JSM Posted August 14, 2006 Share Posted August 14, 2006 Is there a acronym page somewhere? Can we start one? In all my reading I'm continually baffled and don't want to ask what something means. Maybe when I have a question I'll just post it on this same thread. Please add along if you've got others I'm sure there are. AFM = Air Flow Meter CDI = Capacitive Discharge Ignition COP = coil on plug CTS = Coolant Temprature Sensor EBC = Electronic Boost Control EDI(S) = Electronic Distributorless Ignition, add an "S" and it stands for System EGR = Exhaust Gas Recirculation FI = Fuel injection HO2S = Heated Oxygen Sensor HP = Horse Power IAC = Idle Air Control IAT = Intake Temp Sensor IC = Intercooler MAF = Mass Air Flow (meter/sensor) MAP = Manifold Absolute Pressure More Rust than Mull = Huge Amount of Rust MS = Mega Squirt MSnS-E = MegasSquirt n Spark-Extra NA = Normally Aspirated O2S = Oxygen Sensor OHC = Over Head Cam PCV = Positive Crankcase Ventilation SBC = Small Block Chevy SBF = Small Block Ford TB = Throttle Body TPS =Throttle Postion sensor LCA = lower control arm UCA = upper control arm TC rod = tension compression rod or strut rod SFC = subframe connector L28E=Naturally Aspirated 2.8 Liter 6 Cylinder L series Found in 280Z L28ET=TurboCharged 2.8 Liter 6 Cylinder L series Found in 280ZX L28et=FI (forced induction in this case, not fuel injected-that one can get confusing really quickly-the t on that motor is for turbo) E=EFI Motor Used on the end of Motor type (Eg l28E) L26E=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z L26=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z L24=Naturally Aspirated 2.4 Liter 6 Cylinder L series Found in 240Z VG30et=Z31 (chassis code for early 300zx) single cam turbo engine among others in the non-us market VG30dett=Z32 (chassis code for late 300zx) twin cam/twin turbo and possibly other models in non-us market Rb20/5/6det/tt= these engines came from various skyline models as well as some others, generally nissan nomenclature works like this: the number is the liters (i.e. L28=2.8 liters) the e is overhead cam, de is dual overhead cam, and the number of t's indicates the number of turbos, but not always, as in the case of the Fj20e which is a twin cam that doesn't have the d in it. 2jzgte=supra twin turbo engine from the mark IV supra and possibly some others in the non-us market 1jzgte=single turbo variant of 2jzgte available in some non-us toyota models 7mgte=mark III supra single turbo engine Link to comment Share on other sites More sharing options...
RB26240Z Posted August 14, 2006 Share Posted August 14, 2006 MAP= Manifold Absolute Pressure Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted August 14, 2006 Share Posted August 14, 2006 MSnS-E = MegasSquirt n Spark-Extra MAF = Mass Air Flow (meter/sensor) There's probably a million of them. Mario Link to comment Share on other sites More sharing options...
GD71240z Posted August 15, 2006 Share Posted August 15, 2006 IAC= Idle Air Control CTS = Coolant Temprature Sensor O2S = Oxygen Sensor HO2S = Heated Oxygen Sensor EGR = Exhaust Gas Recirculation PCV = Positive Crankcase Ventilation Link to comment Share on other sites More sharing options...
JSM Posted August 15, 2006 Author Share Posted August 15, 2006 Thanks, Keep them comming. I'll edit the post and them as we go. Link to comment Share on other sites More sharing options...
JSM Posted August 15, 2006 Author Share Posted August 15, 2006 IC = Intercooler vg30et = ? L28e = ? L28et = ? AEI = ? EDI = ? EDIS = ? VG30DETT = ? Engines from what type of car/model RB26DETT = ? Engines from what type of car/model 2JZGTTE = ? Engines from what type of car/model L28 i know is the 2.8 Liter, what is the diff between e and the t? Link to comment Share on other sites More sharing options...
Mr.INSANE Posted August 15, 2006 Share Posted August 15, 2006 L28E=Naturally Aspirated 2.8 Liter 6 Cylinder L series Found in 280Z L28ET=TurboCharged 2.8 Liter 6 Cylinder L series Found in 280ZX E=EFI Motor Used on the end of Motor type Eg l28E L26E=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z L26=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z L24=Naturally Aspirated 2.4 Liter 6 Cylinder L series Found in 240Z More Rust than Mull= Huge Amount of Rust SBC=Small Block Chevy Link to comment Share on other sites More sharing options...
