e_racer1999 Posted October 19, 2009 Share Posted October 19, 2009 The sending unit still has to pick up the fuel from the tank, unless you're running a sump. Optional mod would be larger feed and return lines on the tank Link to comment Share on other sites More sharing options...
T S30 H Posted October 20, 2009 Share Posted October 20, 2009 e_racer1999 said: The sending unit still has to pick up the fuel from the tank, unless you're running a sump. Optional mod would be larger feed and return lines on the tank Thanks for the info. Link to comment Share on other sites More sharing options...
LanceVance Posted October 29, 2011 Share Posted October 29, 2011 (edited) Strotter, I stumbled upon your thread while trying to figure out a way to consolidate my fuel components and add a surge tank. Your diagram was exactly what I was looking for! Did you ever get around to making your fold down setup, and if so would you be able to show it off for us? Sorry for the necropost, but this seems like something worth bringing up if you've completed it. Edited October 29, 2011 by LanceVance Link to comment Share on other sites More sharing options...
strotter Posted October 30, 2011 Author Share Posted October 30, 2011 Wow, it has been a while since I saw this thread. I'm glad it helped. I ended up bolting everything to an aluminum plate, mounting it with four bolts with rubber stand-offs. With the bolts out, it "swings" down on the various hoses. Not that I've worked on it a lot lately... Link to comment Share on other sites More sharing options...
DuoWing Posted September 6, 2016 Share Posted September 6, 2016 This thread sounds exactly like what I need. Especially considering you can even buy one of these civic driers for about $10. The only concern I have is, would this be too small of an amount for a surge tank, or it really shouldn't matter? Link to comment Share on other sites More sharing options...
BluDestiny Posted September 9, 2016 Share Posted September 9, 2016 Surge tank size matters depending on how much fuel you're sending to the engine and how much of it is being used. Link to comment Share on other sites More sharing options...
