Garrett76Zt Posted April 6, 2007 Share Posted April 6, 2007 Is your tach clocked like that because you plan on running 8000 rpm? Its clocked because when you sit in the seat you cant see redline behind the steering wheel. Same for me. Time to go back to the wood school bus steering wheel I guess. Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted April 7, 2007 Author Share Posted April 7, 2007 Yep cant see tach when is sitting in right way so had to custom fit it lol. Either way I am going to try to spin it to 7500rpm I belive that will do if for now. Ps. Garrett how is your sack doing? EDIT:: Ivo TYPED THIS !!!!!! Quote Link to comment Share on other sites More sharing options...
Careless Posted April 7, 2007 Share Posted April 7, 2007 That is the kameari timing tensioner setup. what's that do ? LOL looks all gadgety and stuff I assume it keeps tension in the chain to avoid slapping and excessive binding/stretching at high load? Quote Link to comment Share on other sites More sharing options...
steveosupremeo Posted April 7, 2007 Share Posted April 7, 2007 that thing sounds awesome! and i'm the only tech in my shop with a blue toolbox too, lol. Quote Link to comment Share on other sites More sharing options...
Z728 Posted April 7, 2007 Share Posted April 7, 2007 O.K. I'm convinced out comes the n/a in goes the turbo means I'll have to change class to unlimited GTU but man that set up sounds sweet hope it performs like it sounds. that tensioner is solid? or controlled by oil pressure ? nice solution to the problem!! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 7, 2007 Share Posted April 7, 2007 Yep cant see tach when is sitting in right way so had to custom fit it lol. Either way I am going to try to spin it to 7500rpm I belive that will do if for now. 7500. That's a good number for an L. It will be interesting to see how much hp comes from that extra 2000 rpm. Sounds like an L should... nice and lopey. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted April 7, 2007 Share Posted April 7, 2007 John, I belive that it should do fine. With my stock cam and big turbo on dyno I was making power to 6500rpm and thats when is started to taper off. This cams power band is advertised to be from 4k to 8.5k (please dont ask why I got it lol). I did quick drive down the street and when it hit 4500rpm whole car got violent!!! Motor reved up like I was spraying living crap out of it. Z728, Yes now I am in control on how much tension there is on chain which I guess can be good and bad thing...everthing is solid now. Quote Link to comment Share on other sites More sharing options...