Twoeightnine Posted August 15, 2006 Share Posted August 15, 2006 SBF = Small Block Ford. Link to comment Share on other sites More sharing options...
veritech-z Posted August 15, 2006 Share Posted August 15, 2006 Quote IC = Intercoolervg30et = ? L28e = ? L28et = ? AEI = ? EDI = ? EDIS = ? VG30DETT = ? Engines from what type of car/model RB26DETT = ? Engines from what type of car/model 2JZGTTE = ? Engines from what type of car/model L28 i know is the 2.8 Liter' date=' what is the diff between e and the t?[/quote'] L28e=NA (normally aspirated) L28et=FI (forced induction in this case, not fuel injected-that one can get confusing really quickly-the t on that motor is for turbo) EDI=Electronic Distributorless Ignition, add an "S" and it stands for System CDI=Capacitive Discharge Ignition VG30et=Z31 (chassis code for early 300zx) single cam turbo engine among others in the non-us market VG30dett=Z32 (chassis code for late 300zx) twin cam/twin turbo and possibly other models in non-us market Rb20/5/6det/tt= these engines came from various skyline models as well as some others, generally nissan nomenclature works like this: the number is the liters (i.e. L28=2.8 liters) the e is overhead cam, de is dual overhead cam, and the number of t's indicates the number of turbos, but not always, as in the case of the Fj20e which is a twin cam that doesn't have the d in it. 2jzgte=supra twin turbo engine from the mark IV supra and possibly some others in the non-us market 1jzgte=single turbo variant of 2jzgte available in some non-us toyota models 7mgte=mark III supra single turbo engine You got me with "AEI", I've never seen that one before... Link to comment Share on other sites More sharing options...
z_cars_rule Posted August 15, 2006 Share Posted August 15, 2006 the 'e' in the engine code does not stand for over head cam. it stands for electronic fuel injection. OHC = over head cam Link to comment Share on other sites More sharing options...
veritech-z Posted August 15, 2006 Share Posted August 15, 2006 So are the L26e's mentioned above equipped with fuel injection, or twin su's like other 260z's? Link to comment Share on other sites More sharing options...
OlderThanMe Posted August 15, 2006 Share Posted August 15, 2006 well 260s were produced until 78 If I remember correctly... Mostly for the Aussies and the UK. I don't know if they had FI though. Link to comment Share on other sites More sharing options...
veritech-z Posted August 15, 2006 Share Posted August 15, 2006 I'd always heard the 260 was only made for one year...I'd believe that the e is for fuel injection, I'm just curious now... Link to comment Share on other sites More sharing options...
Forrest Posted August 15, 2006 Share Posted August 15, 2006 COP = coil on plug WWJCD = What would John Coffey Do? Link to comment Share on other sites More sharing options...
OlderThanMe Posted August 15, 2006 Share Posted August 15, 2006 The 260 was imported to the USA for one year. And there were 2 versions. Early and late. lol Forrest... WWJCD. Link to comment Share on other sites More sharing options...
Thumper Posted August 15, 2006 Share Posted August 15, 2006 EBC= Electronic Boost Control TPS= Throttle Position Sensor IAT= Intake Temp Sensor FUBAR= Fucked Up Beyond All Recognization Link to comment Share on other sites More sharing options...
JSM Posted August 15, 2006 Author Share Posted August 15, 2006 ICV = Idle Control Valve? Is that one? I've heard of the idle control valve on my BMW, do Z's have them at all? Link to comment Share on other sites More sharing options...
JSM Posted August 15, 2006 Author Share Posted August 15, 2006 What does CAS mean as in this Post? http://forums.hybridz.org/showthread.php?t=106924 Link to comment Share on other sites More sharing options...
Forrest Posted August 15, 2006 Share Posted August 15, 2006 Crank angle sensor. Link to comment Share on other sites More sharing options...
Forrest Posted August 15, 2006 Share Posted August 15, 2006 http://www.aa1car.com/library/acronyms.htm Link to comment Share on other sites More sharing options...
