LS1 Z Posted May 19, 2007 Share Posted May 19, 2007 I thought I would run this by you guys. Get your opinions and see if anybody else is having this problem. The car 280Z LS2 T-56. Q45 diff, Ross's Moser axles, LS1FD's mustache bar and adapters at the stub axles. Arizonia Z car rear mount and lower control arms. MAS280 front diff mount. Everything is tight and looks to be in alignment. The body does not look twisted in anyway. Infact this car is drop dead gorgious!! The Z has been on the road for 6k and runs 10.8s in the quarter!! I pretty much have the same set up in my Z. Pretty easy to guess who's car this is (ULISES). The car came to me for a clutch job. I took the car for a spin to feel the original clutch. I didn't abuse or romp on it at all!! I was making a left turn gave it a little gas (1/4 to 1/2) throttle, and a ton of noise came from the rear, like a broken axle! Limped the car back to the shop. What I found is the drivers outer C/V joint came out of the housing. Tore the axle down. The outer housing is broken and yes the retaining clip got pulled with the joint. Also noticed the cap on the inner joint also broken! I replaced the clutch, got another outer C/V. Go for a test drive and the same thing happens in the same part of the road. It was like a replay of the first time!!!! I'm gonna pull out both axles and inspect. It seems the axle (drivers) and c/v joints are moving too much in the housings and being pushed towards the diff. Has anyone else had this problem? Or any ideas? The car is beautiful, but I don't want to marry it! And I don't want Ulises to miss his baby too much!! Joey Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted May 19, 2007 Share Posted May 19, 2007 I wonder if you are getting too much play and maybe shortening the shafts might solve the problem. What is your half shaft length on the side that broke? Quote Link to comment Share on other sites More sharing options...
mark Posted May 19, 2007 Share Posted May 19, 2007 I've had this happen several times. The axel will walk to the inside of the car and pull the outer CV apart. THe solution is a "stop" inside the end cap. Ross has them. For what it's worth, I run them on both ends of the axel. I've had this happen with the inner CV on a road course. Once the end cap stops were placed, I've had no more problems with this. I beat the crap out of the car at open track days. LT 1 and t-56 with the Q diff and CV's. Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted May 19, 2007 Share Posted May 19, 2007 Can you provide a pic of the "stop" or a link showing what you are describing? Thanks. Quote Link to comment Share on other sites More sharing options...
v8dats Posted May 19, 2007 Share Posted May 19, 2007 watching this thread! r230 on its way!! Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted May 20, 2007 Author Share Posted May 20, 2007 Hey Mark!!! I agree with you 100%!! I was approached with welding a spacer to the inside joint cover. Butt, Wouldn't the cover still crack? I'm with CAL POLY. I cannot find it on Ross's website. I have 3 Z's at my shop with all the same swap!!! Joey Quote Link to comment Share on other sites More sharing options...
mark Posted May 20, 2007 Share Posted May 20, 2007 Sorry, no pics. I was on Ross's web site and I can't find a pic there either but I know he has them. If you can find the Q45 CV conversion, it should have a pic there. Quote Link to comment Share on other sites More sharing options...
mark Posted May 20, 2007 Share Posted May 20, 2007 Just found this on the site. It says one pair are include. Get two pair. Includes: pair of billet 4340 precision CNC machined steel R230 CV/Companion flange adaptors, heat treated, cryogenically treated, and double tempered! one pair of precision CNC machined end stops, required to ensure appropriate CV travel high grade hardware for mounting brackets, this includes OEM 280ZXT stub axle nuts which are preferred (no peening required) and all other high grade hardware for the install optional choice below: custom high strength male male splined axles, engineered with this package Quote Link to comment Share on other sites More sharing options...
jaime240z Posted May 20, 2007 Share Posted May 20, 2007 Here is a pic of the unassembled parts from Ross (glad I took pics!) You can see the caps with built in stop on the lower right. Hope this helps. Quote Link to comment Share on other sites More sharing options...
ULISES Posted May 22, 2007 Share Posted May 22, 2007 I want my car back, I miss it already!!! Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted May 22, 2007 Author Share Posted May 22, 2007 I've e-mailed and pmed Ross. Waiting to here back from him. Or better yet does anybody have number for him? Yes Ulises!!! I'm on it!!! Joey Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted May 23, 2007 Share Posted May 23, 2007 Joey, email back at you, need to know where you want parts sent as queried in my response, cheers! Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted June 5, 2007 Author Share Posted June 5, 2007 Update to this thread... First off ROSS ROCKS!!! Great person to deal with and got the stops to me very quickly!! The stops are the same as the pic. I installed 4 stops into Ulises's half shafts and..... No more problems!! The diff of before and after. Before I had around 3 inches of travel or movement of the axles. Now an inch at the most. Ross sent me 3 sets. I will be installing a set in my Z as well as my clean up kids Z (HEAVYZ's old Z). Joey Quote Link to comment Share on other sites More sharing options...
Cable Posted October 15, 2007 Share Posted October 15, 2007 Here is a pic of the unassembled parts from Ross (glad I took pics!) You can see the caps with built in stop on the lower right. Hope this helps. I guess I am fuzzy on where the end stops go. Do they get assembled with the CV's between the stock end caps and the end of the axles? Thanks for the help. Update to this thread... First off ROSS ROCKS!!! Great person to deal with and got the stops to me very quickly!! The stops are the same as the pic. I installed 4 stops into Ulises's half shafts and..... No more problems!! The diff of before and after. Before I had around 3 inches of travel or movement of the axles. Now an inch at the most. Ross sent me 3 sets. I will be installing a set in my Z as well as my clean up kids Z (HEAVYZ's old Z). Joey How much were all 4 of the end stops? Thanks!! Quote Link to comment Share on other sites More sharing options...
240Z2NV Posted November 29, 2007 Share Posted November 29, 2007 Did you ever get an answer?! Quote Link to comment Share on other sites More sharing options...
Cable Posted November 29, 2007 Share Posted November 29, 2007 Did you ever get an answer?! Nope...... Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted November 29, 2007 Share Posted November 29, 2007 I guess I am fuzzy on where the end stops go. Do they get assembled with the CV's between the stock end caps and the end of the axles? Thanks for the help. 240Z2NV and I just exchanged notes. The end stops essentially replace the OEM thin stamped end caps. Their raised center keeps the custom male male axles in their happy zone when you're pushing your foot thru your floorboard and thinking of other limits like your pucker factor Joey, thanks for your help keeping those Z's flying. Quote Link to comment Share on other sites More sharing options...
240Z2NV Posted November 29, 2007 Share Posted November 29, 2007 In fairness, I want to acknowledge that Ross responded to my inquiry/request very quickly once he finally saw my post. Thank you to Ross & Modern Motorpsorts. Quote Link to comment Share on other sites More sharing options...
Datsun570z Posted April 15, 2014 Share Posted April 15, 2014 I know this thread is older but is this kit still available at all? Parts of it I'm assuming? Any recommendations on half shafts for a 75 280z as I plan on running the z32 Vlsd diff? I know techno toy tune sells the rear and front mount but after a lengthy conversation he basically told me good luck on your half shafts and flange fitting. Help or direction is much appreciated. Thanks. 75' 280z w Ls1 t56 r230 diff and 275 tires! Quote Link to comment Share on other sites More sharing options...
