streeteg Posted April 16, 2007 Share Posted April 16, 2007 Have a swapped 260z with an RB 25det/RB20 trans--- Has a custom dash--- so the stock speedo is not there. Have an autometer and am confused on what I need to make it work--- All there is --- is one connection....so my question is what wire do I need? Is it an RB part or a Z part? any help appreciated... -E Quote Link to comment Share on other sites More sharing options...
stony Posted April 16, 2007 Share Posted April 16, 2007 Hmmmmmmmmmmm, this has been talked about atleast 10 times. here hold on...... Nevermind i guess not,,,, cant think of any good key words to search.......Cant remember, does the rb20 tranny have the electronic or mechanical speed sensor? if its electronic the autometer web sight has a install guide you can download. its pretty striaght forward. I had a rb25 tranny that i was going to hook the elctronic speedo also but never got around to it. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted April 16, 2007 Share Posted April 16, 2007 Speedometer Service Company, 5801 W. Villard Ave., Milwaukee, WI. 414 463 6660......................These people are authorized by Autometer and can supply what you need. They really helped me. Quote Link to comment Share on other sites More sharing options...
streeteg Posted April 16, 2007 Author Share Posted April 16, 2007 sweet Thanks guys! I am new to nissans but not to forums or the search button--- wouldnt have posted if i didnt think i didnt search enough--- Once again thanks for all the help! Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted April 17, 2007 Share Posted April 17, 2007 what type of autometer - mechanical or electrical. both will work with the nissan trans - you can bolt in a 300z mech drive into the rb25/sr20 trannies. Pick your geer color and away you go. I am using the electronic autometer with no problems. Q Quote Link to comment Share on other sites More sharing options...
jerryb Posted April 17, 2007 Share Posted April 17, 2007 Hey I just noticed the RB20 Tranny...this is a mechanical setup. The stock Z speedo cable hooks right up to it....You may need a differtnt color gear but that shouldnt be a problem..... Anyone have product codes for the RB speedo gears. Quote Link to comment Share on other sites More sharing options...
streeteg Posted April 17, 2007 Author Share Posted April 17, 2007 what does different color gear mean? I do not have a stock Z speedo cable---any part that is interchangeable? Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted April 18, 2007 Share Posted April 18, 2007 Hey I just noticed the RB20 Tranny...this is a mechanical setup. The stock Z speedo cable hooks right up to it....You may need a differtnt color gear but that shouldnt be a problem..... Anyone have product codes for the RB speedo gears. The rb speedos are the same as Z31 and Z32 trannies. rb20=z31 rb25/26=z32. Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted April 18, 2007 Share Posted April 18, 2007 what does different color gear mean? I do not have a stock Z speedo cable---any part that is interchangeable? color of gear is based on your final drive ratio - based on your tire size and and rearend ratio you can pick the appropriate color to get the best estimate of your speed on the speedo. Per Datsun Garage YELLOW is the 16 tooth for the 3.36 BLACK is the 17 tooth for the 3.54 BLUE is the 18 tooth for the 3.70 WHITE is the 19 tooth for the 3.90 RED is the 20 tooth for the 4.11 PURPLE is the 21 tooth for the 4.38 Quote Link to comment Share on other sites More sharing options...
turbo_fb Posted April 20, 2007 Share Posted April 20, 2007 http://www.cardomain.com/item/ATM9117 Quote Link to comment Share on other sites More sharing options...
