifold Absolute Pressure
More Rust than Mull = Huge Amount of Rust
MS = Mega Squirt
MSnS-E = MegasSquirt n Spark-Extra
NA = Normally Aspirated
O2S = Oxygen Sensor
OHC = Over Head Cam
PCV = Positive Crankcase Ventilation
SBC = Small Block Chevy
SBF = Small Block Ford
TB = Throttle Body
TPS =Throttle Postion sensor
LCA = lower control arm
UCA = upper control arm
TC rod = tension compression rod or strut rod
SFC = subframe connector
L28E=Naturally Aspirated 2.8 Liter 6 Cylinder L series Found in 280Z
L28ET=TurboCharged 2.8 Liter 6 Cylinder L series Found in 280ZX
L28et=FI (forced induction in this case, not fuel injected-that one can get confusing really quickly-the t on that motor is for turbo)
E=EFI Motor Used on the end of Motor type (Eg l28E)
L26E=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z
L26=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z
L24=Naturally Aspirated 2.4 Liter 6 Cylinder L series Found in 240Z
VG30et=Z31 (chassis code for early 300zx) single cam turbo engine among others in the non-us market
VG30dett=Z32 (chassis code for late 300zx) twin cam/twin turbo and possibly other models in non-us market
Rb20/5/6det/tt= these engines came from various skyline models as well as some others, generally nissan nomenclature works like this: the number is the liters (i.e. L28=2.8 liters) the e is overhead cam, de is dual overhead cam, and the number of t's indicates the number of turbos, but not always, as in the case of the Fj20e which is a twin cam that doesn't have the d in it.
2jzgte=supra twin turbo engine from the mark IV supra and possibly some others in the non-us market
1jzgte=single turbo variant of 2jzgte available in some non-us toyota models
7mgte=mark III supra single turbo engine
IC = Intercooler
vg30et = ?
L28e = ?
L28et = ?
AEI = ?
EDI = ?
EDIS = ?
VG30DETT = ? Engines from what type of car/model
RB26DETT = ? Engines from what type of car/model
2JZGTTE = ? Engines from what type of car/model
L28 i know is the 2.8 Liter, what is the diff between e and the t?
E=EFI Motor Used on the end of Motor type Eg l28E
More Rust than Mull= Huge Amount of Rust
SBC=Small Block Chevy
IC = Intercooler
vg30et = ?
L28e = ?
L28et = ?
AEI = ?
EDI = ?
EDIS = ?
L28 i know is the 2.8 Liter' date=' what is the diff between e and the t?[/quote']
L28e=NA (normally aspirated) L28et=FI (forced induction in this case, not fuel injected-that one can get confusing really quickly-the t on that motor is for turbo)
EDI=Electronic Distributorless Ignition, add an "S" and it stands for System
CDI=Capacitive Discharge Ignition
You got me with "AEI", I've never seen that one before...
