280Z Rear Suspension Distance Piece
Guest FLAZGUY
Guest FLAZGUY
Help! I am at the end of a build of my latest Z. A 78 280Z with 44K on the car. I can not find the "distance piece" IE spacer for the rear wheel bearings (looks like a short piece of tail pipe). I need two "B" one for each side. These are coded A, B or C on the casting that the bearings are pressed into. If any of you know where I can find these parts please post a location or source.
Guest FLAZGUY
I know that I can go to the junk yard and pull the stub axles off of a doner but I was hoping that there may be someone on here that has two of these laying around. I hate to tear up a car for such a small part. It also is a real PIA to do this type of dissasembly in the dirt with no power tools.
