m1ghtymaxXx Posted August 2, 2007 Share Posted August 2, 2007 I went to start my car today after not driving it for 2 days. When I turned the key, all i got was a click comming from the starter. This has happened in the past, but i traced it back to battery terminals. It was arcing from the terminals to a bare part of the batter cable. A little eletrical tape fixed that. So i cleaned the terminals, made sure there was no bare cable, and it still wouldn't start. Next i tried sanding the positive terminals at the starter, as well as a few shots of contact cleaner. Still didn't really help, although it did start just once after that. Since i was just trying to leave to a movie, i didn't have time to play with it too much. I didn't get a chance to a play with the starter ground, but my starter is grounded in 2 spots. One to the motor ( I think, theres no ground cables), and also directly to the negative battery cable (I did this last time it wouldn't start. Found that the bottom terminal on the cable was just dangling, so i connected it to the starter mounting bolts). Also, me and a freind just decided to try and push start it. For whatever reason that wouldn't do it either. And we've push started it numerous times without a problem. Can anyone help diagnose the problem? I would guess its the starter motor itself, since i assume the click is the solenoid working? I've got a 83 turbo parts car as well, but i'm kind of afraid to jack it up to get the starter out of. Quote Link to comment Share on other sites More sharing options...
SteelToad Posted August 2, 2007 Share Posted August 2, 2007 m1ghtymaxXx said: ... we've push started it numerous times without a problem ... I think that's the definition of a problem. The solenoid can click, but still not be working. Quote Link to comment Share on other sites More sharing options...
naviathan Posted August 2, 2007 Share Posted August 2, 2007 Yeah, it's either a bad battery or a bad starter. Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted August 10, 2007 Author Share Posted August 10, 2007 Turned out that the solenoid wire popped off. Found that out after pulling it and taking it in for a bench test:mrgreen: Quote Link to comment Share on other sites More sharing options...
z or bust Posted August 10, 2007 Share Posted August 10, 2007 Starter cylonoid (I think thats how you spell it). I have had this happen many times. Try tapping on the starter with the butt of a hammer or something Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted January 25, 2008 Share Posted January 25, 2008 Sounds like you ought to rerun and repair your battery cables. The ground should drop down to a bolt below the battery box and then to the starter. Have real battery cables not something that someone cut off an put one of those clamp on one size fitall type. They corrode down inside the insulation. zx electronics don't like low voltage. You may be able to turn the engine over but not enough voltage to make the ecu work. I know you found your problem but caution that a few loonies spent on making sure you have good battery cables will save some hairpulling and cussing in the future. Or it could be interference from the northern lights Quote Link to comment Share on other sites More sharing options...
RedEvilrps13 Posted January 25, 2008 Share Posted January 25, 2008 z or bust said: Starter cylonoid (I think thats how you spell it). I have had this happen many times. Try tapping on the starter with the butt of a hammer or something its spelled Solenoid. Quote Link to comment Share on other sites More sharing options...
