Pics of my VG30 mounted in...
BLOZ UP
Here it is. I guess I'm an official hybridz owner now. Or something.
It moved back a little from the ride on the flatbed... need to weld those things in. But think of the possibilities with adjustable engine position.
The mounts are pretty much identical. Since I did the passenger side second, think of it as the driver's side v2.0. The box on the entire side of it was a much better idea. Oh, and on the driver's side I changed my mind on it 3 different times after hacking at it with the bandsaw, so it's a little lopsided and in 3 parts. It works for now, though. I have plenty of steel to to it over again if I find the motivation next summer.
Anyway, I put together some of the dash and electronics and I think everything will be something really close to the following images. The first pic is more-or-less the driver's eye view of it. The second pic includes the stock S30 fuse box (glass fuses FTW!), that I'll be using for the stock items on the car (exterior lights, dome light, horn, etc).
However, while I sat there and contemplated for a while, I decided to ditch the MS Relay Board. It's really redundant in my situation, since I have only a need for the relays. I will have fuses on the switch panel I have.
I will just make another DB37 (with smaller gauge wire this time), and a lot of weatherpaks. With a big enough hole I can disconnect it from MS, and pull it out through the firewall and not have to mess with the individual wires until I actually start disassembling the motor.
Did you notice my sweet transmission "mount"? I would have stolen a dyno strap for a little bit, but they were all in use at the time. (it was a beautiful '69 Camaro with a 402... making a whopping 340hp and tq... oh noesss).
Love the compactness of the VG30E, the only real reason I went for the extra bulk and complexity of a VG30DET is it will rev to 8K.
Have you got any idea BU of what the car's weight distribution will be with that setup? Because you may end up arse heavy the way it is.
Anyway ita a great project, keep us informed eh.
It looks pretty good so far!
I'm curious as to how/where you will end up running the turbo?
Ya got me a bit curious now, I'll have to go home tonight and try and compare your engine position to mine. Front to back in the pics look about the same. BTW don't forget to put some type of heat sheilding for your brake lines, as the crossover pipe gets pretty close with that setback position.
As for weight distribution, I'd be happy to check mine out, if anyone has a good idea how I can measure the front/back separately?
Mine feels very neutral on the track, (how neutral is purely a matter of seat of the pants feel from several drivers who have driven it on the track.
Keep up the good work! Can't wait to see more pics!
Scott.
Yeah, I'm really happy with where it sits. I have no idea how the distro. is going to be. I can only hope that it will be optimal. From my guesswork, it will be more neutral than before, but only more work and time will tell.
Well... I have all this space in the front.... so it will be much like my last VG30E:
In the position I had planned it, the engine is pretty close to the firewall on the driver's side head. There will be no rear crossover pipe. Also, I had to cut the coolant pipes that come out from the back of the lower intake, and from under the lower intake... well, here's a pic:
BOTH of those had to be cut though, and someday I will route them together (no heater). That's an old pic, the driver's side head, which is only partly visible (and out of focus) on the bottom of the pic, sits about 1/2" from the firewall.
As long as it's better than my civic daily driver, I'll be happy. I'm tired of that thing. I hate FWD with a passion. On the other hand, though, it gets 30mpg....
Scott.
Thanks a lot! It was kind of relieving to get over this hurdle. The next "custom" part I need to make is the tranny, and then I imagine it goes downhill from there.
Front/rear weight can be done on drive on scales, did mine at a quarry where they weighed trucks, a six pack was all it took :) Just drive the car half on/half off to measure each end. Of course corner scales are better.
Stock S30 is ~50:50 weight distribution.
I was about to suggest going to the local racetrack if they had one of those, and doing that! I know San Antonio Raceway has one, surely other tracks do. We also have a few quarries too... hmm..
I just took some casual measurement of my fore/aft placement. The 300zxt intake manifold is a very different shape than the pathfinder intake. My intake sits approx 1" from the firewall, and that places the back of the drivers side valve cover a good 3-4" away!
You must have a very setback position for the gear shifter. I had to modify mine to curve slightly aft to get it to come up centred in my console. You may have to do the reverse! hehe
Hmm never thought about pulling halfway on a scale. I'll have to give it a try sometime.
Just so there's no confusion, the VG30E(T) can be made to rev to 8k as well. With proper head porting, maybe some bottom end balancing, and definitely cams made for it you could do it.
That will use a regular transfer case that likely bolts to the transmission and runs a small driveshaft to the front differential. With no center differential though it won't work like the AWD system.
Here's an Audi transaxle. This particular one is FWD but the AWD version will basically be the same with a rear output shaft. This would set the engine pretty far forward but would be one of the better AWD setups as far as keeping everything symmetrical.
The DE(T) should have a better spread of power though shouldn't it. Not knocking the E(T), just trying to justify my decision ;)
With the variable valve timing it should. If you were to build a race engine that technically only needed to run within a certain RPM range, either engine would do really. In the end, the VG30D should be good for more power as it should be able to flow a lot more air with the DOHC heads. Oddly enough though, so far the most powerful N.A. VG I've seen is a VG30E... but it costs more than $10k to get a hold of. :lol:
The DET is definitely not a bad choice, especially since they're probably a dime a dozen down under. Very rarely you'll find a good deal on one in the U.S. and even if you do, it won't include an ECU and wiring harness. I got incredibly lucky on two counts when I found a DET for $500 and picked up a Tomei tuned ECU for $50 or so. Wiring harness I could probably get from a Z32 but I have so many VG30E's laying around that I just like using those. A little more compact and a little lighter. :D
