Careless Posted July 17, 2007 Share Posted July 17, 2007 so I bought a 1250 lb engine support stand. and the bolts don't fit into the holes on the RB, but the bolts that do fit look to be pretty week for a long iron block. How did you fasten your engine to your stand? On the FSM, it shows the RB being mounted from the side using two special plates. My friend has the same engine stand holding up a 350, and it's been there for years. But that's with the bolts it came with. With the bolts to fit the RB, im worried. Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted July 18, 2007 Share Posted July 18, 2007 My block has been bolted on the back for months. I used good grade hardware store bolts. Quote Link to comment Share on other sites More sharing options...
Canadianz Posted July 18, 2007 Share Posted July 18, 2007 My brother and I mounted it the same way and didnt have a problem, we just went and got some nice long bolts to make they'd thread in all the way Rob Crombie Quote Link to comment Share on other sites More sharing options...
synthtk Posted July 18, 2007 Share Posted July 18, 2007 I bolted mine to the 4 transmission mounts, sat like that for months with no issue. Just figure out the size of the bolt ya need and raid your local hardware store for what works. Quote Link to comment Share on other sites More sharing options...
J Taylor Posted July 19, 2007 Share Posted July 19, 2007 Same here. I've had an rb sitting on an engine stand for almost a year. Just get the correct thread and length bolts from a hardware store. JT Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted July 19, 2007 Share Posted July 19, 2007 Mine hung like this, fully assembled, for months..... I use left over L6 crank main cap bolts to bolt the block to the engine stand. They are just the right length/pitch. click Quote Link to comment Share on other sites More sharing options...
Careless Posted July 19, 2007 Author Share Posted July 19, 2007 =) will do, gents! merci. EDIT: so what is the correct length and thread/pitch Quote Link to comment Share on other sites More sharing options...
alexideways Posted July 22, 2007 Share Posted July 22, 2007 Quote Link to comment Share on other sites More sharing options...
Careless Posted July 23, 2007 Author Share Posted July 23, 2007 alexideways said: thats the pic i remember from way back when after i commented about being worried about those 4 bolts holding that iron brick of an engine we call RB. so anyone know the bolt / thread size? i dont have any transmission bolts to compare to. Quote Link to comment Share on other sites More sharing options...
triple B Posted July 25, 2007 Share Posted July 25, 2007 i used the trans bolts and if you use new ones just make sure they are grade 8 or higher Quote Link to comment Share on other sites More sharing options...
Careless Posted July 25, 2007 Author Share Posted July 25, 2007 triple B said: i used the trans bolts and if you use new ones just make sure they are grade 8 or higher that's been established. however, I do not have trans bolts to compare to. That's why im wondering if anyone has the length/thread pitch Quote Link to comment Share on other sites More sharing options...
29PGC10 Posted August 3, 2007 Share Posted August 3, 2007 Than, there is the 'proper' method: nissan engine stand. It will probably cost more than your engine. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted August 3, 2007 Share Posted August 3, 2007 Careless said: that's been established. however, I do not have trans bolts to compare to.That's why im wondering if anyone has the length/thread pitch you could always just use the trans bolts Quote Link to comment Share on other sites More sharing options...
Careless Posted August 3, 2007 Author Share Posted August 3, 2007 e_racer1999 said: you could always just use the trans bolts GRRRRRRRRRRRRRR! someone help me for real, mang! Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted August 3, 2007 Share Posted August 3, 2007 Careless said: GRRRRRRRRRRRRRR! someone help me for real, mang! sorry, i couldn't resist. aren't people bolting RBs up to L-series trannies and vice versa? of that's the case, wouldn't l-series tranny bolts work as well? Quote Link to comment Share on other sites More sharing options...
Careless Posted August 3, 2007 Author Share Posted August 3, 2007 e_racer1999 said: sorry, i couldn't resist. aren't people bolting RBs up to L-series trannies and vice versa? of that's the case, wouldn't l-series tranny bolts work as well? UGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH, i just want to know what the thread pattern is if anyone knows it. Aswell as the lenght. I don't have a tap set right now (stolen from a friend's house) and I don't want to take the tranny bolts out of my cars tranny to prop up an engine. If i had a good reason to hold up my engine with an L28 bolt set, now that I know, I would use it. but i don't... and this could be information that OTHER people can use if someone would be so kind......... Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 3, 2007 Share Posted August 3, 2007 Careless said: GRRRRRRRRRRRRRR! someone help me for real, mang! I use the main cap bolts off the crank. They are 2 3/4 long (may not work for you due to engine stand design) and the pitch is 1.50 metric. I used a 10mm 1.50 tap to match up the bolt size to.... sorry for the poor quality pics. click em Quote Link to comment Share on other sites More sharing options...
zcarmark Posted August 4, 2007 Share Posted August 4, 2007 their 10mm by 1.5 thread by aprrox 2.5" long Quote Link to comment Share on other sites More sharing options...
Careless Posted August 4, 2007 Author Share Posted August 4, 2007 wicked. thank you very much people. I have the main bearing cap bolts for my RB30 at the machinist. And I don't know if i would dare use those on holding up the engine just incase i plan on reusing them. LOL Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 4, 2007 Share Posted August 4, 2007 Careless said: wicked. thank you very much people. I have the main bearing cap bolts for my RB30 at the machinist. And I don't know if i would dare use those on holding up the engine just incase i plan on reusing them. LOL I hear ya... I wouldn't either. I just happen to have a few sets left over from swap outs to ARP's. Quote Link to comment Share on other sites More sharing options...
